Question about Akai LCT42Z6TA 42 in. LCD Television
Hello My picture is great although my OSD is reversed. kide of hard to read backwards. does anyone have a solution? thanks Brad 574-226-1495
POLARIS TRAIL BOSS LOOSES POWER WHEN IN REVERSE
have you ever had polaris(s) before!
my magnum does the same thing , it is a safety thing
press the yellow button on handle bar while on reverse and you will go as fast backwards as forward
Nov 29, 2011 | Polaris ATV
I changed the rear rotors and pads on my 2005 Grand Prix GT a few months ago and now the left rear is not releasing properly after applying the brakes. How do I fix this?
Hello, my name is brad and im here to help.when you install your new rotors and pads,you had push in the calipers,did they push hard or fast,if hard you have stickey caliper,if not a colapst brake hose.hope this helps,have a great day and thank you.
Sep 17, 2011 | 2005 Pontiac Grand Prix
On screen show osd lock.pl.send solution.
Here is the solution for your problem,
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
1.If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
2.If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Thanks.
Have a great day.
Sep 04, 2010 | Computers & Internet
Just want to know whether there is a way to get a tape to auto reverse on the dual tape deck, and, what is the "OSD" button on the receiver for? This is an old Denon D-1250 shelf system. Thanks,
OSD = On Screen Display
Auto Reverse is a built-in feature of any tape deck. It would have a button that looks like > for forward and < for reverse; and probably a switch that sets the mode for automatic or manual reversal at end of tape.
Feb 24, 2010 | Audio Players & Recorders
Hi I've got a Samsung TFT monitor -Syncmaster 710V - that gives an error message.Message reads: Not optimum mode Recommended Mode: 1280 x 1024 60Hz This screen is impossible to get rid of. Anyone know the...
Try to change the desktop display settings, see screenshots below, see if it works
Right click on your destop and go to properties > settings
  1. Set your Screen resolution to 1280X1024
  2. Then click advanced and go to Monitor and set the refresh rate to 60 Hertz.
Dec 06, 2009 | Samsung 710V 17" LCD Monitor
Poor picture quality
Hello Paul. I have this same monitor, but rebranded, Access the service menu with the remote control:
With user’s RC
1. Power TV On
2. Press Menu button and call up User OSD Menu
3. Select Sound-> Balance
4. When Balance value is “0”,Enter 0->5->3 ->2 in sequence.
Note: If necessary, re-do number keys.
5. Factory OSD appears.
6. Press the standby button then AC turn off and restart the TV, which can exit factory
OSD menu.
Now you will be able to change the values for Red Green and Blue channels. I also hated this TV, but after adjusting the colors it's looking great! Hope you could fix it too! :)
Nov 16, 2009 | Televison & Video
Fan stopped working
Hmm, it's hard to diagnose your fan's problems without being there in person, though I can tell you there is a great, handy diagnostic article that provides the most common causes for a ceiling fan not to work. Here it is:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Ceiling_Fan_Does_Not_Work.htm
Hope this helps!
Brad
May 03, 2009 | Emerson Fans CF759PB Designer Polished...
OSD locked out
hello you have Resolved ?
thanks andrea
Jan 25, 2008 | LaCie Electron 19" CRT Monitor
External Hard Drive
Couple of questions first: -What operating system was running on the new and old PC? -Is the old PC still running and available? Once you answer these we?ll start work.
Mar 04, 2007 | Maxtor OneTouch A01B080 80 GB Hard Drive
Akai LCT42Z6TA 42 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
