Question about True T-49 Side by Side Refrigerator Commercial
T-49 delivery - set-up
Plugged T-49 in upon delivery, interior lights and fan running. Compressor not running.
  • 51 Answers
Make sure that the service valves are open. After you have checked that, hook up your refrigeration gauges and verify that you have not lost all of your refrigerant. Please do this and let me know if you need any further guidance.
Posted on Feb 20, 2009
SOURCE:
Samsung fridge SR-L628EV, compressor works, all fans works but no cold air at all, it has been setting for two years but now is not giving cold air, any idea on how to fix it? Thank you
either needs freon [compressor will come on if low freon ] interior fan ,compressor internal valve damage tx valve damage condenser fan -etc can be anything with compressor running feel and look at condenser coils they should be hot and be careful of fan if not hot more than likely need freon
Sep 04, 2016 | Refrigerators
I have a Turbo Air TGF-49F freezer and it is not cooling. The compressor unit seems to work but when I turn the unit on all I hear is the compressor running continuously but nothing gets cold.
Difficult for you to check this I'm afraid, if the fan on the cooling unit is working unless you have an experienced 'ear' you will not hear the compressor running or worse still occasionally clicking.
Possible faults are
1. Compressor not running (the fan will run even if the compressor does not) electrical fault
2. Compressor seized (consult your service guy) also true for the rest of these
3. Compressor not pumping
4. Refrigerant leak
Not much hope for a cheap repair
Apr 14, 2011 | Turboair 49 cu. ft. Upright Freezer...
Freezer is warm, not freezing at all, fans run
If the fans your talking about are in the refrigeration section, then the unit is not in defrost. The interior fans shut off during the defrost cycle.
There is a condenser fan motor in the machine section by the compressor. If it fails, the problem you described can occur.
If that fan motor is still, and the compressor is cool to the touch, then no power is getting to the refrigeration section.
Could be a bad thermostat, or the unit has tripped off on the high pressure safety switch. The high pressure switch can be one of 2 styles. Auto reset, which means it will try to restart the compressor when the pressures become normal. The other has a lock out feature that requires it be reset manually. If it goes out on the high pressure switch, once reset, check the condenser fan motor to make sure it is running and/or excessive dirt in the condenser, which must be blown out.
Other causes can be a total loss of refrigerant, or a compressor that won't run.
Short of a broken wire all items listed except for a dirty condensor and reset of the high pressure switch, require a decent knowledge of electrical, Knowledge in the use of a VOM meter and amp-probe, as well as a set of refrigeration gauges.
Oct 30, 2009 | Turbo Air 49 cu. ft. / 1388 liter...
Moved refrig. and compressor will not kick in
The unit may have gone into the defrost cycle. The fans and compressor will be off during the defrost cycle. Has the unit been plugged in for more than 30 minutes since you noticed it stopped? If so, you will see a round plastic knob recessed about 8" back in the console on the fresh food ceiling. Rotate this knob clockwise with a flat blade screw driver until a distintive click, louder than the tiny clicks made while rotating the knob. If the fans and compressor come on, replace the timer (68233-3).
If the fans and compressor do not come on after rotating the timer, you may have a bad cold control of loose wire in one of the molex connectors from the move.
Apr 29, 2009 | Refrigerators
Evap fans not running after power loss and restart
It sounds like you could be stuck on a defrost cycle? The system is in a pump down cycle, check solenoid valve is off but compressor is not cutting on pressure switch.
Mar 04, 2009 | True T-49 Side by Side Refrigerator...
True t-49 compresser not running at all
Is the compressor fan motor running?
If so, replace the capacitor on the compressor.
If no.
Replace the thermostat.
Feb 24, 2009 | True T-49 Side by Side Refrigerator...
Temperature at 10 degrees
check condenser fans, if defective or running slow change it
if condenser fan is running, suspect a compressor with internal mechanichal problems, it will run but i can't guarantee how long, maybe a couple of weeks or days. if it's an copelamic compressor, it's going bad.
Apr 21, 2008 | True 49 cu. ft. / 1388 liter Commercial...
Inside fans not running
verify wiring probably lose wire(s) in movement
Apr 21, 2008 | True T-49 Side by Side Refrigerator...
Samsung Model RS2630SH
if fridge freezer sits down after power outage on a rs21dcns where interior lights are lighting but nothing else is working press power freeze and power cool buttons together for a few seconds should repower unit
Feb 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
True T-49 Side by Side Refrigerator Commercial Logo
67 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
Joe Palazola
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
