Remote not working. tried the tin foil idea w/o success. can you repair or tell me where to replace it?
    Brigadier General:
  • 8,546 Answers
Try this advice:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved
How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the unit.
If it works, Great!
If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Find new or replacement remotes:
http://remotes.com/store/codes_original.html
or eBay: search for "(model) remotes", check the 'include description
Posted on Mar 28, 2011
Cobra model GA-bn and GA-cd charger. Won't charge.Tried previous suggestions to cover base of one battery with foil I used aluminum foil, not tin foil. Charges for a minute or two then stops.
Depending on price point, it may be more cost efficient to simply replace the units as opposed to time spent attempting repair.
Contact your local retailer directly or online here: Support Cobra Electronics Corporation
Jun 02, 2017 | Cobra Radio Communications
Oven door will not remain fully closed
Noiselab is not correct for all cases. As Buzz says, if the springs are strong then the foil fix works and works really well. Refer to attached photo for guidance in conjunction with instructions below. Note my possibly simpler answer at bottom.
I cut some short narrow strips (about 4mm x 20 mm) from a tin can and folded them over into a flattened "U". You can back off the large Phillips head screw on the frame of the oven where the door hinges are inserted and sit the tin over the little plate that is held by these screws and then tighten so that one end of the "U" sits between the oven chassis and the adjustment plate. If it still doesn't quite close add more tin as required. Refer photo for terminology.
Now the simpler solution which I didn't try but which would probably work after I contemplated the problem in retrospect is this. The reason I didn't think of this was that I thought the hinge went into a tube or slot. Later I realised it is just a simple cantilever design which is why the tin foil solution works (ie lifting the middle support of the cantilever produces a corresponding closure of the door). When I inspected the large Phillips head screws to insert the tin foil these were completely loose. Try this first then. Slide the adjustment plate up as high as the tolerance of the Phillips screw allows and then tighten it off hard. This will raise the bottom edge of the plate just as the tin foil method does. If not enough then proceed to the tin foil method.
Jul 09, 2010 | AGA ILVE M-90F-MP Dual Fuel Range
My kenmore cooktop keeps blowing the fuse. as that is all that is on that fuse. i have no idea where to start
take one out turn others on keep going till you find the bad one....if you use tin foil look for it where the burner plugs in(never use tin foil in your stove anywhere)
Aug 20, 2009 | Cooktops
My remote doesn't seem to be working to my Naxa TV. I have put in new batteries. The TV comes on with the "green" light in front. But when I click remote "pOWER" nothing happens ??? Thanks
If you replaced the batteries and can turn on the TV manually, then the button is probably not making proper contact with the remote. Try opening up the remote and placing a small piece of tin foil where the power button is, close the remote up and it should work.
Aug 03, 2009 | Televison & Video
Sharper Image iTower remote not working
I put a small piece of tin foil on the negative side of the battery and the remote worked again.
Mar 28, 2009 | Electronics - Others
How do I remove tin foil baked on brand new oven bottom?
Unfortunately you can't remove that foil, you will end up doing more damage to the liner. the only thing you can do is replace the liner. And it's a big job, if the manufacture makes a replacement part for your unit, and if they do it will be costly. Your warranty will not cover it.
Jan 09, 2009 | Kitchen Ranges
How do I remove tin foil baked on brand new oven?
Unfortunately you can't remove that foil, you will end up doing more damage to the liner. the only thing you can do is replace the liner. And it's a big job, if the manufacture makes a replacment part for your unit, and if they do it will be costly.
Good luck....
Yes, we were a couple of dummys when we received our brand new LG stove, with convection oven,glass top and very fancy, and we put tin foil to cover the bottom of the stove and of course yesterday when I...
I really don't know what to tell you. During the clean cycyle the metal probably melted and is permantly sealed to the bottom. You are lucky the oven still works. Sometimes using foil will destroy sensors or other things. NEVER use foil in ANY oven!!!!! The only exception is to partially cover the shelf underneath something you know is going to make a mess. Even then don't cover more than about 60% of the rack.(Never do this in a convection oven as the fan will blow the foil ) Also NEVER!!! allow foil to come in contact with a hot burner. It will melt to the smooth top or coil.
Jul 07, 2008 | LG Kitchen Ranges
Unable to get my bush tv to accept any code to enable me to use my sky handset to switch tv on off
Hi Roger,rather than paying out for a universal try repairing your own remote first by taking it apart and where the power button is clean it with a damp cloth and also clean the circuit board where the power button is,this sometimes cures the fault,but if the rubber power button itself is worn on the pad side(contact side) another good trick is to put a drop of super glue on the button and quickly attach a small piece of tin foil(same size as the single pad) to the rubber button(underside of course) this almost always works,failing that a universal could be your best bet but try to get an upgradable one.
Feb 02, 2008 | Televison & Video
489 people viewed this question
 Grubhead
Grubhead
