Question about Samsung RB1955 Bottom Freezer Refrigerator
Samsung RB1944SL bottom freezer. Noticed that contents didn't appear to be as cold as normal in refrigerator and ice cream was soft in freezer, along with other items. Door mounted temp readings seemed normal ~ 2 deg F freezer and 36 deg F refridgerator. Unplgged the unit for 10 sec and plugged back in and the tem readings then read 50+ in fridge and 30+ in freezer - plus the compressor came on and cooled the unit down eventually. Later, looked at the temp readings and again they looked normal. I had put a thermometer in the fridge in a cup of water and it was reading about 10 deg higher than the digital door reading of 2 and 36 and the compressor was not running. Unplugged for 10 sec and replugged and the temp readings on the door went to 11 and 46 and the compressor came on and cooled everything down. Same cycle keeps repeating. It seems that once colled down to set temperature, the brain locks up and needs to be reset.by unplug/replug cycle. Spent most of 2 days fooling with it and can't reliably continue to babysit this thing.
3 Suggested Answers
  • 16 Answers
SOURCE: My refrigerator is too cold
sounds like you have a defective temparture sensor
Posted on Apr 07, 2009
bugoy31
  • 1238 Answers
SOURCE: None of the recommended solutions appear to be
Good day!!!!
When working properly, the thermostat turns the compressor on and off. Once the thermostat turns the compressor on, it will run until the temperature inside the refrigerator is lower than the setting of the thermostat. Make sure that the refrigerator has enough air clearance on all sides. Refrigerators with a condenser coil grid on the back of them need room to radiate the heat away from the coils.
Verify that the door light switch is working properly. Push the switch with your finger to verify the light is turning off. If the light stays on, it will actually warn the interior of the refrigerator. Fix or replace the switch if it is faulty.
Modern refrigerators that have a lot of storage and large freezer compartments run for longer periods of time. They also start and stop very frequently to maintain an even temperature. This is especially true if you have just put a lot of warm food in the refrigerator, or if it is very hot and humid. It can take several hours to get back to the cool temperature you have it set for after putting a large amount of food in it.
If the compressor is not shutting off when the temperature inside the refrigerator is cold enough, you may have a bad thermostat. You may also have the temperature set too high in the refrigerator. Try adjusting the thermostat to a lower temperature. If this turns the compressor off, you had it set too high. With the help of a refrigerator thermometer, you can find a more ideal setting that will keep your food cold, but not so cold that the compressor is always running. If raising the temperature setting doesn't help, it may be a problem with the thermostat and you will need to replace it.
If your thermostat is working properly, there's a chance that you have low levels of refrigerant in the sealed system. If this is where the symptoms lead you, you need to contact a professional appliance repair person. Only an EPA certified technician can legally work on a sealed system. If you attempt to do work on this system, you will void the warranty.
If this is a new refrigerator, it will run for a long time, almost constantly, before it gets cooled enough to stabilize the interior temperature. Allow up to 24 hours for it to stabilize. The refrigerator should be at least one half to two thirds full. This will help to maintain a stable temperature inside the unit. The cold items inside will help to keep an even temperature inside after the door has been opened and closed. Some people prefer to keep a lot of stuff in the refrigerator as ballast, even jugs of water. This helps to maintain temperatures inside so that when the door gets opened and closed often, it doesn't need to run as much to maintain the temperature inside.
I hope this information will be helpful...
Thanks for using fixya....
Posted on Aug 13, 2011
Ice block
There is some cooling in the freezer which is allowing the temp to raise above freezing for a brief period. Check gaskets and or the temp setting. Is ice cream hard or soft. Ice cream freezes at around 15-18 degrees. My guess is that the door gasket is allowing air inside the box.
Feb 03, 2013 | Samsung RF265AA Bottom Freezer French Door...
Kitchen Aid bottom freezer KBRS22KK is frosting up
Replace the "defrost thermostat" located on the coils in the freezer. Here is the part to order.
Dec 01, 2012 | KitchenAid KBRP20EMSS Bottom Freezer...
Ice Cream In Freezer Is Soft
DON'T BY ICE CREAM! LOL Try putting ur ice cream somewere else
Oct 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice cream soft
Ice Cream is the hardest thing to freeze in a fridge /freezer unit , you need a least 0 deg F
to harden ice cream. If the ice cream was satisfactory before the repair and the stat is set to max. it is possible you have an over charger refrigeration circuit.
Fuji
Aug 06, 2009 | Sub-Zero Bottom Freezer Refrigerator
Freezer seems as if it is not cold enough
Your sensor is packed in ice and giving false reading (always frozen)
You NEED to defrost. Will take 2hr
Turn off or Pull plug on freezer
Take everything out and put in cooler, brown bags, large bin or boxes to stay cold
Defrost by setting large pail of boiling water in each side bottom of freezer and closing door(s) for 1/2hr
Open freezer, empty pails in sink and use pails to hold large chunks of ice from freezer that will come out easily
Toss out ice chunks
Check sensor to be sure it is no longer packed in ice
Wipe down interior dry
close doors
plug in
wait 1/2hr
reload with stuff you want to keep
Done!
Mar 26, 2009 | Refrigerators
Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Sep 18, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Freezer not cold enough
How is the other products in the freezer. Some ice cream doesn't get too hard and it is because of the ingridients. I can't remember now, think it is the sugar content. If your ice cubes are solid you should be ok.
Sgt 48
Jun 02, 2008 | LG LDN22735 Stainless Steel Bottom Freezer...
Samsung RB1955 Bottom Freezer Refrigerator Logo
105 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
