Question about Acer Aspire 4520-5582 Notebook
Turbo c++ not working
Hi! turbo c++ software is not working properly in my acer aspire 4520 laptop.the screen becomes blank or off whenever i try to open turbo c++.after that the windows task manager opens and then i can write my program.the same problem occurs when i try to see the output of my program.
  • 9 Answers
You could try right-clicking the executable, then select properties. Go to the compatibility-tab and select 'windows 95'.
Posted on Aug 04, 2008
Hi mine is Acer Aspire 4520. I was playing movie from a DVD yesterday all fine. I left it inside the drive. Today I found that my DVD Ram device has gone bad; it's showing all empty space in whatever...
Can you suggest which OS you are using?
Does this problem exist for all the CDs/DVDs?
Try to insert bootable CD and try boot from it and check if it works.
You can try blank cd and just write it using NERO and check.
May 11, 2011 | Acer Aspire 4520-5582 Notebook
I have acer aspire 4520. Whenever i turned on the laptop, the screen will go blank. The power button is still on which means that it wasn't the motherboard problem. Sometimes, the screen turn on but after...
before you change the screen, try to plug the laptop into a monitor or any flat screen tv. are you able to view the image on the tv? if so, your screen is broken.if not, there is something wrong with your laptop and you may want to consider a system restore.
Feb 28, 2011 | Acer Aspire 4520-5582 Notebook
My Acer make Laptop model: aspire 4520 not power on , power led and dvd led flashes at the same time and screen blank.
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced
Sep 11, 2010 | Acer Aspire 4520-5582 Notebook
I hace Acer aspire 4520. Suddenly the screen went blank. I tried to start the laptop but never starts. The power is available, battery is working and power button is illumination. Please advise what to do?
try to re-seating the memory card(s) located on back, clean it if necessary. If it has two cards, try one to another probably one of them is out of order
Apr 09, 2010 | Acer Aspire 4520-5803 Laptop
ACER LAPTOP NOT STARTING
Try to reinstall windows overwriting the previous installation so that all your data, files and programs will not be deleted. If you have your windows installation cd, insert it to the cd/dvd drive and start/restart your laptop. It then detects the installer and scans your computer. Just follow the on-screen instructions. But during setup, do not choose the "Repair Mode" instead choose "New Install". Now when attempting to install, then system will detect your previous windows installation so there highlight (using the arrow keys) choose "Repair Previous Installation". When you do this, all windows system files will be replaced but all programs and personal files will be in tact.
Dec 29, 2009 | Acer Aspire 4520-5141 Notebook
No display in Acer aspire 4520g laptop
Have your laptop check up the technician, it has somethingt to do with your video card
Nov 05, 2009 | Acer Aspire 4520-5582 Notebook
When i'm online, my computer screen flickers then goes blank with a white screen. The computer is still running the screen just goes blank. how can i solve this problem? and sometimes when i turn on the...
Your computer is infected with spywares.You need to scan your computer for spywares from a good antispywares software like Malware byte, SuperAntispyware etc.
Jul 11, 2009 | Acer Aspire 4520-5141 Notebook
Acer ASPIRE 4520-5141 AMD TK-57 1.9G 1GB 120GB · blank screen
OOPS.... OK.... it may be serious but it may also be easily solved. If what i tell you now doesnt work then the laptop is KAPUT.
Remove the battery... then remove the hard drive and the memory chips. You should find all these under latches at the bottom of the laptop .... the hard drive sometimes pulls out from the side somewhere.
ALSO TRY ANOTHER POWER SUPPLY because youyrs may be faulty. TRY ANOTHER POWER SUPPLY FIRST OF ALL !!
Once you've done that you must put it all FIRMLY BACK... If that DOESNT work you may have a DEAD computer.
Jul 08, 2009 | Acer ASPIRE 4520-5141 AMD TK-57 1.9G 1GB...
Acer Aspire 4520-5582 Notebook Logo
163 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
