Question about Health & Beauty
I just received two new battries for our DKS200 Sport, however, our son removed the old batteries and did not write down were the wires go. There are two red wires, two black wires, two white wires and one blue wire. The two white wires are connected to the Reset button on the battery case. My son said that the blue wire went to the ground screw. A picture of the battery connections would really be appreciated. Thank you, Tom
    Genius:
  • 1,622 Answers
Hi, ok it's very easy to connect.
Your son was right about the ground shield which is the blue wire.
Connect the red wires to the positive side of the battery (the side with + sign),
and connect the black wires to the negative side of the battery..
Also connect the white wires to the reset button on the battery case..
That will do.
Take care..
Posted on Mar 28, 2011
When start the engine all the lights are blinking
NEVER remove the battery cable when the engine is running. It can damage the alternator and a lot of other electronics on the vehicle. The alt will go to the full charge mode. Most all of the dash warning lighs shut off thru a circuit that goes to the alternator. Check your wiring for loose connectors or a grounding wire.
Dec 31, 2013 | 2000 Mitsubishi Montero Sport
Looking for a bladez DKS200 mobility scooter battery case?
http://www.bladezscooters.com/
http://www.monsterscooterparts.com/
Unlikely some other manufacturer's box will fit, if only because the circuit connecter is built into the pack.
May 03, 2012 | Health & Beauty
1994 olds 88 Wont start up. Battery problems?
Put another battry in and see sounds like battry
Nov 13, 2011 | 1994 Oldsmobile 88
Battries going flat
Good day to you, how are you doing? The problem with your gps that the battery goes flat is as a result of a weak battery, the battery might seem to hold full charge but gets discharged easily and soon. First try another battery in it to see if it will run down easily, if it last for long, then all you need to do is to replace the old battery with a new one, but if the battery goes flat soon, then it is the gps that need to be checked for its energy consumption.
Hope this information helped.
Dec 22, 2010 | Navman S70 4.3 in. Car GPS Receiver
How to remove battery from columbia CL-5012 watch
Take It Too a Place Like JCpenny Store or Sears or Wal-Mart or Target & They Can Remove Battery Things From Watches as Well as Replacing Battries Too Have a Nice Day.
Nov 27, 2010 | Columbia Sportswear All Sport Digital...
Changing rechargeable battries 45-40
Metz 45-40 consist of 6 nos of NiCd - AA size batteries connected in series. These battery packs can be rechanged by resoldering new set of AA size rechargable Nicd battries. Care should be taken not to short circuit the cells when disassembling and assembling the cells. Keep a note (sketch) of the connections of the cells, specially the longer connecting metal strip and the polarities of cells. re-solder the new set of AA size NiCd Batteries. If the old wires were corroded, use new wires' If the connecting terminals also corroded' clean it. If it is severely corroded, get it plated prior to fixing for better performance.. There is an charging indicating lamp which also control the charging current of the batteries. check its connections and solder it if required. I wish you got the answer for your problem.
H.D. Shirantha.
Sep 07, 2010 | Metz 45 CL-1 Flash
My 580 phone is fully charged has been turning off by itself, it beeps then shuts down,i do charge the phone when battery is low
how old is battery ? rechargable battries can get a memory to them if very old get a new battry
Feb 02, 2010 | Cell Phones
Remove starter on a 2001 ford explorer sport
Gather the necessary tools needed such as wrenches, sockets, screwdriver and pliers.
Place the vehicle on ramps or jack up the front and support with jack stands. It is very important to block the rear wheels to keep the car stationary during this procedure. Never work under a vehicle not supported properly
Make sure ignition is OFF and the remove the negative (ground) battery cable from the battery.
Note the location of all wires before removal to make for easier connection.
Remove the large starter cable going to the battery at the starter location.
Remove any other wires attached to the solenoid.
Remove the starter attaching bolts (usually there are two or three).
Remove any supporting brackets that holds the starter.
Drop the starter down away from the car. On some cars you may have to turn the wheels to one side, remove the idler arm, remove or loosen transmission oil cooler lines, exhaust pipes, or ground straps to give you enough clearance to get the starter motor away from the car.
Install the new starter in the reverse order of removal.
Reconnect battery cables and other wires to solenoid.
Place old starter in the new starter box for proper core return.
Sep 20, 2009 | 2001 Ford Explorer Sport
Battery change on Columbia All Sport CL 5008
Buy a set of precision srewdrivers. Remove back(4 screws),take your 1 mm flat screwdriver and push straight down at the end of the hold down strap at the inside end. KEEP IT TIGHT IN THE NYLON CATCH! The hold down is hooked on the bottom of it. It will release and you will be able to lift that end and replace the battery. Then just push it back to hook it,VOILA! R.J.S.
Mar 16, 2009 | Columbia All Sport Digital watch
Health & Beauty Logo
49 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
