Question about Price Pfister R89-7PC0 Chrome Portland Single Handle Pressure Balanced Show
I need a replacement cartridge # 17196-0100k for a single handle price pfiser shower valve. where can i order one?
I have a single handle price pfister shower valve Model 17196-0100k .No cold water.It's coming hot on both sides.
Posted on Aug 10, 2011
I found the new replacement cartridge number to be 974-042 for the old 17196-0100k. I obtained the info from Price Pfister there Ph number 1-800-732-8238.Apparently some of there faucets maybe all! have a lifetime warranty, all I had to pay for was shipping.
jzhjr
Posted on Mar 23, 2012
I have been strugling with water flow after replacing a single handle tub and shower cartridge. I have no flo. They have pex plumbing. the shower has not been used for a while and at the time they were...
look inside the valve with a flashlight and make sure a rubber peice of the cartridge did not plug the cold side this cartridge needs hot and cold water to function it has a built in balancer that prevents scalding also make sure its not shut down at a manabloc system in the mechanical room if this helped you please feedback vote thanks
Aug 27, 2011 | Moen & Posi-Temp Single Handle Shower Or...
My single moen posi temp shower knob wil not completely turn off my water. In the closed position it still runs a slow stream of water.
Remove the handle and see if it will turn off without the handle and if it will reposition the handle alignment and your good to go. If no the cartridge will need to be replaced.
Feb 12, 2011 | Moen & Posi-Temp Single Handle Shower Or...
When i turn it on it is only warm at best. when i turn it all the way hot the water comes out in a trickle. all our other showers and sinks get hot water just fine. this is a single handle shower and does...
You will need to remove the old cartridge from inside the shower valve body and either refurbish it with new rubber seals and O rings or replace the cartridge altogether (preferable). It's not a complicated fix but the Posi Temp cartridge can be a bear to remove. Moen and Danco make special 'pullers' to make the cartridge removal go a little easier (sold at Lowes/HD and plumbing supply for anywhere between $15 and $35 but well worth it, IMO).
Oct 27, 2010 | Moen & Posi-Temp Single Handle Shower Or...
I have an 11 year old, single handle shower control that when turned off has dripping. I have taken off the handle, etc and am at the wall. What is the next step or steps?
After you remove the chrome collar and plastic collar washer (behind the faucet handle), pry the beauty plate off the wall. Turn off the house main water supply. Remove the four screws and washer holding the cartridge and valve stem in place. Save the metal washer under the four screws for use with the new cartridge. Replace the stem/cartridge assembly and secure with the saved metal washer and four screws. Reinstall beauty plate, collar & collar washer, then handle.
Dec 21, 2009 | Price Pfister R89-7PC0 Chrome Portland...
The shower head is leaking. I disassembled the
You need to pull and replace the cartridge on your shower valve most likely. It varies by Make and Model, but generally, remove the handle, remove any sleeve around the center spine, remove the round trim plate, close the service stops, remove the retaining clip or ring, and pull the cartridge straight out of the valve body by pulling on the spline... or get a cartridge puller. Then take your cartridge to the store and get a new one. Flush the valve body by slightly opening both service stops and then install the new cartridge and reverse the process.
Generally this problem occurs when sediment has torn part of the sealing o ring on the cartridge. If you send me the make/model and/or a picture I will give you the specific instructions
Oct 11, 2009 | Delta & Single Handle Shower Faucet
The single handle fauchet will not stop running water.
Replace cartridge and insure that the C clip is not missing.
Sep 11, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Need a shower valve replacement cartridge
I found the cartridge at globeunion [nooutgoing@email.com], 888-328-2383. They told me they are shipping the cartridge to me today at no cost ("lifetime warranty") and they immediately emailed a part diagram of the whole Fontaine NF-VCTST-BNV-TSRVH Single Handle Pressure Balanced Tub and Shower Trim and Valve with Rain Showerhead (from the Monaco Series).
Larry
Jan 29, 2009 | Fontaine NF-VCTST-BNV-TSRVH Brushed Nickel...
Single handle moen bath fixture only lets out hot water
remove the cartridge and see if their is anything blocking the cold inlet.If you dont see any dirt than that means that the cartridge needs to be replaced
Jan 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen single handle valve tub/shower
The Moen Posi-Temp Valve is a pressure balanced valve and when not used for long periods of time they can stick causing only cold or hot water to pass through the valve.
A New Posi-temp cartridges can be purchased at most plumbing supply houses or big box outlets such as Lowes or Home Depot.
As long as you had cold water before, a new cartridge will solve the problem. In the future it would be wise to occassionally operate the valve at least a couple of times a month in order to keep the pressure assembly from becoming lodged in position. Just follow the instructions included with the new cartridge on the proper removal of the old cartridge and the installation of the new cartridge. a little silicone grease inside of the valve before installing the new cartridge will also help.
Be sure that there is no particles of the old cartridge left in the valve.
sanray
Dec 27, 2008 | Moen & Posi-Temp Single Handle Shower Or...
Price Pfister R89-7PC0 Chrome Portland Single Handle Pressure Balanced Show Logo
3,444 people viewed this question
Top Price Pfister Home Experts
Mike
Tim Whalen
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
