Question about Canon i455 InkJet Photo Printer
It keeps saying printhead is not installed but i havent messed with my printhead so it should be in the same position as before it started displaying this message.
  • 390 Answers
The Print Cartridge is a moving part and there are chances that the cartridge might have moved from its clasp try removing the cartridge and reloading it and ou might have it back in order
also when you have anyway taken the cartridge out try to wipe the ink side (bottom) with a soft cloth to clean
cheers
Posted on Mar 28, 2011
  • 37 Answers
Maybe the print heads just got knocked out of alignment while the printer was printing. Try taking the print heads out and resetting them. If this does not work then you can purchase another set of print heads or you can see if the printer has some type of warranty with it.
My hp pavilion g7 series laptop is messing up? it says my ati display driver keeps messing up.
1.Start the laptop up in safe mode with networking by pressing the f8 button while switching it on at the power switch.
2 Once in safe mode remove the ati drivers.
3. Download Eusing free registry cleaner install it and clean your registry.
4. Download new drivers from Ati and install them.
hopefully this should do the trick. if the problem still exist then it could be a sign that your graphic chip is failing,.
Feb 13, 2013 | Pavilion g7-1219wm Notebook PC
My printer keeps saying that the prinhead is missing and need to be installed, I took it out and installed it again and it keeps saying the same thing
it could be more serious, but I would put in the printhead and then unplug the printer and then wait a few seconds and plug it back in. it might clear the code. otherwise it might be your print head bad.
good luck
Jan 09, 2012 | Kodak ESP 5 Printer
Keep getting paper jam fault 3618
Hi!
If the error comes up during the initial setup of the printer:
  • Select All-in-One Printers.
  • Double-click the Setup Guide for your printer.
  1. Open the printer access door.
  2. Remove all:
    • orange shipping tape
    • foam pieces
  3. Follow the steps in the Setup Guide to insure that you have properly installed the printhead and ink cartridges.
  4. Close the printer access door.
  5. Press OK to clear the error.
  6. Make a print.
OR
Check the printhead carriage area:
Debris and Obstructions:
  1. Remove any paper, tape or other obstructions from the printhead carriage area.
  2. Gently move the printhead carriage from side to side to see that it moves freely and there are no obstructions.
Ink Cartridges:
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
    NOTE: If the printhead does not move to the center position, press Home, then Maintenance on your printer. Check if the Install Ink Cartridge option is available. If so, select Install Ink Cartridges, press OK, and follow the instructions. Otherwise do the following:
    1. If an error is displayed on your printer control panel or the status monitor on your computer, press Cancel to clear the error.
    2. Go to KODAK All-in-One Printer Downloads and Drivers, select your printer from the All-in-One Printers pull-down list, and download and install the latest firmware version for your printer. Follow the on-screen instructions.
    3. After you upgrade the firmware, press Home on the printer control panel.
    4. Select Maintenance, then press OK.
    5. Select Install Ink Cartridges, then press OK.
    6. Follow the instructions on the control panel LCD.
    7. Go to the next step.
  2. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the black ink cartridge into the printhead, then press down firmly until you hear it click into position.
  5. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
  6. Close the printer access door.
  7. Press OK to clear the error.
  8. Make a print.
Hope this helps.
Apr 19, 2011 | Kodak ESP5250 All-In-One InkJet Printer
My kodak esp 7200 series printer keeps saying theres a printhead carriage jam. ive done everything its asked and there not shouldnt be a problem but it keeps stalling up.
Open the printer access door and clear any obstructions. Check that the printhead and ink cartridges are installedcorrectly. (The printhead and ink cartridges are installed correctly when youhear them click into place.)
Apr 17, 2011 | Kodak ESP 5 Printer
My canon MP480 keeps poping up a 5100 error
That error is a Carriage error, which means that the printer carriage (the bit that holds the cartridges) is unable to move or similar.
Make sure you've installed the cartridges correctly and that the grey lever that holds down the printhead is in the down and locked position.
You may find that you've installed the printhead incorrectly so worth pulling out the cartridges, removing the printhead and then reseating it so the lever goes down to a horizontal position. Then reinsert the cartridges.
Mar 10, 2011 | Canon Pixma MP480 All-In-One InkJet...
Our printer keeps saying printhead and wont print ofcourse. so ive changed the printhead with a new one and it printed just fine for a day til they turned it off and returned the next day to find the same...
im not familiar with that model but ill say the platen roller is probably fine in your case. im going to ask is this a direct thermal or thermal transfer printer?? transfer means uses a ribbon?? if not its possible your thermal paper isnt any good?? it does have a shelf life and gets to the point where print might be there but quite faded if the paper is old. one more question...does this printhead have an ohms value on its label?? if it does and so will the new one and that value might need to be set in the printer itself. like i say im not that familiar with your model im used to large industrial tabletops and print engines on applicators
Aug 01, 2017 | Zebra 105Se Thermal Printer
Error message! I just got a Kodak 5210 printer and it keeps saying "printhead carriage jam. open printer access door. clear any obstruction. check installation of printhead and ink cartilages. close...
To resolve the error condition:
1. Disconnect the power adapter from the printer.
2. Wait 30 seconds to allow the printer to reset.
3. Connect the power adapter to the printer. Turn the printer on if necessary.
4. Wait until the printer is ready to use.
If the error condition continues:
2. Remove and install the print head two times. - See http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
3. Close the printer access door.
5. If the error is still displayed, contact Kodak
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 03, 2011 | Computers & Internet
Error code U052; keeps saying incorrect printhead installed - the printhead has never been changed
Per Canon's website, and this just worked for my mp620:
Turn the printer on.
Open the cover.
Remove the ink cartridges.
Remove the printhead.
Re-install the above (this resets the printhead).
Close the cover.
Printer should initialize and go to home menu screen.
Nov 24, 2010 | Canon PIXMA MP620 All-In-One InkJet...
How do I change the print head on a Xerox 8500?
How to remove a printhead
  1. Press the on-line / off-line key on the printer operator panel to set the printer off-line.
  2. Use the upper softkeys to scroll to the 'Replace printhead' card
  3. Press the softkey below the 'Replace printhead' card to enter the wizard.
    An introduction screen displays the message 'Use this wizard to replace printheads. A roll is needed for calibration.'
  4. Press the key for 'Next'.
    The screen displays the message 'Select roll to use'.
    The system does a calibration at the end of the wizard. You can only calibrate on the defined media types. When calibration is not possible with the media available on the printer, the system asks you to load the correct media. When calibration is possible with one of the rolls, the system automatically uses the correct media roll. When calibration is possible with both rolls, use the lower softkeys to select the roll to use.
  5. Press the key for 'Next'.
    The screen displays the message 'Carriage moving to centre position...' while the carriage moves to the centre.
    The screen displays 'Open top cover.'
  6. Open the top cover. The screen displays the message 'Replace printheads' and the printheads that you must replace. Find the correct printhead number on the printhead carriage.
  7. Press the front of the printhead cover to unlock the cover.
  8. Open the printhead cover.
  9. Pull out the printhead and remove it.
How to place a printhead
  1. Remove the protective tape from the new printhead.
    Do not touch the contact and nozzle areas of the printhead after you remove the protective tape.
  2. Place the new printhead in the printhead holder.
    The printhead only fits in one way.
  3. Close the printhead cover.
  4. After you replaced the defective printhead, press the softkey for 'Next'
  5. The screen displays the message 'Make sure that all head covers are properly positioned.'
    Press the key for 'Done'.
    The screen displays the message 'Close top cover.'
  6. Close the top cover.
    The screen displays the message 'Carriage moving to home position...'
  7. The screen displays 'Calibrating...'.
    The calibration process takes several minutes.
    You can stop the calibration process at any time. Press the key for 'Cancel' to stop the calibration process.
Regards,
Anirban Mazumdar
http://www.ikarmatech.com
Sep 08, 2009 | Xerox Phaser 8550DX Laser Printer
My brand new printer is displaying printer error code 5100 and will not print or recognise the ink not sure if this means the ink cartridges are faulty.
That error translates as a "Carriage error"... which means that the printer carriage (the bit that holds the cartridges) is unable to move or similar.
Check you've installed the cartridges correctly and that the grey lever that holds down the printhead, etc.. has been put in the down and locked position.
If that doesn't solve it the best course of action is to return it and demand a replacement.
Feb 19, 2009 | Canon Pixma MP480 All-In-One InkJet...
Canon i455 InkJet Photo Printer Logo
111 people viewed this question
old marine
old marine
