Tv sanyo katron (sound problim) ther are a noise with sound all time
2 Suggested Answers
SOURCE: broken xbox 360
check if it is on the cords, or you might need to play with the wires by picking them up and things .....that is what i needed to do.... and I play it as long as it isis to the side....
Posted on Apr 27, 2008
Top 1/4 of ther screen is distorted
If that is a plasma - and it sounds like it is - it probably needs a new upper buffer board or, better yet, both buffer boards replaced.
Jan 11, 2014 | Sanyo 42 in. LCD TV
My Sanyo is making a noise that's been a little quite but now its louder and it would usually go away but its not. Please help I don't want to use the small tv
One anong your TVs transformers causing the problem. Usualy, on all tvs ferrite cored transformers are used. If the core of the transformer get loosed, it will make a whisling noise. To get the faulty transformer, you must open the back cover of the tv and listen which transformer makes noise. Usually core of LOT will vibrate. After recognising the transformer which makes noise, press its core with a wooden or plastic matereial to sure the transformer under concern is it or not. Fix its core joints with some super glue, without seperating it you can do that. Take caution. There are severel very high voltage points are ther inside the tv.
Oct 13, 2010 | Sanyo HT32744 32" TV
Broken xbox 360
Apr 27, 2008 | Microsoft Xbox 360 Console
Sanyo HT27547 tv - lightening came in on coax line
Ther is probably a fuse and a diode that got hit by the lighting. If you want to try to fix it yourself unplug it check the fuse and change it if it is bad. Then turn it on again. If it blows that fuse then a diode is also out.
Mar 18, 2008 | Sanyo HT27546 TV
Sanyo avm 2506 tv no sound
As It only makes noise when there is no signal (without an antenna).clearly indicates that there is a problem in sound IF SECTION or loose contact in that section. your audio section section is ok as you get noise signal when there is no signal. also check remote control setting.
Sep 27, 2007 | Sanyo AVM-2506 TV
Relay "Chatter" with good picture and sound
Sanyo Model AVM-1304 This TV has a loud mechanical "chatter" (or clicking)that appears to be coming from RL001 on the motherboard as soon as ther TV is turned on. I can feel the mechanical vibration on the component. The Picture and sound are very good. The chassis is G6Y-13040. Any ideas? This TV has a loud mechanical "chatter" (or clicking)that appears to be coming from RL001 on the motherboard as soon as ther TV is turned on replace relay as it is easily available or make it direct. .
Sep 11, 2007 | Televison & Video
TV got sound but only shows a complete white screen and the message no signal connection
call a tech your tv needs to be repaired tv is having a problem in the video circuit ther is a cip that controls that circiut checks should also be made in the related circuit.video IF circuit.good luck
Mar 01, 2007 | Sanyo DS24205 24" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
