Question about Acer X233Hbd 23 inch LCD Monitor
I've been using my monitor for quite some time & all of it sudden it doesn't work. When I boot up my computer (XP) the Windows screen does show on the monitor then it tell me "NO Connection"
  • Acer Master
  • 6,771 Answers
If the monitor is coming on with no connection, check the video cable connection from the computer to the monitor, "sub the cord if possible" hook a spare monitor to the computer to verify the computer is working properly, because I think the monitor is okay, If it were bad your screen would remain blank regardless.
Posted on Mar 28, 2011
My Zoostorm Desktop won't boot and show up on the monitor. Help?
No signal just means the video card isn't putting out any signal. If you don't even see BIOS then replace the power supply first. Still doesn't work then it's probably the motherboard.
Jan 01, 2013 | Computers & Internet
Asus a8n-e m/b gets power, will not post
Hello from here you can download a manual and drivers:
http://www.asus.com/Motherboards/AMD_Socket_939/A8NE/#download
My guees is that the windows disk is damaged or burned to fast.
Since you not get any picture on screen now the graphic card. maybe malfunctioning try to change that and see what happens.
A ps2 keyboard and mouse must be used.
Because the usb function will not work until the system is fully installed.
A restore disk does not contains a full windows its only for repair
purpose.
Good luck
Nov 02, 2012 | ASUS A8N-E Motherboard
My computer is stuck in hybernation mode
Hi wushuassazin:
1. What exactly do you see on the monitor screen when the computer starts?
2. Do you see any error message?
Step 1: We recommend you to start your computer in last known good configuration and check if the computer starts.
a. Start your computer and tap F8 key continuously to see advanced boot options.
b. Select Last known good configuration and hit enter.
c. Check if the computer starts.
Step 2: If the computer does not start, then check if it starts in safe mode
a. See Start the computer in safe mode
b. Check if the computer boots to the desktop.
c. If it boots, then restore the computer to an earlier time.
See How to restore Windows XP to a previous state
Step 3: If the computer does not start in any mode, then repair install using Windows XP disc
a. See Perform a Repair Installation
b. Once you've completed the installation, check if the issue persists.
Also use a system utility software like RegInOut to fix and avoid all such type of windows errors.
Hope this solution works for you.
Dec 25, 2011 | Gateway Computers & Internet
I am using LCD monitor LG, my son changed some settings which i don't know, Presently, the monitor says Out of range 53.6KHZ / 60HZ. What is the problem and How to solve this problem and restoration of my...
He may have changed the display settings on the computer. He may have altered the refresh rate higher than the monitor can handle.
You can try start the computer in safe mode (F8 repeatedly on boot up, till the safe mode option comes up)
This will load basic video drivers, you should be able to check your settings now.
Windows xp / right click on desktop and your settings are there
OR control panel / display
Sep 04, 2010 | Samsung 510N 15" Flat Panel LCD Monitor
I am having trouble with the monitor showing a black screen. It will turn off in the middle of anything I am doing, quite randomly. Using windows XP Home edition. PC does not turn off, but disk light...
I would suggest to first determine that your monitor is OK. If you are using a notebook try connecting an external monitor as well and see if the same random (monitor switching off problem) happens with this monitor. If you have a desktop try connecting a different monitor.
If the same condition happens with a different monitor try updating the drivers for your video card.
Dec 29, 2009 | Microsoft Windows XP Professional
I was trying to hook up my laptop (Dell Inspiron 2200)(windows xp) to my television. I managed to get the laptop to go to the tv screen, but when computer rebooted, I got a black screen and cannot get rid...
use the F8 button before windows starts. as the laptop show the manufacturer's screen. keep tapping it gently and fast until you get froted with the bootup options screen. Select whichever option reads the word "VGA" in it. Then it will boot into windows. Enter the multiple screen setup (could be hard given that screen could show all icons and windows big) and select proper settings. Restart the PC and ensure the options remain active.
Aug 31, 2009 | Dell Inspiron 2200 Notebook
Computer monitor becomes distorted after boot up.
Download and install the correct driver for the monito as well as the deiver for your video card, if the video is onboard, you may need the motherboard and AGP driver as well.
You will probably need to boot in Safemode to do this.
Good Luck.
Feb 10, 2009 | HP Computers & Internet
Dell Monitor Power save mode activate using pc
yes right click on desktop select properties then click on screen saver then increase wait time problem will solved
Oct 29, 2008 | ViewSonic VE155b 15" LCD Monitor
Acer X233Hbd 23 inch LCD Monitor Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
