Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
No suction when using accesories. Works fine on capets
  • 710 Answers
Have you checked for something blocking the hose or the attachment? There could be lint, hair, plastic bag, or somthing in the air flow.
Do you have the handle completely up and locked into the upright position? The handle must be locked up in order for the attachments to work properly.
And, are all your filters clean?
Hope this helps, if still having trouble, please write back.
If I have helped you, please place a vote for me,
Thanks,
Handie Andie
Posted on Mar 28, 2011
My vac has suction with wand but Capet part won't come on? Help
Check all the passages to the filter canister.
Dec 03, 2016 | Vacuums
Very low suction when I use the hose, but the carpet brush roller attachment works fine. Any ideas?
This style of vacuum has great airflow but does not have great suction, especially at the end of the hose but it still should have enough to pick up most soils. It may have a restriction in the suction tube or emptor. The disposable bag may be full or clogged, the outer bag could also be clogged.
May 04, 2016 | Kirby G4 Bagged Upright Vacuum
SPOT BOT NO SUCTION
Hey Courtney! Sorry to hear about the suction problem on your SpotBot. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1040&cid=ccsocial
Jan 04, 2013 | Bissell SpotBot Robotic Wet/Dry Vacuum
Dyson dc17 No suction
i have the same problem and none of these solutions help. they are all for if suction works but brush doesn't. that isn't what she is saying. brush motor works fine. It's the Suction motor that never kicks on. Mine is doing it now and I would love a fix for it. Resetting suction motor. Not brush....
Jan 02, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a dyson DC18 slim all floors i have no suction from the accesory hose with hose off there is a white plastic thing blocking the hole
I realize this questioned was posted >1 year ago, but in the event you still have the poor suction/wheezing or if anyone else has this issue, here's what worked for us.
Use a plumbers sink snake to unclog the "pipe". I thought it was the pipe on the right hand side (when you're looking at it) which needed to be unplugged. There was a little in that size, however we retrieved the nastiest "hairball" out of the left hand side (when you're looking at it) and after removing that, and re-testing, the suction was incredible. In addition, the "wheezing" noise was no longer there.
Good luck
Jan 23, 2011 | Dyson Slim DC18 All Floors HEPA Bagless...
I have a dyson 07. Vacuum works fine, great suction using the hose. How do I switch to using the carpet vacuum. (I lost my instruction book) Thanks
If this unit has a suction hose built in to the handle, the carpet vacuum should start working after you return the handle hose to the proper position.
Dec 01, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My vacuum stopped working. If it is plugged in and not connected to the power nozzle and you turn it on nothing happens. If you plug in the power nozzle it turns and works fine but no suction.
depending on your unit, and how old it might be, it could be the motor, wiring, or even a fuse next to or on the motor. The power is working fine you have said because the power nozzle works, but because there is no suction I am leaning towards a suction motor in this case.
Nov 05, 2010 | Vacuums
No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Suction is not as it used to be
take out beater bar and pop end cap off and clean out inside of beater bar.
Additionally, this video can help you disassemble your dyson: http://www.ezvacuum.com/dyson-dc07dc14-clutch-assembly-90025204-genuine-p-1636.html
Dec 21, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Keeps getting clogged up in the hose and wont **** until you manual unstop it
clean out hose i some times have the same problem is the felter cleaned out after i started cleaning felter after i am done using it it now works great so try it,with pets it may seem to get blocked up try using arm&hammer capet for pets this seems to help some
i hope this works out.thanks
Nov 30, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
55 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
