Question about Kelvinator KBM5100MB
Kelvinator fridge freezer, fridge too cold frosting at back
  • 32 Answers
Fridges that are less then 10 years old have a lot of POWER. To get rid of the frost, wait until you have eaten most of the food up (maybe a few days), then unplug the fridge and leave the doors open. This will take care of the frost after several hours.
From then on, make sure that when your fridge is full, use a higher setting, and when it is near empty or half way full, use a lower setting. Keeping the freezer at a mid to low setting all the time should be fine, because its usually the fridge part that gives people trouble.You will have to judge on your own which setting is best (i.e you can tell when its good based on how cold the juice is in there, etc).
By adjusting the setting based on the amount of food in your fridge, it should prevent frosting.
Hope that helps!
Posted on Mar 28, 2011
  • choralsam Mar 29, 2011
    Thank you... but don't know whether 1 or 6 on internal dial is the coldest.
  • John John Mar 29, 2011
    6 is likely the coldest, 1 is the warmest. We have keep ours at 1.5 most times...3 when the fridge is packed full.
5 Suggested Answers
aasc
  • 1606 Answers
SOURCE: I have GE side by side fridge. The freezer built
Pull refrig out from the wall and unplug . Remove the 8" x 10 " panel covering the main control board . On this board , unplug the blue plug with 3 larger wires going to it . The sequence looks like this : wire1,wire2,space,wire3 . Use a piece of wire , with both ends stripped about 1/4 " , and insert an end into wire2 and wire3 . Plug refrig back in . Look inside the freezer at the back bottom , and see if you see a red glow . It may take about 30 seconds for the glow to appear . If no glow appears , the defrost heater located at the bottom of the coils ( glass tube ) is probably shorted . Pt # WR51X10042 . Also replace the defrost thermostat Pt # WR50X10068 . To access these parts , the inside freezer panel has to be removed . If you do get a red glow , then the main control board is bad Pt # WR55X10656 .
Posted on Sep 04, 2009
Testimonial: "Thank you very much for this imformation it saved me $75.00 which right now I really don't have. Unforntunately the board is bad. Thank You again"
mgprice
  • 744 Answers
SOURCE: Freezer frosty and fridge warm.
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using fixya! Mike
Posted on Oct 09, 2009
heatman101
  • 43501 Answers
SOURCE: my hotpoint fridge freezer doesn't
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 31, 2010
  • 1196 Answers
SOURCE: I have a Kelvinator 2
he reasons the air is not moving is usually two reasons
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it's own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
  2. The timer device
  3. The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
Posted on Feb 26, 2011
Kelvinator Cyclic 330 not getting cold enough
Empty the refigerator and freezer, unplug it for about 8 hours, leave freezer door open so it will completely defrost. Plug it back in for 4 hours and close doors before you fill it back up with food. If you have a thermometer, check the interior temperatures before you fill it back up. Refigerator should be around 42 degrees F.
Mar 19, 2014 | Refrigerators
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
Kelvinator fridge compressor running constantly, but freezer section barely freezing
CHECK THE CONDENSER COILS UNDER THE UNIT. THEY PROBABLY ARE DIRTY AND CANT REJECT THE HEAT.
Oct 18, 2012 | Kelvinator Refrigerators
I have a kelvernator fridge/ freezer and woke up this morning to find the freezer part still working but not the fridge part, why do u think this is ?
The most common cause of that is a malfunction of the automatic defrost system. Do you see a bunch of frost on back wall of freezer? if yes it's not defrosting or perhaps the fan in the freezer that circulates air into fresh food compartment has failed,no frost build up if it's the fan, do you hear the fan?
Gene
Jul 30, 2011 | Kelvinator Refrigerators
Kelvinator no frost KBNT23AS back plate in the freezing compartment is icing up but the ice trays are not freezing. The lower compartment is not getting cool enough.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 05, 2011 | Frigidaire Freezers
Old Kelvinator Cyclic 340. Freezer is Ice cold
Read the below :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 16, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Fridge not getting cold
unplug unit to "reset." pull unit out from wall and blow the coils out on the back of refrigerator. if that does not work- call service man to come check freon level.
Aug 09, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Fridge & freezer no longer cold
if you only removed the ice you can see without removing the back panel then you need more defrost time yes. but the frost will come back, something in the defrost system has failed. so the answer is yes to both questions off for longer and something more serious too.
Apr 06, 2008 | Freezers
Kelvinator KBM5100MB Logo
657 people viewed this question
Top Kelvinator Refrigerators Experts
Charles T Nevin
Charles T Nevin
Melissa Martin
Melissa Martin
Are you a Kelvinator Refrigerator Expert? Answer questions, earn points and help others
