Question about Sony DELUXEPRO CPD-G520 (Gray) 21" CRT Monitor
I have a sony monitor G520 i have a proplem when i use the buttons of the monitor to change the option of the screen in the monitor it send me a password required i dont know it its unlock to not allow children to play in it this is every thing about the monitor i have (cbd-g520 serial 6007981) this is all info about it so i need help please i need this password the official password of the monitor
Does not turn on
With any monitor, check the following to determine if the issue is MONITOR related or COMPUTER related.
1. Verify the monitor is receiving power - use a known good power outlet and plug it into the monitor
2. Samsung monitors have a light on the power button - are you getting any color light from this? Orange means it is in "stand by" mode and is waiting for the PC to send it a signal. Green means the monitor is getting a signal from the PC and the monitor is on.
3. With the monitor on, press the buttons on the monitor to bring up the OSD (on screen display) that changes the monitor settings. If you have a green light on the power button and press one of these buttons (AUTO works best), this will display the monitor adjustment options on the screen.
If you see the on screen adjustments, your monitor is working and the issue may be with your PC. Move the monitor to another PC and verify the monitor is working correctly.
IF you don't see anything on the screen and the power light is green, the monitor has failed.
This could be the lights that illuminate the screen have failed (something that happened to my Samsung Syncmaster monitors after about 6 years of use) or the screen has stopped functioning. In either case, replacement parts are hard to find and a monitor swap is likely.
Nov 03, 2013 | Samsung SyncMaster S22B150N - LED monitor...
I have an HP G60-117US Notebook PC. Can you tell me how to connect it to my Sony HD TV so I can watch a movie.
Use an HDMI cord to connect the two together. On your Sony remote click the TV/Video button ( also called input button) slowly until you see your desktop screen appear on the Sony TV. Your desktop screen will probably be smaller then the TV screen and will be a duplcate to the computer desktop screen. That might not be acceptible to you. You will have to change the resolution to the recommended 720p or 1080p to fill up the TV screen. The pc will recognize the Sony monitor (TV) as a second monitor. You could change it from duplicate screen to seperate second screen.
Oct 03, 2010 | HP G60-120US Laptop
I have a Compaq Q2009 (new). The picture is too wide on the right side, cutting off the image about 1/4".
There are a series of buttons on the monitor. There's probably a Menu button that allows you to change the dimensions and sizes of your picture on the screen. You'll need to open the picture menu, and find the Horizontal picture options. There are normally two options - one changes the horizontal placement, and the other changes the horizontal size. You can play with these two options until you can see your whole screen.
Mar 07, 2010 | Compaq QVision 171FS (White) 17 in.CRT...
I have a dell 22" monitor. I cannot get the display to show properly. How do I get the proplem fixed
At the Right side of the monitor you can see Buttons try to change it to Auto or Reset it by using the MENU options IF not Right click on desktop screen,go to properties and go to display settings and change resolution as you needed
Jan 07, 2010 | Dell Computers & Internet
New wide screen not compatible with my old pcv-rx650
Try, right clicking, then pushing the option of customise or personalize (depends on operating system), then it will give you an option (by where you change your background), to change the resolution. Choose one of the bigger ones, then when you hook up the other monitor, it will fit on the screen, and you can go back the the same screen and pick the one that looks best with that display (The monitor should have came with a manual that says the recommended resolution for the display.
Oct 24, 2009 | Sony VAIO Digital Studio PCV-RX650 PC...
Monitor shuts down unexpectedly, can't bring it back up
Please verify your monitor screen saver options.there u can find power selecting that button u need to change turn off monitor option into never.then your monitor never shuts down unexpectedly.
Sep 14, 2008 | HP Computers & Internet
Computer monitor screen stays black
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 26, 2008 | LG Flatron L1710S 17" LCD Monitor
D-Link AirPlus Xtreme G DWL G520 channels proplems
I'm assuming you're in USA. The FCC may be limiting the frequency range that the card can use.  Check out drivers for other locations to see if that helps.  Also see if you have current drivers.
Oct 14, 2007 | D-Link AirPlus Xtreme G DWL G520 802.11g/b...
No Picture
you have brightness and/or flyback problem...
Jul 03, 2007 | Sony CPD G520 (Blue Grey, Gray) 21" CRT...
Sony DELUXEPRO CPD-G520 (Gray) 21" CRT Monitor Logo
54 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
