Question about IMTiger Software Supertintin Recorder For Skype
Tryin to record a group video on skype using supertintin. both audios record, but only my video (and not the other person's video) records? what's wrong and how do i fix it?
My chrystaleye webcam wont work with skype
SKYPE VIDEO PROBLEM
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video. If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam Also check the Audio Settings for the Microphone THEN click on Save. Avoid connecting the WEBcam to an USB hub. SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphone driver not installed or not working OR the microphone is not configured in Skype.
To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.
Sep 03, 2012 | Acer Aspire 5500 5570-2609 Laptop
Using medion md 96340 with built-in realtek hd audio sound card. in skype video calls the caller can hear very well but called person does not hear at all. skype echo test says-cannot find sound...
Analysis- The call can gear very well - indicates that the speakers / head phones are working fine and the audio drivers are working well
The called person doesnt hear any thing - it indicates that the caller is not able to transmit sound. This can be a microphone related issue. It can also be skype settings issue.
Please answer following questions to analyze the issue better
1. has this ever worked before?
2. Have you tried using the microphone for some other application like recording some audio?
3. Have you tried audio / video calls using some other chat program like gtalk?
4. Are u using any external microphone attached to a head set or is it the laptops inbuilt microphone?
-IAmAraldite
Aug 18, 2011 | Medion MD 96340 Laptop
While using Skype, the person I am talking to can't hear me. It says I need to install a soundcard. What is the solution?
If the person cannot hear you then, either your mic driver not installed or not working OR the mic is not configured in Skype.
To test your mic go to Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the mic need to be configured in Skype.
Normal 0 To configure the mic - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.
Oct 23, 2010 | Computers & Internet
Skype video using Acer Aspire Mini Laptop camera?
If you have a WEB camera you need to configure your video Webcam settings. Open Skype click on Tools - Options - Video Settings - select your Webcam model. When you open Skype click on Tools - Options - Audio Settings and click on Microphone and select the microphone you are using and save the setting.
If you still have problems with your mic. then - To test if the microphone is working, go to Start - Programs - Accessories - Entertainment - Sound Recorder and record you voice. Can you see your voice recording, the green line should vary as you speek.
If you see a flat green line, then the microphone is either faulty or the wrong microphone is selected.
Jun 15, 2009 | Acer Aspire One AOA150-1949 Laptop
Need to do an interview, recorded in video, so I can post on my blog.
Skype and gotomeeting are the best I use them for podcasting all the time. Skype works good too those other dont work as good. So my advice would be skype
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 18, 2009 | Skype IM
Can u record the audio of a Skype Call?
Hi Mike,
Here are a few options for you (I have not tested them, pls let me know how they work, reviews were not so bad on them):
Record Skype conversations with Skype Recorder!
http://www.extralabs.net/skype-recorder.htm
PowerGramo skype recorder is a perfect skype recording solution. With it you can easily record skype calls of any kind.
http://www.powergramo.com/
Mp3 My Mp3
May 08, 2009 | Skype IM
Logitech cam microphone cuts out on skype
Normal 0 Normal 0 Go to "TOOLS", click on "OPTIONS," Then go to "Audio Settings" and click on it. Make sure both the Microphone and Speaker's are correctly chosen. Then "make a free test call." Wait till the voice tells you to record. Then when finished talking wait for the test persons voice to insure your audio transmission is working. Then go back to options and test your video settings. Click on Video Settings and proceed to set up you video camera. Also, you can visit this site for additional information to setup video.
http://www.skype.com/help/guides/video/
Hope this helps. Bud
Jan 28, 2009 | Logitech Quickcam Chat Webcam
Using Skype with the Logitech Qickcam E1000
Jan 26, 2009 | Logitech QuickCam Communicate STX Personal...
Skype will not recognise my headset. Using Windows XP and Plantronics headset. Audio and speakers work ok.
Normal 0 After you install Skype and have it operational with your ID. Go to "TOOLS", click on "OPTIONS," Then go to "Audio Settings" and click on it. Make sure both the Microphone and Speaker's are correctly chosen. Then "make a free test call." Wait till the voice tells you to record. Then when finished talking wait for the test persons voice to insure your audio transmission is working. Then go back to options and test your video settings. Click on Video Settings and proceed to set up you video camera. Also, you can visit this site for additional information to setup video.
Jan 01, 2009 | Computers & Internet
Sound problem
Oct 10, 2008 | Logitech Quickcam Chat Webcam
Computers & Internet Logo
21 people viewed this question
Top IMTiger Software Computers & Internet Experts
David Payne
David Payne
Are you an IMTiger Software Computer and Internet Expert? Answer questions, earn points and help others
