I dropped my viewsonic g tablet and cracked the screen. The unit works fine operationally and the touchscreen works. The screen is cracked. How can I get a screen to replace or get the screen replace?
  • davidbaroody Mar 28, 2011
    I have looked on Ebay. There are numerous complete units, but no screen. Do you have another solution?
    Brigadier General:
  • 8,909 Answers
I expect you will be able to find a replacement screen on ebay.
Posted on Mar 28, 2011
  • davidbaroody Mar 29, 2011
I have a lg v495 tablet the screen is cracked and was just fine working now the touch part of screen stop working its on and the only part that the touchscreen works is the bottom how can I make the...
Hello, Thomas -
I am afraid you will need to have the cracked screen replaced and checked for any internal damage to the device and have that repaired, if necessary. There are probably several businesses in your area which can evaluate the damage and give you an estimate of the repair cost.
To find repair businesses in your area, I recommend you use Yelp.com (because it also offers reviews of businesses). You will want to enter the words "computer repair" in the Find box and enter the name of your location in the Near box.
Also, you can use YellowPages.com to find a computer repair business near you.
Note: You will probably have to pay an initial charge for a technician to make an evaluation.
Dec 19, 2017 | LG Tablets & eReaders
Why does my touch screen not work on my viewsonic viewpad 10pro?
at this point, i would recommend to try to perform factory reset to see if only software problem, not HW. You should be able to reset the device by locating little reset hole and pressing it down for 10s, using so sharp object.
May 31, 2014 | VIEWSONIC DISPLAYS Viewsonic Viewpad 10pro...
Zeepad locked
Hello
This is a common problem with cracked screens, the digitizer breaks, which is the component that makes the device touchscreen. I might be wrong, but that seems to be the case.
Mar 18, 2014 | ZEEPAD VIA8650 Android 2.3 Tablet
My v touch pro touch screen wont work
b> The Touch Pro2, manufactured by HTC, is a smartphone designed to be used with the Verizon wireless phone network. This smartphone combines a cell phone, PDA, MP3 player and wireless Internet access into a small, portable device. If the device begins malfunctioning or freezing, you can perform a soft reset. A soft reset does not delete any of your saved information. It shuts the phone down and reboots the phone to the Verizon Today Welcome Screen.
Pull the stylus upward to remove it from the side of the phone. Push the back cover upward using your thumbs until it pops from the back of the Touch Pro2 phone. The back cover can then be lifted away and removed from the phone. Press the "Reset" button, on the upper, left side of the back panel using the stylus tip. The device will now restart and display the Verizon Today screen. Snap the back cover back onto the back of the phone. Touch Screen is Not Working
As most tablet PCs ,Phones and Mp3 players are full touchscreen devices, you use your touchscreen for everything you need to do on your Tablet PC. If the touchscreen stops working, you can't get much use out of your Tablet. Touchscreen issues are caused by hardware or software problems, but check with your manufacturer before attempting a DIY repair.
Hardware Issues Damages to the surface of your Tablet PC can cause the touchscreen to malfunction or stop working entirely. For example, putting pressure on the screen, such as placing the Tablet PC in a bag with other heavy items, can cause cracking along the screen. Exposing the screen to water, even in small amounts, can cause the electrical system within the touchscreen to malfunction. If the electrical system malfunctions, the touchscreen stops working properly. b> Screen Sensitivity b> Pressing the touchscreen on your Tablet PC sends a signal to the internal motherboard. The motherboard then transmits to other components, such as the hard drive. The accuracy of the touchscreen depends on the screen's sensitivity. Many Tablet PCs include a program for calibrating the touchscreen. This program may fix minor responsive issues. Even a small amount of dirt or debris can effect how the touchscreen responds. Cleaning your touchscreen with an electronics cleaner or a microfiber cloth may help improve sensitivity. b> Software Issues b> A driver is a software program that interacts between hardware devices and an operating system, Your Tablet PC needs the right drivers for your OS to work correctly. Outdated or missing drivers can cause the touchscreen to work improperly, or not respond at all. Visit the manufacturer's website to find the right drivers for your Tablet PC. b> Repair b> While you can perform some minor repairs yourself, such as re-calibrating the touchscreen sensitivity or installing drivers, only perform a hardware repair if you have a good working knowledge of electronics, specifically Tablet PCs. Before attempting to repair your device, contact your manufacturer. If your Tablet PC has a warranty, completing an unauthorized repair may make you ineligible for claiming that warranty. Hope this helps
b>
Jan 20, 2013 | Visual Land V-Touch Pro (8 GB) MP3 Player
Touch screen broken on viewpad
Only way is to get it serviced. Replacing a screen like that is complicated and annoying, you also would need to order a panel and digitizer replacement if that is damaged too.
Nov 02, 2012 | ViewSonic Tablet Notebook PC VPAD7 Viewpad...
Dropped a Kyros tablet and cracked touchscreen,can it be fixed?
What is the extent of the damage? Size of crack, apparent depth, shape, and location on the tablet?
Jun 07, 2012 | Coby Kyros Android Tablet
Broke the touchscreen (LCD is perfect) unit works otherwise
nope
when support is dropped its dropped any unused units or parts end up in the recycle bins or auctions
keep searching internet for a used unit for sale
or put wanted ads in free online sites for one
Mar 04, 2017 | ViewSonic Airpanel V150 15" LCD Monitor
Televison & Video Logo
444 people viewed this question
Top Televison & Video Experts
