Question about Samsung Remote Control
Having problems pairing the remote for Samsung un55D8000. Followed directions but continue to get pairing failure.
Make sure to hold the remote near the bottom right of the tv. There is a red LED and an IR receiver there. The remote needs to be pointed at this area and within 6 inches of the tv to pair the Bluetooth. Samsung doesn't mention this anywhere and I almost returned the tv before the salesman told me about this.
Posted on Apr 19, 2011
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
I'm having a continued pairing failure with remote on ud55d7000 Samsung. I even tried put it close as on person had suggested but all I get is failure
I had the same problem. The following worked for me and the 46d7000 qwerty remote. Try this: unplug TV. Then press power button until the red led turns off (5 sec or so). One themed is off, plug in tv and power on and try the pairing again.
May 15, 2011 | Samsung Remote Control
Having a problem getting my samsung touch remote for 55c9000 tv, to watch tv on my remote it keeps saying that there are no tvs found? when i try and connect to my tv can someone help me solve this issue,...
I don't have a solution but just checking if you have set up your remote as an "extended distance wifi remote" as described in the manual. I have been trying to set mine up and when I follow the instructions to pair the remote to the TV I get a message on the TV screen to "Allow" or "Deny" access. Problem is I do not know how to select "Allow" as the remote is unavailable to use as it is part of the pairing process. I can highlight "Allow" by using the volume button on the TV but don't know what button to press to enter my selection.
Nov 22, 2010 | Samsung TV Remote Control
Direct TV remote quits working - conflict with Samsung LCD?
Turned power saving feature on the TV to low and moved the receiver about four feet away from the TV and the remotes work fine now.
Sep 03, 2009 | Samsung TV Remote Control
Hughes box wont power on.
Sorry it took so long to reply to your request for help.This Direct TV box has had a component failure. You will need to call Direct TV and have them replace the box. You can call Direct TV Customer Support at this telephone number 1-888-667-7463. Tell them that you are having a problem with Direct TV box and need a replacement. I hope this information help you solve your problem with the Direct TV box failure. Thank you for using FixYa and have a nice day!
Oct 21, 2008 | RCA DIRECTV Satellite Remote Control
Samung wep200 to my samsung instinct
http://www.alternativewireless.com/samsung/Samsung-WEP200G-quickstart.pdf
Make sure you do as it says on the pairing section. i was having the same problem (no devices found) until i followed as it said on #2, when wep200 is off press the multi-function key until the blue light comes on solid approximately 8 secs. I have a samsung instinct and it read just fine after that.
Aug 18, 2008 | Samsung WEP200 Headset
Samsung HT-Q100 - Changed Battery on TV remote control
Just try to clean your remote,this the common problem of dirty contacts of remote it plays a certain unit but to the other won't play.Just open it take a toothbrush with an alcohol brush the remote control board,and dry it for 1minute and close it back then check if working..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 17, 2008 | Samsung HT-Q100 System
Samsung Remote Control Logo
1,962 people viewed this question
Jerry Greenberg
Jerry Greenberg
