Question about Asko W6021 Front Load Washer
I have an asko 10505 washer. how do you open the door?
  • 32 Answers
Here is a video that shows someone closing an Asko machine. I think you just have to get your hand in that place where she shuts the door and pull.
http://www.youtube.com/watch?v=kmvxNwqUDJ8
Posted on Mar 28, 2011
  • Asko Master
  • 2,605 Answers
Welcome to FixYa.
To answer your question, "i have an Asko 10505 washer. how do you open the door?" Aside from the door lock switch on the control panel (shown below), you can open it via the manual door latch safety release by the pump.
Even though the image above is the 12505 it's essentially the same, To access this latch release with these Asko machines you must first remove the access panel below the door.
i.e.
The image I attached above is an example of a access panel I had to remove and disassemble to inspect it. There will be a red loop attached to a string next to the pump and fastened to the inner metal panel (not shown here) via single torx screw, if you remove the screw and pull the loop, the door will open.
Let me know how you make out or if you require further assistance. Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
  • Houston resident
    Houston resident Nov 17, 2014
    For the unlock button to work, the machine has to be turned ON
    New Friend:
The washer has to be turned ON for the unlock button to work.
Posted on Nov 17, 2014
3 Suggested Answers
  • 49 Answers
SOURCE: asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
Posted on Mar 06, 2008
Macmarkus
  • 2605 Answers
SOURCE: asko 10505 washer will not spin
Hi, 2 things to check for. Obstruction in the drain pump or faulty drain pump, brushes in the motor worn out. The easiest way to determine the pump issue is answer this question. Does it drain ? Next, turn the timer to the drain/spin cycle, obviously it should drain & spin and advance to "off". The next thing with these 10505 asko is to see if the drum rotates in both directions in the wash/agitate portion of the cycle. You can just select the short wash for this (I forget if it's #4 or #5) If not, it's worn brushes. However, you'll have to make sure the armature isn't damaged before simply installimg new brushes. We can cross that bridge when we get there. Let me know. Hope that helps, though those are just the most common problems there could be others. Good Luck
Posted on Nov 01, 2009
I can't open the door to the washer, asko 10505. I ran a load, and it's all done washing, but now the door is clicked shut, and I can't figure out how to release it and get the laundry out. can you...
After teh program the latch had to disable but possible that the lock got jammed or the end link is not connecting.
Look from the bottom and you can access the lock section to release and get the lock function.
Once it opens use good degreasing spray and then oil then lock as there can be rust or dirt that has got it stuck.
The end program safety link must also work.
Sep 02, 2010 | Asko W6021 Front Load Washer
Unable to locate any info on a model 10505 se # 982410041588
Hi, I may be mistaken but I don't think so, that number ( 10505 ) is for an Asko washer built in 1998, not a dishwasher. Do you require assistance with your washer ? I will watch for your reply. Macmarkus :)
Mar 17, 2010 | Asko Dishwashers
Asko 10505 door doesn't open
It is very likely a drainage problem. Please see this link:
http://www.fixya.com/support/t427982-asko_10505_wash_finished_door_open
Mar 06, 2010 | Asko Washing Machines
Asko 10505 washer will not spin
Nov 01, 2009 | Asko W6021 Front Load Washer
Leaking inlet valve on Asko 10505
Unfortunately, the only way to be 100% sure this won't happen again is to replace the inlet water valve. Especially if the problem is intermittent. You could live with it if you turn off your water taps when the machine is not in use.
Feb 19, 2009 | Asko W6021 Front Load Washer
Repair front load washer
wash machine not draining properly at end of wash. not fully spinning.
pls advise
Sep 11, 2008 | Washing Machines
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Asko 10505 - wash finished, door won't open
Mar 06, 2008 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer Logo
1,209 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
