Can one Lutron AYF-103P dimmer control 2 Lutron EC3T832GU210 ballasts? Ken Smoker, Ken Smoker, Inc.
2 Suggested Answers
wentlanv
  • 710 Answers
SOURCE: Can a Lutron AYF-103P ARIADNI FLUOR control two
Since this dimmer is a 3-way, it can control more than one light. Assuming there is one ballast in each light, I'd say Yes.
One thing you should know is that if you have more than 2 switches in the circuit, only the 2 end switches are 3-way, the ones between should be 4-way.
I've also heard that dimmers do not last very long on 3-way circuits, however it's built to be a 3-way, so it should work fine.
Hope this helps, if it does, please place a vote for me.
Thanks,
Handie Andie
Posted on Mar 28, 2011
WHEN DIMMING IN MINIMUM POSITION THE LIGHTS START BLINKING
Which dimmer do you have. So I can look up the manual.
Are you using a fan dimmer, or light dimmer?
Does the dimmer feel warm to touch? or hot?
What does the dimmer control? Incandescent? Fluorescent?
How many total watts are being dimmed?
Is this a new dimmer or old dimmer that started having a problem?
Add a comment with as much detail as possible for best available answer.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 08, 2012 | Lutron DVF-103P-277 Diva Fluorescent...
New dimmer switch not working
Hi -
The Lutron D600P is a preset single pole dimmer. Wiring is pretty straight forward as show in this diagram. Recheck wiring and if OK, continue below.
If power is present on both wires (black / red wires), power is being passed through the switch to the lamp and the light should be on. If not, try replacing the lamp.
Minimum recommended connected load is 40 watts. This switch is ONLY for use with filament type lamps - such as traditional tungsten, halogen, etc. It is NOT to control speed of Fan Motors, nor dimming of CFL (compact fluorescent lamps) energy saving types or other ballast operated lamps such as High (or Low) Pressure Sodium, Metal Halide, Fluorescent, etc. as this would create a high heat condition and could cause a fire.
If you're still having trouble, you can contact Lutron Technical Support Center 1.800.523.9466 24 hrs / 7 days www.lutron.com
I hope this helps & good luck!
Sep 02, 2012 | Lutron #D-600PH-DK 600W SP Push Rotating...
Require schematicwiring ofma400 and high power 2 lutron dimmer
You can access Lutron's Wiring Library here:
http://www.lutron.com/Service-Support/Technical/Pages/WiringDiagrams.aspx
I couldn't find an MA-400 or High Power 2 dimmer, so you might want to double check the model numbers and look for a match in the link above.
Jan 02, 2012 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
Lutron 1000w skylark s-103p. The lights hooked up to this dimmer had always worked. now sometimes when i hit the on buttom they don't come on at all. the dimmer is probably5 years old.What do you...
Older dimmer switches use rheostats to adjust the resistant loads on the switch. Since this is a mechanical operation, over time they become loose or corroded. So it sounds like this has happened to your dimmer switch and you should replace it with a more modern switch that isn't as mechanical.
Jun 26, 2011 | Lutron SKYLARK S-103P Light Control by...
Can a Lutron AYF-103P ARIADNI FLUOR control two ballasts?\r\n Ken Smoker Ken Smoker, Inc. Ballast # EC3T832GU210
Thanks,
Handie Andie
Mar 28, 2011 | Lutron Dimmer Controls - AYF-103P-277 -...
Need to hook this up to a lutron eco-t528-277-2 ballast which only has a hot,dimmed hot and neutral
If I understand correctly, you have Leviton florescent dimmer
And you want to connect dimmer to Lutron ECO-series ballast
This is the ballast with 3 wires: Hot dimmed, Neutral and Hot
Is this your dimmer???? Has Black, White, Red, Yellow-red, & Orange
Here's how to do it:
Dimmer yellow-red is not used except for 3-way switch >> cap it off with wire nut
Dimmer orange wire connects to ballast Dimmed Hot
Dimmer red wire connects to ballast Hot
Dimmer white wire connects to ballast Neutral
Those are your wires going to ballast. As you can see, you need 3 wires going to florescent fixture
Next, let's focus on Dimmer:
Dimmer green wire goes to bare ground wire
Dimmer black wire connects to Hot from breaker box (we'll test for that next)
Finally the Dimmer white wire connects to ballast Neutral as discussed above BUT is also has to connect to Neutral from breaker box
This means the Dimmer white wire is connected to 2 wires >> one wire goes to florescent fixture and the other wire comes from breaker box
So which wires come from breaker box??
It should be a black and white wire.
Let's test to find Hot and Neutral that come from breaker box.
Mark your wires.
Disconnect all the wires and separate from each other
Turn on power
Use ordinary tester
Tape tester leads to wood sticks so hands stay away from electricity
Power is on
Test each wire to bare copper wire
When tester lights up, that is Hot from breaker box ... this wire connects to Dimmer black wire
Now, test the hot wire to each of the other wires
When tester lights up, that is Neutral wire ... this wire connects to Dimmer white wire, and also connects to Ballast neutral.
Connect one wire at a time, and it will work.
Oct 04, 2010 | Leviton Decora Light Dimmer Switch
Fluorescent dimmir
The dimmer you purchase needs to be compatable with the ballasts of the C.F. light. A compact flourescent potlight has a ballast, if your replacing incandescent bulbs with compact flourecent lamps
you still need a flourescent dimmer. Remember a ballast is like a transformer! If you compact flourecent fixture has a ballast by Lutron. then you need a lutron dimmer as there ballasts are not officially compatable with other dimmers, allthough I've seen them work. My advise is buy Pass & Seymour (Legrand) or Leviton.
Jan 21, 2009 | Pass & Seymour / Legrand DFB600-M 600VA...
Have a Lutron Skylark SF-10P need to wire to existing 3 wires
You have to have a special ballast on the light to dim fluorescent light fixtures. You also have to have a special dimmer.
Nov 28, 2008 | AMS Lutron SFSQ-LF Skylark Slide-to-Off...
How many dimmers types?
Certain dimmers can control standard incandescent lamps that use 120 volts while other dimmers can control low voltage xenon or halogen light sources that use 12 or 24 volts.
Aug 27, 2008 | Lutron Electronic Low-Voltage...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
