Question about Samsung DV218AG Gas Dryer
The drum stopped spinning on our Samsung DV218AG. Less than a year old. Suspect drum belt broke. Does the dryer have the belt in the rear or bottom? What type of belt is needed?
  • Samsung Master
  • 2,605 Answers
Welcome to FixYa.
Yes it does have a belt. I'd say your assessment is almost bang on, based on your description and my experience. I've seen this many, many times...though the belt usually doesn't break it just comes off. Very common for Samsung dryers for whatever reason.
**Unplug the unit before proceeding...safety first**...
The good news is if it's accessible from the back you can simply remove the small panel around the exhaust tube as shown here,
if it's not you'll need to go from the front...do-able just a little more involved, let me know.
Once in the back the belt should look like this when routed properly, with the "V" grooves towards the drum and motor pulley.
i.e.
Hope that moves you forward...or even better, to the finish line, lol.
Let me know what you find. If this is something you think is not within' your scope of expertise please call a pro.
I will try to help in any manner I can of course as well. Good luck.
Regards,
Macmarkus :)
Posted on Mar 28, 2011
  • beefkayk2410 Apr 12, 2011
    Macmarkus,
    You are the man! I googled how to fix a broken belt and stumbled upon your response above and low and behold it was just sitting there and I was able to fix the belt that fell off and saved myself some cash. Thank you for your detailed post, i greatly appreciate it!
    Jesse
  • Benjamin Nov 26, 2011
    Perfect Fix! Thanks for saving us some extra $$. It turns out that the coil and belt were off on ours, so the picture above really helped.
I own a Samsung dryer model DV218AEB/XAA. In both the sensor and timed cycles it shuts off early and goes dead for about 30 minutes before it comes back to life and the load can be restarted, only to
I have a good idea that it may be the following;
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
You can check out other possibilities and order parts here using the following link;
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/2---/Dryer-stops-turning-during-cycle
Good Luck!
Rich Lilja
Oct 29, 2014 | Samsung DV218AEB/XAA 7.3-CuFt Electric...
The drop has broke
Check your owners manual, or call samsung. These dryer drums, if stainless are usually warrantied for multiple years or lifetime as listed in your manual. Consumer to pay all other charges like other parts, trip charge, and labor if over 1 year old. The stainless drums frequently split on the seams. Pleazer Appliance...
Apr 06, 2014 | Samsung DV218AE Electric Dryers
Samsung dryer DV4015J turns on and motor sounds like its working but the drum does NOT turn so clothes do not dry, they just sit in dryer container?
If this is the older type, then the dryer drum is rotated by a thin loop belt that goes around the drum and then a pulley on the motor. I had to replace my 20 year old dryer belt on a Whirlpool a couple years ago. The front comes off and the belt slips over the drum. The front of the Whirlpool is held on by friction clips that have to be pried off with a flat blade. I suspect that you can do the same. look on the internet for a diagram of your dryer or you may have one in the manual that came with the machine.
Sep 19, 2010 | Samsung Dryers
Have a Samsung gas dryer-DV812agv. Has power, turns on but the drum does not turn. Just bought this darn thing having a lot of trouble from Samsung to get it fixed!!!
Can you hear the motor running upon turning it on? If so the belt is off of the drum. If no noise is hear from the motor check the wiring to it especially the ground wires. You can have a faulty switch which is the one you push to turn on. All items must be check starting with the easiest first
Apr 03, 2010 | Samsung DV218AG Gas Dryer
Dryer heats but drum does not turn when the start button is pushe
You need to check the drum belt. With dryer empty, reach in and give it a spin. If the belt is good, it will stop in 1/2 turn or less when released. If the belt broke, it will spin almost a full turn.
Oct 25, 2009 | Kenmore 62602 Electric Dryer
Electrolux FGX831FS1 dryer drum, only spins one way manually
Check inside the drum to make sure the three screws in a triangle in the rear center are all there, if they fall out the drum goes off center and the motor can no longer drive it.
This model has no rollers, the front of the drum has plastic glides mounted on the front of the drum that ride on teflon impregnated pads that are glued around the door.
The rear is supported by a steel ball screwed to the rear of the drum (the 3 screws that I think are causing your troubles) that rides in a plastic saddle screwed to the rear of the machine.
If the excess drum movement is only up and down you should replace the front glide system.
Good Luck
Quentin
Apr 26, 2009 | Frigidaire FEX831CS Top Load Stacked...
The dryer is humming but not spinning when i removed the top cover i see the belt in the middle of the drum. Do you know where it supposed to go?
is belt disconnected? Is belt broken? Will dryer rotate manually? if so ,
I suspect that the belt broke. order a new belt Home depot has a good parts service or try other local appliance places. You will have to disconnect power first, Remove front panel to access drum Dont forget to unplug door switch there should be a plug front top right, in the rear on the bottom there is a motor and an idler/tensioner. install the new belt and under tensioner Yes the path will seem awkward and re assemble. Also now is the time to vacuum lint out
Dec 30, 2008 | Roper RGX4634KQ Gas Dryer
Whirlpool Dryer wont spin
If it heats but doesnt spin, most likely the belt. May not be broke though. May have fallen off. Let me know if you need more help.
Dec 16, 2008 | Whirlpool LEQ9858P Electric Dryer
Samsung DV218AG Gas Dryer Logo
462 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
