Hi!! I got this compressorfit just 6 months ago & would have not got it run even 50 hours run. As per the workshop, It has leakage & can't hold the gas now. Kindly suggest if there is a way out to get it repaired/replaced as i can'tafford to get again a new compressor put. Regards Shantanu
  • 40 Answers
The system need to be charged with nitrogen to determine where the leak is
then repair the leak and recharge
Posted on Apr 05, 2011
How much power does a
Since 2011 the FTC has required that every TV display a yellow and black Energy Guide label estimating how much it costs to run for a year. The label assumes a price for electricity (11 cents/kWh) and a baseline usage (5 hours per day).
The cost is tiny. A typical label can read anywhere from $6 for 32-inch LEDs to $38 for 65-inch plasmas (PDF). Per year. That's from 50 cents to $3.18 per month.
Aug 15, 2014 | Televison & Video
How do I charge the battery on a 1990 xlh sportster 1200
The voltmeter test provides general indicator of battery condition. Check the voltage of the battery to verify that it is in a 100 per cent fully charged condition. If the open circuit or disconnected voltage reading is below 12.6 V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8 V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE and STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC is 100 per cent
12.6 VDC is 75 per cent
12.3 VDC is 50 per cent
12.0 VDC is 25 per cent
11.8 VDC is 0 per cent
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
Battery Charging Rates/Times (Approximate)
FOR A 19 AMP HOUR DYNA AGM BATTERY
BATTERY STATE OF CHARGE is 12.8 VDC is 100 per cent Charge; Rate of Charge is N/A
BATTERY STATE OF CHARGE is 12.6 VDC is 75 per cent Charge; Rate of Charge at 3 AMP is 1.75 hours at 6 AMP is 50 minutes at 10 AMP is 30 minutes at 20 AMP is 15 minutes
BATTERY STATE OF CHARGE is 12.3 VDC is 50 per cent Charge; Rate of Charge at 3 AMP is 3.5 hours at 6 AMP is 1.75 hours at 10 AMP is 1 hour at 20 AMP is 30 minutes
BATTERY STATE OF CHARGE is 12.0 VDC is 25 per cent Charge; Rate of Charge at 3 AMP is 5 hours at 6 AMP is 2.5 hours at 10 AMP is 1.5 hours at 20 AMP is 45 minutes
BATTERY STATE OF CHARGE is 11.8 VDC is 0 per cent Charge; Rate of Charge at 3 AMP is 6 hours, 40 minutes at 6 AMP is 3 hours, 20 minutes at 10 AMP is 2 hours at 20 AMP is 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance free batteries is not recommended. Any overcharge will cause dry out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F or 43 degrees C during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
Hi the clock is set for 60 Hertz, What about countrys with 50 Hertz in voltaje?
50 Hz means the electric generator rotates 50 times per second.
And then electricity oscillates or reverses polarity 50 times per second.
Products rated for 60 Hz will not operate correctly with 50 Hz power.
Feb 16, 2014 | Coralife Power Center DayNight Timer or...
Power consumption pool motor
Look at your amps and multiply by volts. This will give you watts.
ex.motor label 115V/14.4A 230V/7.2A
Whether you are running on 115v or 230v you get 1,656 watts.
This converts to 1.656 KW (kilowatts)
Your power company charges you by the KW hour. I'll use
12 cents per kilowatt hour for example.
$0.12 x 1.656 = .1987
This rounds off to 20 cents per hour to run, so if you run the pump 6 hour a day,180 hours per month, the electrical cost would be
about $36 per month.
Jan 09, 2013 | Pool & Spa
1110 SECURITY CODE
hi if you forget the security code try default codes like 0000 or 1234 to reset your mobile .if it didnt help you to reset then visit onlinegsmunlock.com here they provide master reset codes for some nokia and alcatel mobile models.
Jul 15, 2012 | Cell Phones
Meter to kilometer
There are 1000 meters in a kilometer and 3600 seconds in an hour (60 seconds per minute, 60 minutes per hour).
Press 8 0 0 / 5 0 * 3 6 0 0 / 1 0 0 0 =
or 8 0 0 / 1 0 0 0 * 3 6 0 0 / 5 0 =
The result should be 57.6 kph.
Nov 11, 2011 | Casio FX-115ES Scientific Calculator
Hello! I have a vulcan 800 classic 1998. I bought it some days ago. It was sleeping for 6 months in the garage and the guy told me that I have to run it in order for the motor to breathe. I run on the...
well of corse its true. its like sticking ur hand flat into the wind when ur driving ur car. its all wind resistence. if u were to somehow lean the windguard back about 6 to 7 degrees it would make a wind bubble over you which would make it easier for ur bike to flow into the wind. more or less like drafting. hope this helped
Mar 29, 2011 | 1998 kawasaki VN 800 Vulcan Classic
Have misfire, code P0316, any ideals? 86,000 miles on
2004 Marauder and 2003-2004 Mustang vehicles built before 12/19/2004 equipped with 4.6L 4V/5.4 4V engine may exhibit a runs rough, lacks power, and engine misfire, prompted by a MIL light and DTC codes P0301, P0302, P0303, P0304, P0305, P0306, P0307, P0308, and P0316.
ACTION
Diagnose engine for engine misfire concern. If diagnostics determine an engine misfire which is characterized by leakage through exhaust valve(s), only replace the affected cylinder head(s).
SERVICE PROCEDURE FOR VEHICLES WITH RUNS ROUGH/MISFIRE CONDITION:
1. Perform relative compression check on all cylinders. If abnormal, check cylinder leakage and actual compression for "low" cylinders refer to Workshop Manual (WSM), Section 303-00.
2. If leakage/compression check indicates a valve train concern, per valve train diagnostics in WSM, Section 303-00, replace cylinder head and cam assembly, pipe plugs and timing chain tensioner, per procedure outlined in WSM, Section 303-01.
3. If cylinder leakage and compression tests are inconclusive, perform misfire diagnostic, per TSB 05-22-8.
So
Feb 26, 2011 | 2004 Ford Freestar
I can use it for child?
u can use it for child..
dosage depends on age of ur child.
advil syrups are availabl which yo may find easier to give to ur child.
Children 6 months to 12 years: 5-10 mg/kg of ibuprofen every 6-8 hours for the treatment of fever and pain.
The maximum dose is 40 mg/kg daily.
Juvenile arthritis is treated with 20 to 40 mg/kg/day in 3-4 divided doses.
Nov 21, 2010 | Advil , 2 Tablets Per Pack, 50 Packs Per...
6) If two lights of capacity 80W replaced by 20W, which run for 6 hours per day. What will be energy savings per month (30 days) in KW/hr?
For the 80W bulbs you'll be using 2 x 80 x 6 x 30 = 28800 W/hr = 28.8kW/hr.
For the 20W bulbs, it's 2 x 40 x 6 x 30 = 7200 W/hr =7.2 kW/hr.
The monthly saving is 21.6 kW/hrs, a saving of 75%.
Sep 04, 2010 | Office Equipment & Supplies
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
