Question about Frigidaire Refrigerators
JCD-23 won't make ice but dispells water - Frigidaire Refrigerators
My Electrolux EW23CS65GS1 model JCD-23 the freezer makes a strange noise at the rear it sounds like it comes from inside what is it and what can I do?
Thanks for your post, Rob Muzich!
From the information you have provided your Electrolux refrigerator is making a strange noise at the rear. Depending on what type of noise you are hearing it could be a normal operating sound. In the manual it provides a list of sounds on page 23. I have included a digital copy of the manual for you to review. If you need any additional assistance please feel free to reconnect. -Matt
Frigidaire Manual Search Results
Nov 28, 2014 | Electrolux Refrigerators
There's no water coming from the water dispenser
Have you ever replaced the water filter? It may be clogged. Does it make ice?
May 01, 2014 | Kenmore 23.1 cu. ft. Side-By-Side...
JCD-23 making too little ice
Check the water flow to the ice maker. Turn the supply water off, loosen a fitting near the ice maker and then turn the water on. You should get plenty of water. If it is slow, check the filter.
Dec 01, 2013 | Frigidaire FRS3R5EMB Side by Side...
Fussy Frige
Yes 66003764 Overload, Relay with Run Capacitor and you may need to also change the=> 67006531 Water Inlet Valve because it is not closing all the way and allowing water to continue to drip into the ice maker when it should be off. Here is a JCD2295KES Parts List and JCD2295KES User Manual I am here should you have questions, Thanks Sea Breeze
Jul 16, 2013 | Jenn-Air Refrigerators
I have a Jenn Air refrig JCD 2389GES....the frezzer is working fine, the the fridg is warm.....what should I do? I took the ice maker out and cleaned the slots behind it....the fridg side is still not...
Check the circulation fan in the freezer compartment that circulates the cold to the fresh food compartment. If its not running, and no ice is on it to bind uo the blades, replace the motor.
Aug 04, 2009 | Jenn-Air JCD2389G Side by Side...
I have a JCD 2289 AE side by side. The freezer has water at the bottom rear that has frozen. How do I turn off the freezer and not the refigerator to defrost it and what could the cause be for the water
Just unplug the frig and open the freezer and let it defrost. Put the frozen items in the frig to keep them cold. Keep the frig closed if possible. You can assist the defrosting by blowing a window fan into the freezer. The room temp will defrost it quickly, or set a blow dryer on LOW and direct toward ice. Careful don't take the chance and turn that dryer on heat. And DO NOT CHIP ICE with a sharp object (patience is free). You may need to physically remove the water as the ice melts. - The source of the ice is probably condensation, or if it happens very quickly, there may be a ice maker leak. Once defrosted replace the frozen items and watch for cause of ice.
Jul 05, 2009 | Maytag MZD2669KE Side by Side Refrigerator
Water and ice despencer
Production of ice cubes depends on freezer temperature. zero degrees turns out ice more often than 15-20 degrees. Slow water?
You may have a partial clog in the supply line to the water sloenoid vavle. Are the ice cubes normal size when dumped?
Jun 20, 2009 | Maytag MSD2351HEB 33" 23 Cu. Ft....
Refrigerators Logo
444 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
