Question about LG LMVM2075 Microwave Oven
I recently had main door replaced on my LG2075 from slamming door it stopped. I had a repair man come and replace door. Now new door 2 months old won't allow unit to stop running. Close door it comes on and stays on. A couple door buttons work but only showing you that you have pushed button. No functioning. Unit will not turn off. New door bad ?? Adjustment?? Help Frustrated LG owner!! Lol
    Brigadier General:
  • 8,909 Answers
I would say adjustment or faulty door switches.
Posted on Mar 28, 2011
Hi, My Bosch built in microwave won't start when I close the door unless I slam it. I suspect the switch. Think so? Can I get at ithe switch to replace without removing the whole unit from the
You will need to remove microwave to access casing, remove casing and check door micro-switch. The switch activator will need adjusting to enable door interlock to activate.
Sep 29, 2014 | Bosch 500 HMB5050 Microwave Oven
Hello, I have a Danby micrwave that is almost exactly a year old and it suddenly just stopped working. Seems to have no power at all, nothing works. Is there a simple fix or is it garbage already? ...
You can check the rear for a fuse. Also check the wall outlet by plugging something else in. If not, then as you say, it is not worth paying for repair.
Put in a Warranty Claim
on warranties
To ensure our customers are taken care of, Danby proudly offers the industry's longest warranty and extended warranty options. Our products include standard 12 month, 18 month and 24 month warranties that include parts, labour and in-home service. We're here to keep you moving forward.
Support Danby
Dec 24, 2017 | Danby DMW799 Microwave Oven
I have a ge jvm 1750 dm1ww microvawe and suddenly stop working . i changed the 20 amp 250 w fuse inside the display panel and the light and the microvawe started working again.However as soon as i use the...
It's possible the high-voltage capacitor is bad, but I suspect a bad interlock monitor switch. This is one of several switches operated by the door latches, and it's wired to cause the fuse to blow if you try to operate the oven with the door open. The switch may be stuck, which can happen if the oven door gets slammed. It's also possible the switch is good but is out of adjustment.
Replacement switches are available. The Sears parts website has an exploded diagram showing where it's located (item number 30). You should let a professional make the repair, though. Microwave ovens are dangerous items to work on, and if door repairs aren't done correctly there can be excessive microwave leakage.
Mar 20, 2011 | GE Microwave Ovens
2 months old. bought brand new. and just stopped
These things will happen. You are aware that these appliances have a 12 month warranty so return it to where you purchased it from.
Feb 17, 2010 | Microwave Ovens
Unit does not respond to anything-no power indication. It is 15 months old. any suggestions?
If there is no sign of power at all it may be that the fuse for the internal power supply has blown.
These are normally a special ceramic type and I have seen these simply give up when a microwave oven door is slammed shut a bit too hard. Recently happened to me.
The fuse should be visible as soon as you have removed the main casing. They are a special ceramic type. Normally if you look on the circuit board where they are mounted on you will see the rating for the correct fuse.
Try this first, If it fails again then something is drawing too much power and it should be further investigated by a service engineer.
Jul 04, 2009 | Kenmore 66029 Microwave Oven
Neff combination microwave oven
We have had NEFF repair man out again and he replaced the door switchs and this time it is OK.He did say if it was a problem again it will be classed as unrepairable because he thinks it is shorting out on an internal rivet on the bodywork which is inaccesable. fingers crossed it was the door switchs and it dosent blow the main fuse again .thanks for your responce. Simon.
Jul 23, 2008 | Microwave Ovens
NEED TO REPLACE THE WHITE PLASTIC CATCH ON NEXT TO THE CONTROL PANEL AS IT SNAPPED OFF AS MY SON SLAMMED THE DOOR
By the nature of the oven main face plate and the locking latch being attached to the safety system the replacement cost is usually higher than a replacement microwave oven.
In your case replacing the microwave with another one is more sensible. Your oven is an obscure model as it is, I'd suggest a sharp brand.
Regards,
Worldvet
May 15, 2008 | Zanussi ZM24STX 900 Watts Microwave Oven
Neff microwave combination oven
no solution sorry but we also have a Neff mw/combi oven which keeps blowing for no apparent reason, the Neff repair man has looked at it 4 times and practically replaced every component -power module, operating module,relay board, door switches but it`s just gone again! The model is a H5972N0GB/01 and it is approx 3 yrs old, no problem for the first 2 years .Time to write to Neff -is yours the same model?
Apr 23, 2008 | Microwave Ovens
It blows the fuse each time open the door if this em-Z2100GS
Probably a bad door switch or door switch mount. It may have gotten damaged or misaligned in shipping.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Being only 2 months old, I would think you have a warranty, but maybe not. I'd contact the seller to see.
Nov 21, 2007 | Sanyo EM-Z2100GS Microwave Oven
Turntable continues to rotate.
I would say you have a failing door switch or the mount which holds your door switch is loose or broken. In most designs, it is the upper door switch that will produce these very symptoms when it is intermittent or its mount is broken or loose. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. Slamming the door, damage during shipping or transportation and sloppy manufacturing techniques or materials are the primary causes of trouble with the door switch mounts. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. You can find these files via a Yahoo search. In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see from time to time, and we repair those nationwide, but it's usually a door switch. If you still have a problem, please post again. Be safe!
Oct 29, 2006 | Panasonic NN-S264BF 1200 Watts Microwave...
LG LMVM2075 Microwave Oven Logo
151 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
