Question about Belkin (F5D5231-4) Router
Network key for router.
I'm using a belkin 54g router and when i try to connect to the internet, in the properties it says: security type, encryption type and network security key. how do i find the network security key, please help me fix this
  • Anonymous May 11, 2010
    Two questions I will require answers to before I can assist you. One have you ever changed the security settings on your router before? Two, are you sure you are trying to connect to YOUR wireless network? Shoot me the answers and I will be able to assist you further.
    Novelist:
  • 173 Answers
In onder to obtain this information you need a computer that has internet connection through the router, if you have a main computer that is wired through the router then use that computer if not try to hardwire the laptop to the router(plug it to any of the number ports that say ethernet/lan). Access the setup page of the router by typing 192.168.2.1(deafult IP address of the router) on the address bar of your browser(i.e. Internet Explorer, Firefox, Safari), type admin for the username and leave the password blank. Go to the Wireless Settings/Configuration tab of the router and verify the security mode(WEP or WPA)
Posted on Aug 06, 2008
6ya staff
SOURCE:
I am trying to connect my archos device to my belking 54g wireless router for internet access. the archos is asking for a windows wep key and hexidecimal wep key. where can i find these?
The windows wep key is something that is normally set up when you configure your router. It is something you yourself add when you want to encrypt your network. Here is a good guide for doing that:
http://www.tekstenuitleg.net/en/articles/networking/wireless-security-guide/configure-wep.html
Note that there are different levels of encryption you can use. Wep is only one of them.
Jun 23, 2011 | Belkin Computers & Internet
I need to secure my belkin 54g so other people cannot use it, how do i get to the setup page first?
BELKIN ::::
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Jan 15, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin 54g router I am trying to use the wireless featur of the router but when connecting I kepp getting the message limited or no connectivitythe network is security-enabled and the password is correct...
Jun 28, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Web key wireless internet service
I think you meant WEP key. this is a wireless encryption security key. and it is normally required when you try to connect to a secured network. Your administrator should be able to provide you with this. because it varies. i.e you can set it to whatever you want if you have access to the wireless router. in your case Belkin 54g Wireless DSL/Cable Router
so please if you have access to it, log in to the router and check from wireless security settings.
Regards
May 20, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I a using cable net and not the dsl line.the net on my pc is working but when i try to connect ps3 wirelessly it show 100% signal from belkin but the internet connection fails.i have tried different...
check the wireless settings of the router .
Make sure that you are typing the correct network key if your network is secured.
May be you will need to open the ports on the router.
Click Here for more information
Jan 04, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
How do I put security on my Belkin 54g router
You set your security by enabling WEP.
When you get in the interface to configure WEP, set a pass phrase. Write down the 3 numeric keys it generates. Then connect to the wireless using your laptop, etc. When it asks for your passkey, do not enter the pass-phrase; enter one of the three keys that were generated by the router. That's the biggest mistake people make when trying to get wireless to work.
Oct 06, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Wont connect to belkin 54g with wpa security applied
Please try using Wireless 'G' mode only in the router. Also, try using 'TKIP' and not TKIP+AES for encryption.
Please rate this solution, if it works for you.
Jun 01, 2009 | Dell Inspiron 6400 Notebook
I secured my wireless network but have forgotten the password
hey what you can do is you can reset the entire router... by using the reset button on your belkin router... Or else you can also access the router by using the following IP address in the internet exlorer...
try 192.168.1.1 or 192.168.1.0 & then go to the wep settings & reset the router or change the password for the router...
Jan 17, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin 54 encryption
1. Log into your Wireless Router or Access Point.
Open your web browser and type in the IP address of the Wireless
Router or Access Point. (The Router’s default is 192.168.2.1, the
Access Point’s default is 192.168.2.254.) Log into your Router by
clicking on the “Login” button in the top, right-hand corner of the
screen. You will be asked to enter your password. If you never set
a password, leave the password field blank and click “Submit”.
Click the “Wireless” tab on the left of your screen. Select
the “Encryption” or “Security” tab to get to the security
settings page.
2. Select “128-bit WEP” from the drop-down menu.
3. After selecting your WEP encryption mode, you can type in
your hex WEP key manually, or you can type in a passphrase
in the “Passphrase” field and click “Generate” to create a WEP
key from the passphrase. Click “Apply Changes” to finish. You
must now set all of your clients to match these settings. A hex
(hexadecimal) key is a combination of numbers and letters from
A—F and 0—9. For 128-bit WEP, you need to enter 26 hex keys.
For example:
C3 03 0F AF 4B B2 C3 D4 4B C3 D4 E7 E4 = 128-bit key
4. Click “Apply Changes” to finish. Encryption in the Wireless
Router is now set. Each of your computers on your wireless
network will now need to be configured with the same
security settings.
May 09, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Network security
Once you've logged into the router (open your browser, and type ONLY this into the Address line, without the quotes: "192.168.2.1). You should get a log in pop-up, "admin" is the username, and the password is left blank (or is sometimes "password"), again without the quotes.
Once logged in, you have a series of menus on the left hand side, Usually large blue lines demark each section, i.e. "Lan Setup", "Internet WAN", and of course the section you are looking for "Wireless". Under each header is listed each of the pages available for that function. For example, under Wireless you'd want the first 2 items: "Channel and SSID" - this is where you set the name of the wireless network; and "Security", which is where you setup whichever one of the Encryption options you want. This Encryption key is the password you will use when connecting wirelessly to the router from a PC.
Hopefully that is enough to get you setup.
Feb 20, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D5231-4) Router Logo
97 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
