Question about Dryers
My dryer stopped heating. It runs but only with cold air. I have replaced the heating element, I bought the kit and replaced the high and low sensor....I took out the thermostat and "jumped" the wires and the dryer will run but still no heat.....????? HELP!!!
  • 96 Answers
Sounds like the operating thermostat mounted next to the thermal fuse on the exhaust duct,asuming this is a whirlpool dryer
Posted on Mar 29, 2011
Samsung Dryer dv203aes/xac will not heat. Drum is rotating and lint was cleared from exhaust.
Check the following:
1. Does it have 220 volts (yes it runs, but dryers run on 110 volts)?
2. Check the heating element and the safety thermostats located on the heat element canister. Low air flow from any restriction like lint build up or mashed ducting or blocked air exhaust vent cap can either trip the safety stats or burn out the element. Clean dryer and exhaust ducting thoroughly and replace bad parts before placing back in service. Poor air flow is the number one problem with "No Heat" dryer issues.
Sep 20, 2016 | Samsung Dryers
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
Blowing cold air
Unplug the unit. Using a ohm meter you need to check of the heating element is good or not. Reading across it you should see very low resistance. If you don't it may be "open" or a thermal interrupt has stuck open preventing current flowing through it. Check your high and low limit switches (sensors) for closed circuit (low resistance). If one reads high or open that one needs to be replaced.
Feb 27, 2014 | EuroTech EDV158 Electric Dryer
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
Two problems with Whirlpool Dryer
I would suspect the heating element. I bet you are asking why this clown is saying that when you already told him that on high heat it worked fine. SIMPLE! Your heating element is made up of five coils. For low heat your dryer uses two heating elements and for high all five. So if one or two of the heating elements are open and they happen to be the low temp dry setting ones, that would explain it. That model doesn't have the dryness sensor on it (according to my documentation) so the heating element is the most likely cause.
Hope this helps!
ImJustAvg aka Hal
Dec 30, 2011 | Whirlpool Dryers
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
My kenmore dryer is blowing only cold air. What is wroge? We already checked the heating element and timer...???? This dryer is only 4 years old.
The heating circuit is composed not only by the heating element and the timer but also with a high-limit thermostat, a thermal cut-off, and a cycling thermostat. The high-limit thermostat and the thermal cut-off are both mounted on the heater housing to monitor and regulate the heater temperature while the cycling thermostat is mounted on the blower housing to monitor and regulate the temperature of the exhaust air.
All of these components are wired in series and a failure in any of them results in the dryer not heating. The proper troubleshooting is by checking the continuity of each of these components with a volt-ohmmeter and replacing the ones found without continuity (open).
A continuity check can also be done by bypassing each of the three components, never the heating element, and then starting the dryer. The dryer should heat, otherwise the problem is somewhere in the timer, the heating element, or the centrifugal switch within the motor. When the dryer heats up, unplug it then un-bypass one of the bypassed components and start the dryer. If the dryer stops heating then you have found the failed component; replace it. If the dryer does not stop heating, do the same to the remaining components until you find the failed one. Just make sure the dryer is unplugged before touching the components.
Replace both the high-limit thermostat and the thermal cut-off if any of them has failed. Indicate the exact model number of the dryer if you need further or more specific advice.
Jun 12, 2010 | Kenmore 63942 Dryer
Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Jul 10, 2009 | Amana ALE643RB Electric Dryer
There is only cold air in my kenmore elect dryer
The motor runs on 120VAC. The heating element requires 208/240VAC. Cycle the dryer circuit breaker. Other than a simple issue like that, the problem could be a bad heating element, thermostat, high limit control, thermal fuse, motor centrifugal switch, timer or electronic control. It can also be a wiring issue.
Apr 27, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
Top Dryers Experts
