Question about Frigidaire FRS26R4A Side by Side Refrigerator
I have a frigidare refrigerator side by side,profissional series, 2 door, model # PLHS269ZDB2. suddenly only the bottom halves in both fridge and freezer working only not the upper parts in both sides (fridge and freezer). i feel the coldness only at the bottoms not at the top of both sides.
SOURCE: HELP!
check 4 build up of frost on the coils if frosty take a hair dryer n defrost then plug back in, either your defrost timer,heating element or condenser!
Posted on Sep 24, 2007
  • 213 Answers
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Posted on Nov 29, 2007
SOURCE: Frigidaire Side-By-Side Top Not Cooling
sounds like its froze up. the coil is in the back of the freezer and blows into the freezer via a fan then cold air is carried to the fridge via another fan. more than likely condensation due to weather conditions has built up on your coil and has froze up or your fridge fan has stopped working. unplug fridge for a day to let thaw, if this doesnt work check you air distribution fan in top.
as for the lights not working in the freezer the switch is on the left hand side of freezer wall under ice holding tank sometimes water from thawing ice get on it and it wont come out all the way, take a blow dryer to it to thaw and dry it out.
Posted on Feb 17, 2008
  • 1314 Answers
SOURCE: Frigidare side by side FRS202RG freezer cold, fridge side warm (coils frozen)
your having a defrost promblem either the adc-auto defrost control board is bad or the defrost termination thermostat is bad or the heater is bad thats rare but does happen if you will open the refridgerator door and get me the model number off the serial plate on the toop of the compartment just look up when you open the door then let me see if it has an adc or timer i can reply and be more spefic about fixing your promblem hold my rating till we are done ok
Posted on Mar 30, 2008
  • 29 Answers
SOURCE: refrigerator and freezer not working good
drip tray usually located at bottom of fridge at rear.sounds like defrost timer is no good,some models can be manually manipulated its located at bottom front panel or at back of fridge,if this is the case defrosting the fridge results in operation o.k. for a short period then gradually dying again
Posted on Aug 13, 2008
Freezer ices up and fridge part warm, timer changed worked well for 2 weeks model frt 163ag no frost fridge
Hello Claire Trancoso - If the refrigeration side is the one with the issue, you need to check the damper door/switch that is between both doors. In side by side units this damper controls the cool air from the freezer to come over to the refrigeration side to cool it. Contact a professional technician to diagnose if the unit has a floating restriction, an issue with the evaporator fan or a possible air leak.
Dec 17, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
My frigidare refrigerator has a freezer on top but the fridge door has dropped it is a newer frigidare how do I fix
The bottom hinge needs slackening off, lift the edge of the door in place and retighten the hinge screws; if it's not that loose, a sharp tap with the heel of your hand may bring it back into line
Apr 24, 2012 | Frigidaire Refrigerators
ITS A NEW FRIGIDARE IT WILL NOT COLD TO FREEZE
Possibly stuck on defrost... locate the defrost timer and turn the timer dial... the fridge should come on.... but you still need to replace the timer
Jul 19, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
My GE Profile PS123SGPA BS side by side keeps dripping water from the water dipenser
Frigidare Model FRS26H5AS Side by side HELP!!!
Water collects and freezes in the bottom of my Freezer eventually leaking out the freezer door.
Thank you!!! bstrickmaker@neo.rr.com
Feb 15, 2010 | Frigidaire FRS26H5AS Side by Side...
I have a kenmore top freezer refrigerator model 253 about 1 1/2 years old. The fridge door sticks at the bottom of the door and the bottom of the fridge inside. There are scratches on the fridge bottom...
i had the problem my self :)
you need to take the freezer door out then the fridg door and add small ring like 1mm to the hinges of the fridg door poot all back and see if it rais the door a bit....
what i did is on the top of the freezer there is option to move the door from side to side ...the plastic that go into the freezer body its a ring with long tube.. i cut the tube and use that plastic :) good luck
Jan 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Fridge door suddenly won't close
Your refrigerator may not be level side-to-side and front-to-back
Jan 05, 2018 | General Electric GDL22KCWSS Stainless...
How to replace the door seal on a frigidare upright freezer
most fridge door seals are attached to the door by screws. If you flap the seal up from the bottom you should see some screws. if you go to the site below it gives your guidance on replacing the seals on fridges, as all fridge seals are pretty generic you should find it useful
http://www.wikihow.com/Replace-a-Refrigerator-Door-Seal
I hope this helps
Dec 08, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Refrigerator and freezer not working good
Aug 11, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Mar 30, 2008 | Frigidaire FRS26ZSG
Frigidaire FRS26R4A Side by Side Refrigerator Logo
50 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
