Question about Samsung LNT3242H Television
Melody option under setup is greyed out not allowing me to turn melody off when tv is turned on - help!!
3 Suggested Answers
  • 317 Answers
SOURCE: closed caption
maybe in cable box setup?
Posted on Aug 03, 2008
SOURCE: LG LCD TV Model 42LB5D. The closed caption option is greyed out. Help please.
redrover 11-13-2007, 01:03 PM Well I stumbled onto the solution to my problem, finally, but no thanks to any of the tech at my cable
Posted on Feb 21, 2009
I have a sharp aquos tv, model LC-42D62U, and had a sound bar attached that worked great. When I remove the soundbar I can’t get the TV sound to turn on. I have trouble shot a lot of things. The problem...
I do not have sharp manuals to reference - in general the TV sound - Variable vs Fixed just allows the set to control the volume output (variable) or Fixed will produce one level of output and your device (soundbar) volume control would adjust up or down from there. There is usually another location in the menu that allows you to turn off the TV speakers so they do not operate at the same time as your soundbar or other device. It should be simply Speaker ON / OFF. If you can locate this - you should be able to select it. If it is all greyed out - that means the TV believes based on the connections / setting / input selection - those cannot be changed. (you may try connecting the device and see if the greyed out menu items turn back white or are selectable. Sorry I don't have a specific answer - hope this helps
Dec 21, 2017 | Sharp Televison & Video
Tip
Turning off the Melody sound on a Samsung Television.
You have a Samsung television and you want to turn it on at night, and not wake up your house, or you are annoyed by the sound that the television makes when you turn the set on and off. Samsung incorporated a feature into the set that will play a melody to let you know that the set is either turning on or off, whichever the case may be.
If you want to turn off the melody you can follow the instructions below and that should take care of the annoying sound that is bugging you.
You may have a Samsung television and you remember when it had a melody when you turned it on and off and now that is gone. Well this tip can help you too. The same menu selection will allow you to enable the melody that is missing, and you can bring it back.
You can change the setting on your Samsung Television by selecting “Menu” then “Settings” and arrow down to “Melody”. There are four options; Off, Low, Medium, High. I personally would not select the high setting as it is very loud on my set. I guess if you have someone in your house that sneaks the television on and you want the loud melody to play, this could be a way of knowing when the set comes on. I hope that this helps you with your television issues and as always, Thank you for using FixYa.
I hope that you enjoy your television for years to come.
asnowman
on Mar 16, 2010 | Televison & Video
How to activate all inputs on samsung tv
read your manual,you need to give us more info for more help
May 09, 2015 | Samsung Televison & Video
How do I turn off the starting sound on a Samsung series 7 tv?
On your Samsung remote. Press the MENU button. At the botttom of your screen you have the setup selections. Scroll over to the SOUND option and select that, A menu should appear and toward the bottom of the menu you should see MELODY. Scroll down to that and select ON or OFF...
Nov 02, 2014 | Samsung UN50ES6500 Series 7 LED 3D 1080p...
How to turn off music when turning on tv
Yes it is possible. You should be able to set the melody to off, low, medium or high
I believe you can get to the setting by doing this:
  • Press the MENU button to display the on-screen menu.
  • Press the up or down button to select "Setup", then press the ENTER button.
  • Select "Melody" by pressing the up or down button, then press the ENTER button.
  • Select the setting you want (Off) by pressing the up or down button
    repeatedly.
  • Press the ENTER button.
  • Press the EXIT button to exit.
You can find the manual here: http://downloadcenter.samsung.com/content/UM/200804/20080401185600828_BN68-01507A-01Eng-0328.pdf
Page 24/25 is where it talks about the Melody setting.
Sep 10, 2014 | Samsung LA22A450 22 in. LCD TV
Got a Samsung 50" tv and we cnt turn the melody
No way to defeat this stupid feature--it is controlled by the microprocessor in the set---unlike a door open chime in a car you cannot disconnect the sound.
Dec 09, 2012 | Televison & Video
The store demo mode is stuck on my insignia tv. the user guide says go to menu and then setup and select plug & play. however the plug and play option is grey and it wont let me select it.
Are you using an HDMI cable? Go to input and select TV. Then you should be able to access the Plug & Play option and be able to turn off the Demo Mode.
Jan 03, 2011 | Insignia 42" Flat-Panel Plasma HDTV
How do I turn off the on / off melody on the 42 in samsung LCD tv?
Usually melody turn On-Off option is available in Settings menu of tv, let me know model number of your tv to provide you more detailed info about how to turn Off melody sound on start up and shut down.
Thanks.
Nov 07, 2010 | Samsung HCN4226W 42" Rear Projection...
How do i turn chime off when you turn tv on?
go into your tv menu probably under setup for audio you will find a reference to "melody" turning that to off should do the trick.
Jan 21, 2010 | Samsung LN-S3251D 32 in. LCD HDTV
Closed caption
May 27, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
114 people viewed this question
Jerry Greenberg
Jerry Greenberg
