Question about Parasound 5250 5-Channel Amplifier
I have a parasound 5250 5 channel amp. Channel one is not working. Is there a fuse?
  • 89 Answers
Hi, there is no fuse on amplifier output only power supply, the problem is some parts of electronic that drives into audio output of the amplifier maybe are shorted like transistors, diode or amplifier Ic's. bring it to a nearest service center to check it. or if you have a knowledge in technical yo can used multi tester to check it. Note: unplugged it first before you open the cover to check it. thanks
Posted on Apr 28, 2011
My parasound 2205a 5 channel smells like cat urine it lights up front window says normal but no sound from speakers what blew when cat urine in top
******? E****d? Maybe unplug, take cover off; and check for p**s tracks. Then go brush the cats hair the wrong direction.
Nov 02, 2014 | Audio Players & Recorders
How to fix 2 fuses on the left of the amp? the right side work well.
Fuses only blow if there is an overload somewhere. The most likely cause being a transitor that has shorted out. Easy to spot with a multi-meter on the ohms setting. As it will be liked you have touched the test leads together!
Aug 21, 2012 | Parasound HCA-1000A 2-Channel Amplifier
Amplifier wont turn on. the orange ac light is on but nothing else
Check internal AC fuse. If intact, amplifier may be in protect mode due to fault.
Oct 27, 2011 | Parasound HCA-1000A 2-Channel Amplifier
Parasound A51 have two channels out. The blue indicators in from of the amp did not turn on. The other three have blue lights when power is engaged. I opened the cover and measure each independent channel...
Whatever does the work in those channels has gone open circuit. This would not cause a fuse to blow, so power would be still present. I suspect it is the main amp chip(s) or transistor(s), which will be found on a heat sink.
Jan 07, 2018 | Parasound A 51 Amplifier
I have an overload indicator on channel 2. I opened the lid and swapped the channel 2 module with the channel 5 module and the overload light followed the card and showed up on channel 5. Parasound said...
I believe that the output transistors may be bad. Without seeing the actual card, there is no way to tell. If the parts are under warranty, request a replacement board. If I remember correctly, the board is the field replaceable unit (smallest orderable part) anyway. If not, you will need instruction from Parasound about what to do next.
Dan
Sep 03, 2010 | Parasound HCA-2205AT 5-Channel Amplifier
Bryston 4b amp, left channel blows the back panel
I would check out whatever drives the left channel first. If it is a transistor, you can put a ohm meter on the terminals and see if it shows a short (amp turned off). If there are two transistors for the left channel, and you find a short on one only, replace the other to be on the safe side.
Mar 16, 2009 | Bryston 4B SST 2-Channel Amplifier
The amp is only putting out on 1 channel
I do believe this is caused by one of your amp fuses. Depending on which + on the amp is being used. That channel has a blown fuse. have you tried running + and -, + and - to both channels to see if both subs worked? If one sub doesn't then it's a blown fuse or scarred fuse and needs to be changed.
Feb 10, 2009 | Kenwood Excelon KAC-X521 Car Audio...
Noisy transformer
Normally, power transformers don't hum loudly unless there is a problem in power supply circuit. If all seems normally operational, the problem may be simply anchor screws that hold transformer to frame may be loose. Try tightening them
Apr 29, 2008 | Parasound HCA-855A 5-Channel Amplifier
Parasound 5250 5-Channel Amplifier Logo
269 people viewed this question
Top Parasound Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Gil Shultz
Are you a Parasound Audio Player and Recorder Expert? Answer questions, earn points and help others
