Question about Dryers
The dryer is viberating more that usual. I opened and checked the rollers under the barrel. They turn and don't feel loose but the entire moving parts assembly around the barrel is visibly shaking more that it used to.
I just had to replace the rollers and the front and back seals on my dryer because it was doing the same thing. You might also replace the belt while you are in there, if it looks worn. Mine runs good now.
Posted on Mar 28, 2011
My kenmore 84052 is making a squeaking noise
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
The glides on drum worn and making metal to metal contact.
CHECK FOR LOOSE BELLOES inside the drum
Aug 14, 2014 | Kenmore 84052 Dryer
SCREECHING DRYER
DRYER MAKES NOISES.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
Apr 11, 2014 | Frigidaire Washing Machines
My dryer's barrel will not turn. I have replaced the pulley and belt but that did not fix the problem. The pulley's tension is not tight enough to turn the barrel. I have the correct barrel and...
Hello Mwagner, sounds like the Idler bearing pulley assembly has come loose from the belt. It's job is to keep tension on the belt so the motor is able to turn the dryer drum. By watching some videos online it seems that alot of teardown is required to get to the part you need to inspect and or replace. Here is a link for you to look at that might help you. Samsung Dryer Idler Pulley Roller Replacement DC97 07509B
May 04, 2017 | Samsung DV316LES Electric Dryer
Turn on gas dryer, but the barrel does not move. I do hear a motor click. I then gave the barrel a little assist to start it moving. then the motor worked as it should. Gas came on the barrel was move at...
You must never attempt to repair or troubleshoot your home-appliances unless the electrical power is switched off and the plug removed.
This site or myself cannot accept any responsibility for injury or death following any attempt to follow the advice given within this website.
If you are in any way unsure of your ability to follow the advice then call a qualified electrician or service person.
Unplug or electrically isolate the appliance before checking any part of the wiring, or opening the protective covers
Kenmore dryer troubleshooting - The dryer will not operate
1. Check that the power is on to the machine. The power indicator light will if this is the case.
2. Check that the door is properly closed. When a door interlock switch is not activated properly the machine will not start. The best check is to open and close the door several times and sometimes the microswitch may be sticking and some do come loose due to vibration
3. The dryer start switch hasn't been pressed or turned properly.
4. The dryer program hasn't been selected
Kenmore dryer troubleshooting - Dryer does not heat
1. The electrical circuit fuses or circuit breakers have tripped. If they blow a second time then you may a faulty or blown heating element.
2. Heating element thermostat is faulty.
3. Heating elements are faulty. In rare cases the wire connections may have burnt off the element. WARNING Do not open the rear access of the dryer until the dryer is unplugged!
4. Heating overheat cut-out switch has tripped out or is faulty. Some machines also have a replaceable thermal fuse that should be checked.
Save time with easy cleaning - burners are sealed so there are no cracks or crevices to trap debris. Cook top spills wipe-up quick and easy. Plus,
Dec 21, 2010 | Kenmore 74602 Gas Dryer
My Kenmore Dryer Model 65732 drum won't turn. I opened up the front so that I could see the drum and I can see that the belt is okay. I can also see that the rear drum seal has deteriorated. Can anyone...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2010 | Kenmore Dryers
Loud noise that sounds like a train coming from drum
Check inside the drum for loose plastic bars that run front to back. You will need to release the top to tighten them if they exist. With top open, check the drive belt condition and replace it if it is cracked, pieces missing, or running loose. To release the belt, open a panel in back and release whatever creates tension in the belt (usually remove a large spring). With belt off, turn the drum by hand to check the rear bearing and whatever provides a bearing for the front edge of the drum--some dryers use plastic plates on the cabinet side for the drum to turn on, and others have actual rollers that the drum turns on. If rollers, check each one for missing pieces or warped surfaces of the rollers. If plates, check each one for wear through to the metal. Hope this helps.
Nov 17, 2009 | Computers & Internet
Dryer tumbler barrel loose
Depending on what brand a model. This sounds as though the guide roller or guide roller shaft are bad and are in need of replacement. It could also be the tub glides are bad. If you will give me the brand and model number I can probably tell how to check this and repair.
Nov 14, 2008 | Dryers
Paper does not feed completely properly.
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
If the error still exists then its the problem with rollers it needs to be serviced..
Good luck..
Nov 13, 2008 | Lexmark P4350 All-In-One InkJet Printer
My dryer dries but it shrieks. Do I need to buy a new one? Is it worth it to have it fixed? Thanks!
usually this is a sign the felt bearings on the drum, or the roller bearings under the drum are worn and need replacing
felts and rollers should be visible once you open the case
check the rollers turn freely, check the felts are not worn through and metal showing
replace both rollers or both felts if one is worn
roolers are bout $9 /pair
felts can be anything the manufacturer thinks they are worth
Aug 28, 2008 | Maytag Dryers
Tumble dryer fault
Jul 01, 2008 | Zanussi TC7114W Electric Dryer
Dryers Logo
54 people viewed this question
Top Dryers Experts
