Question about Brother MFC-820cw All-In-One InkJet Printer
Hi, my brother printer keep showing Machine error 46 unable to clean. Thanks
  • 1,218 Answers
Machine Error 46 - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An "initial purge", for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Get more help and information click here . hope this helps you.
Thanks
Michel
Posted on Apr 04, 2011
    Sergeant:
  • 192 Answers
Disconnect the machine from the power for several minutes, then reconnect it. (The machine can be turned off for approximately 24 hours without losing faxes stored in the memory. If the machine will be off longer than 24 hours, you can transfer faxes to another fax machine or you can save the faxes in your PC.
Found on page 101 of the manual at the link below.
Brother Printer
Hope this solves your issue.
Posted on Mar 28, 2011
I have a brother's MCF-255MC printer and i keep getting the message unable to clean 50 I followed the steps in the manual and it still didnt work could you please help me?
How do I clear the message "Unable to..." or "... Unable" ? ' Brother
support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod...eu_as...
Aug 18, 2014 - Unable to Clean (Clean Unable); Unable to Init. ... If the encoder gets markings or debris on its surface, it may cause other problems.
Brother Unable to Clean 50 Error - YouTube
? 0:51
https://www.youtube.com/watch?v=8THfCUgYCMU Jun 9, 2015 - Uploaded by Aceh Com
Printer Brother Unable to Clean 50 Error Cara mengindentifikasi Printer Brother Unable to Clean 50 ...
Clear the "Unable to Clean" Message ' Brother MFCJ4510DW ...
? 1:49
https://www.youtube.com/watch?v=EH3CEA3WbEY
Aug 2, 2013 - Uploaded by Brother Office
Yeah, keep it ... Clear the "Unable to Clean" Message ' Brother MFCJ4510DW, ... assistance, please ...
Printer is displaying unable to print/init/clean 50. Have referred
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting Get a Professional Answer ... Have referred to brother manual and there is nothing jammed in the machine. ... To attempt to resolve it, do the following steps created by Brother in this step by step guide to try resolving the error message: ... Unable to init, unable to print, unable to clean, unable 36, error 46, 50 and error 32 are ...
I am getting error:unable to clean 50, was unable to print - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting I am getting error:unable to clean 50, was unable to print - Answered by a ... What is the exact model of your Brother printer? ... For example, MFC-615 ... it is not allowing me to press any thing, I keep getting a beeping noise when I press .... How do I remove error messages, epson wf-2750, PC MS10, I 8/12/2017 8/12/2017.
brother MCF 255MC printer message unable to clean 50 Google Search
Aug 14, 2017 | The Office Equipment & Supplies
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Error 46 and says unable to clean. can u help me plz
According to the manual, the unable to clean error means a mechanical problem or a foreign object in the machine: Open the scanner cover and remove
any foreign obstacles inside the
machine. If the error message
continues, disconnect the machine
from the power source for several
minutes then reconnect it.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002010/BH3eDCPWLAN_UkEngUsr.pdf
Apr 24, 2009 | Brother DCP-340CW All-In-One InkJet...
Clean unable 46
Hi, check to see if there is any foreign object jamming the print mechanism, check all drive belts. If this doesn't show nup any problems, I'm afraid that you have a failure that will require dis-assembly and repair by a company who deals in these printers.
Apr 12, 2009 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Mar 24, 2009 | Brother DCP-330C All-In-One InkJet Printer
DCP-330C All in one
Hi. I had unable to print and unable to init 46 error. Any help available to reset my machine please. Thank you
Jul 27, 2008 | Brother DCP-110C All-In-One InkJet Printer
My printer have problem
you need a new waist ink absorber box.
Search this forum for error 46 or unable to clean. the procedure is explained many times (identical for all brother inkjets)
Apr 17, 2008 | Brother DCP 115C All-In-One InkJet Printer
Error 46 Unable to Init.
No need for part necessarily
SkipperOz solution pasted below
MFC-5440CN saved from the tip!
"Unable to Clean" message - found TrickyDicky's sltn 4 for various printers.
Went into maint mode as per sltn 4 - verified error 46.
"The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed."
Keyed in 80 - stepped through the items with "down" key and located Purge Counter.
"Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero
Press the 9 key twice to return to the standby state."
This worked brilliantly - no need to tamper with any parts of the printer. Purge Counter reset did it all. Fully functional printer.
Thanks TrickyDicky for info on verifying the error code and purge reset
Apr 03, 2008 | Brother MFC-5440CN All-In-One InkJet...
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
Jan 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother MFC-820cw All-In-One InkJet Printer Logo
353 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
