Question about Sony DAV-DZ170 Theater System
I hooked everything up, speakers played the instruments right, and surround works for dvds. I have the optical audio cable going from the dvd player to my bravia tv. Why won't the surround work for my satellite or my gaming systems? Thanks for your help.
    Brigadier General:
  • 8,546 Answers
To each source a digital input must be assigned.
Posted on Mar 28, 2011
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
Xbox360 not hooking up to Curtis DVD5091 surround sound through optical cable
try running the optical cable from your dvd directly to your tv and then select whichever input (eg HDMI 1/2 etc) you use to play the xbox on..In theory this setup should allow any audio playing on the tv to go through the surround sound..hope it works
Feb 11, 2013 | Curtis DVD5091 Theater System
No surround sound from Kenwood VR-5090
please select the 5.1 option in the audio menu of the reciever.
Jan 10, 2010 | Kenwood VR-5090 5.1 Channels Receiver
How to connect dvd player to AV reciever
S-Video is a media type that only carries video. Unfortunately the LG unit was designed only to be a self contained surround sound unit. There are only video outputs to the television on this unit. Because of the unit having surround sound capabilities, LG felt that their wasn't a need for audio output. You would need to buy a new DVD player to allow audio from the DVD to your new Yamaha unit. Good Luck!
Jan 22, 2009 | Audio Players & Recorders
Surround sound works for dvds but not tv
Use an optical audio cable for your tv audio out.
Jan 01, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
No sound out of surround back speakers
It sounds like you don't have your surround sound source set up properly (your DVD player is not set up for PCM sound).
the best quality audio will be to set up either digital or optical audio between the DVD and the receiver.
Once you have connected the optical or digital audio cable between the DVD and receiver, you have to go into the DVD player audio setup and change it to PCM digital audio or you will not get surround sound. DVD players are not set up by default to output surround sound.
Sep 05, 2008 | Yamaha RX-Z9 Receiver
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
RCA RT2280 surround sound mode button wont select 5.1 dolby digital mode.
I had the same problem and this is what I did to fix it. Assuming that all of your equipment is powered on, (tv, blu-ray/dvd, rca receiver) you'll need to go into your dvd players audio menu and select the dolby digital audio.
Once you do this, the digital signal is sent to your receiver from the dvd. The receiver should automatically set itself to the dolby digital preset. If it doesn't, press the surround button until you reach it. I found part of this information here. And the rest was personal experience.
Also, it depends on if the disc format is in dolby 5.1. I hope this helps you.
Dec 18, 2007 | RCA RT2280 System
Yamaha HTR 5740 no surround sound with DVD
i have the htr 5230 and i had the same prob ... are you using fiber optic ??? try the effects like pro logic. or 5.1
Sep 23, 2007 | Audio Players & Recorders
Sony DAV-DZ170 Theater System Logo
146 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
