Question about Dewalt D55275 8 Hp Gas - Powered 17 - Gallon Wheeled Portable Compressor
Honda engine shuts off instead of unloading & going to idle, when compressor reaches operating pressure.
    Champion:
  • 299 Answers
Check oil level has auto shut off if low.
Posted on Mar 28, 2011
  • mchill482 Mar 28, 2011
    Not the engine problem. Its the shutoff system on the compressor.
I have a LeRoy older model pull-behind air compressor. When it starts up it low idles but shuts off before it builds pressure. I have all the valves open I have low in pressure but the motor keeps dying. I...
I'm not familiar with that model air compressor, I'm assuming this is a rotary screw driven by a gas or Diesel engine? If the inlet valve is open & the air compressor is attempting to compress air while the engine is starting up, it can be too large of a load for the engine to continue running. I would be checking to make sure I followed all the steps of the mfg start up procedure. If you had a reciprocating air compressor driven by an electric motor and the check valve or unloader valve fails and there is air pressure coming backwards thru the piping against the valves, the actual compressor itself becomes too hard for the electric motor to turn over. The amp draw is so large it causes the breaker to trip. In your case you probably don't have any back pressure coming from other machines making it hard to start but if the inlet valve on the air end is open it could have the same effect. If there is zero pressure in the machine and you start the engine. Everything is going to rotate. The inlet valve for the compressor has to be shut somehow to prevent the compressor from compressing air. If it's open, air will be drawn into the air end, the more the engine runs the more the air end will compress the air. As the internal pressure rises, the air end becomes harder and harder to turn which causes the engine to strain. That's a complete shot in the dark. There are many ways air compressors are controlled. There are many types of air compressors. It could be a problem with the engine itself. The bottom line is that you need to be able to know the air compressor is unloaded and not trying to compress air. If it is unloaded the engine should start up and run.
Dec 16, 2017 | Air Tools & Compressors
When max pressure reached engine dies instead of idle down
Has Pressure Switch Issues - About Air Compressors
www.about-air-compressors.com/has-pressure-switch-issues.html
Many times folks think that they have a pressure switch problem since air leaks out the ... The pressure switch does not kick off when the compressor has reached itsmaximum pressure. ... compressor sits humming and trying to turn the motor insteadof cutting out. It is a ... I have an old, about 20 year old, Ingersoll-rand T21.Missing: idle
[PDF]21 Front St. - Celtic Distributors Ltd
www.celticdistributors.com/content/Celtic/.../BasicCompressorTraining.p...
The air compressor motor and/or engine will get hot while in operation. .... enters thru the intake ?lter and the intake valve on the down stroke of the piston. .... My gas unit builds pressure but instead of idling the engine dies? 0 Check ... most single stage compressors only reach maximum pressure of 125 to 135 PSI. A slight.
[PDF]ALTRONIC GAS ENGINE GOVERNOR OPERATING ...
www.altronicinc.com/pdf/engine-controls/govinstall.pdf
Dec 16, 2015 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Ingersoll Rand 3 hp air compressor builds correct pressuse but trips rest when called to restart. Changed starter and running capasitors but no change in problem.
You need to check the head unloader.
Compressed air that is trapped over the piston when the compressor shuts off will be evacuated to atmosphere through the unloader valve, to prevent that compressed air pressure from adding load to the start up of the compressor motor, when the pressure switch again calls for air. For example, the last time you did a sit-up, you may have folded your arms over your chest, or if you are particularly masochistic : - ) , even held a weight to your chest. What you were doing is increasing the load against which your muscles have to work to effect the sit up.
Compressed air, captured in the cylinder after the compressor shuts off, would increase the load against which the electric motor would have to work. It may increase the load too much, and the motor may fail to start, or it may pull too many amps and fry a fuse or pop a breaker in the panel.
When the compressor shuts off, the unloader valve operates, it unloads the trapped air to atmosphere, and that problem is solved.
The unloader valve is plumbed somewhere in the line between the compressor and the compressor tank.
It is often part of the pressure switch assembly. It will, in many cases, be opened by the pressure switch, when the air in the compressor air tank reaches the set point and the pressure switch trips the power supply to the motor off, and at the same time, trips the unloader valve to open.
it is normaly on the bottom of the pressure switch it will have a small tube hooked to it
Jan 04, 2012 | Air Tools & Compressors
Compressor builds correct pressure but will trip rest before it can restart.
Compressor won't restart when pressure gets low. How do I fix it?
The unloader is designed to release the pressure in the discharge tube after the unit reaches set pressure. The unloader is usually located within the pressure switch and is enabled with a small lever opening a valve (some look like tire stem). You can verify if it is working by cycling compressor and listening for release of air after unit reaches set pressure. Some compressors do not have a built-in unloader relying instead on loose fitting parts to bleed out air. On these units, air leaking back from the intank checkvalve will cause problem of loaded/backpressure and the motor cannot overcome. Easy to verify if checkvalve is leaking; with pressure in tank remove the discharge tube at the checkvalve and spray soapy water. Clean or replace this valve as needed. Good luck
Apr 20, 2011 | Campbell Hausfeld Air Tools & Compressors
I HAVE A 4 HP GAS COLEMAN POWERMATE COMPRESSOR. THE COMPRESSOR KEEPS RUNNING AND WONT SHUT THE PRESSURE OFF UNTIL THE BLOWOUT VALVE BLOWS.THIS COMPRESSOR HAS A HONDA 4 HP GAS ENGINE ON IT.THE PRESSURE IS...
Coleman PowerMate CT4090410 Operator Parts Manual
This unit uses an loader valve to control pressure, it will unload compressor and idle engine back until the pressure falls below 95 psig and the speeds engine up and loads compressor until cutout pressure is reached. I've linked to manual and the unloader is
Coleman PowerMate CT4090410 Operator Parts Manual Page 18
The item number is 9 and part number is 070-0056.. This part is around $100-$110. Ive repaired this type part on air compressors used on mechanics service trucks ., Depending on your skill level and access to tools and parts, it might be better to purchase a new one.g take time ti read to read and understand manual. Good luck
Nov 10, 2017 | Coleman Air Tools & Compressors
I HAVE A TECUMSEH 10 HP ON AN AIR COMPRESSOR IT STARTS, BUILDS AIR PRESSURE THEN IT SHUTS OFF INSTEAD OF GOING TO LOW IDLE
try to decrease regulator, maybe you ask to much power and it shuts of. specially with cold motor its important to ask less pressure.
Jan 24, 2010 | Honda Jenny GT8HGB-8P2 8hp 8 Gallon GX...
MY TECUMSEH 10 HP ON A PRO AIR 30 GALLON AIR COMPRESSOR BUILDS UP AIR THEN IT SHUTS OFF INSTEAD OF GOING TO LOW IDLE
the pilot valve or control valve when it unloads sends a air signal to close the motor throttle down to idle and depending on what form of control it uses for the compressor it will either use head unloaders to hold open the inlet valves or a unloader that dumps the compressor output to atmosphere, this one uses a silencer mounted near the pilot valve. if it uses this type remove the silencer and retest the operation. either you have a motor that is out of adjustment or the compressor is not unloading!
Jan 24, 2010 | Air Tools & Compressors
Gas Engine shuts down after maxium air pressor is reached
hi yor problem seems to be that your machine is running too high a pressure,try adjusting your unloader valve so that your pressure is no more than 120psi , if that fails then check and replace your non return valve
please let me know how you get on best of look
Mar 24, 2009 | Honda Air Tools & Compressors
Gas air compressor shuts down
IS IT BUILDING TO THE UNLOAD PRESSURE AND THEN STALLING OR JUST SHUTTING DOWN ANYTIME. IS THE UNIT SITTING AT AN ANGLE?
DOES IT WORK FINE WITH THE LOW OIL SWITCH UNPLUGGED? UNPLUG SWITCH AND LEAVE IT UNPLUGGED FOREVER.THEY'RE ALL P.O.S.
Feb 14, 2009 | Hitachi EC2510E 5.5hp Gas Air Compressor
Dewalt D55275 8 Hp Gas - Powered 17 - Gallon Wheeled Portable Compressor Logo
181 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
