Question about ASUS HS1000W Wireless Headset
Headset is not charging through USB - ASUS HS1000W Wireless Headset
If you are using a USB hub, then try connecting the USB dongle directly to the USB port of the machine/laptop. Some USB hubs will not charge devices properly.
I had a similar problem with my headsets solved by plugging into a USB port directly.
Posted on Jun 06, 2011
How long should i charge the headset and how to turn it on
The headset contains a lithium ion rechargeable battery, which should be charged before using the headset for the first time.
System requirements for battery charge using USB
Personal Computer with pre-installed with any of the following operating systems and USB port:
Operating Systems (when using Windows)
Windows® 7
Home Basic / Home Premium / Professional / Ultimate
Windows Vista® (Service Pack 2 or later)
Home Basic / Home Premium / Business / Ultimate
Windows® XP (Service Pack 3 or later)
Home Edition / Professional / Media Center Edition 2004 / Media Center Edition 2005
(when using Macintosh)
Mac OS X (version.10.3 or later)
Charging the headset
  1. Open the cover of the micro-USB port.
Insert the tip of your fingernail in the groove, and open the cover.
  1. Connect the supplied micro-USB cable to the headset, and then connect the other end to a computer.
Make sure that you connect the plug of the micro-USB cable in the direction as shown in the illustration below.
Charging starts when the headset and the computer are connected.
Make sure that the indicator (red) lights up. Charging is completed in about 6 hours* and the indicator (red) goes off automatically.
*Time required to charge the empty battery to its full capacity
Notes
  • If the headset is not used for a long time, the indicator (red) may not light up when you connect the micro-USB cable to charge the headset. In this case, do not disconnect the micro-USB cable from the headset and wait until the indicator (red) lights up.
  • When you close the cover of the micro-USB port after charging the battery, push the catch at the edge (the round part) of the cover into the port compartment.
  1. Catch
Tips
  • If the micro-USB cable is connected to a computer while the headset is turned on, the headset will be turned off automatically.
  • To charge the headset from an AC outlet, use USB Charging AC Power Adaptor* (sold separately). For details, refer to the manuals supplied with the USB Charging AC Power Adaptor.
  • The headset cannot be turned on while charging the battery.
*Refer to the Reference Guide on the recommended adapter.
Caution
If the headset detects a problem while charging, the indicator (red) may turn off, although charging is not complete.
Check for the following causes:
  • Ambient temperature exceeds the range of 5 °C - 35 °C (41 °F - 95 °F).
  • There is a problem with the battery.
    In this case, charge again within the above-mentioned temperature range. If the problem persists, consult your nearest Sony dealer.
Notes
  • If the headset is not used for a long time, the battery may be quickly depleted, however, after a few recharges, the battery life will improve.
  • Even if you do not intend to use the headset for a long time, charge the battery to its full capacity once every 6 months to maintain its performance.
  • If the headset is not used for a long time, it may take longer to charge the battery.
  • If the life of the built-in rechargeable battery drops to half the normal length, the battery should be replaced. Consult your nearest Sony dealer for replacement of the rechargeable battery.
  • Avoid exposure to temperature extremes, direct sunlight, moisture, sand, dust or mechanical shock. Never leave the headset in a car parked in the sun.
  • If the computer enters into hibernation mode while connected to the headset, charging will not be completed properly. Check the setting of the computer before charging. The indicator (red) will go off automatically even if the computer enters into hibernation mode. Charge the headset again in this case.
  • Use the supplied micro-USB cable only, and connect directly to a computer. Charging will not be completed properly by an indirect connection, such as via a USB hub.
Usage hours
Status Approx. usage hours Communication time (including music playback time) (up to) 30 hours Standby time (up to) 200 hours The communication time will be about 15 hours when it is charged for 2 hours.
Time stated above may vary, depending on ambient temperature or conditions of use.
Checking the remaining battery
If you press the POWER button while the headset is turned on, the indicator (red) flashes. You can check the remaining battery by the number of times the indicator (red) flashes. The indicator (red) flashes immediately after the headset is turned on to indicate the remaining battery power.
Indicator (red) Status 3 times Full 2 times Mid 1 time Low (needs to charge) Note
  • You cannot check the remaining battery during pairing operation.
When the battery is almost empty The indicator turns red. When the battery becomes empty, the headset sounds a beep and turns off automatically.
Mar 26, 2016 | Jabra Bt2045 Bluetooth Headset
How to fix H350 Bluetooth headset? why wont it charge?
You should charge it via wall charger so it charges faster.
Jun 26, 2014 | Motorola Mobility Bluetooth Hands Free...
Why do you send usb connection to charge jwin jb-th130, why not receptical plug. do i plug into computer and how long to charge?
The standard connection is a USB plug (mini or micro USB style). You can plug it into your computer or any wall plug that has a USB connector on it (the bigger rectangle shaped plug like your computer has). The USB standard is 5 volts so if it comes from your computer or a wall adapter or your car charger - as long as it is a USB connector and likely says 5 volts, they will all work the same way.
Every headset I have worked with seems to charge about 50 to 75% in 2 hours (it is ok to do a quick, partial charge). Leave it plugged in overnight for full charge (8 to 12 hours).
Jun 14, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
I have a nokia x3 slide.. im having toruble using the headset bec its not going to the headset when im trying to use it,, its always on loud speaker whne i want to listen to mp3's.. also same with the usb...
clean the headset interface jack, and make sure the headset is not faulty. otherwise, try in a another headset. is same, have your phone checked since that could be a problem with phone.
Mar 28, 2011 | Blueant X3 Charging USB 2.0 Data Cable...
I lost the charger for the jabra bt135 bluetooth headset...where can i buy a new one?
Hey there sanjeev! There should be an USB port on the back of the headset, it is the micro-usb port. Therefore, if you have a cable from your camera, mp3 player or any other gadget that uses a micro-usb port, take their cable, plug it into the headset and let it charge! :D
I hope it helped! Take care! :)
Mar 04, 2011 | Jabra BT135 Bluetooth Headset
I have a madcatz headset, Well The Headset still working in the ps3, but today when i put it to charge doesnt want to charge anymore, and the USB cable looks perfect, i didnt dmged it or moved it. is weird
Seems you should order another cable from madcatz because your charging cable might of become faulty or you might want to change usb ports on the computer you are using.
Jun 12, 2010 | Mad Catz Bluetooth Headset for PS3
I cant connect my headset
Have you charged headset via usb cable plugged into ps3...when charged press + hold silver telephone symbol...a blue pulse light should appear on headset..go to menu in ps3..to pair devise [headset] with Bluetooth.
Feb 26, 2010 | Mad Catz Bluetooth Headset for PlayStation...
I have a H270 Bluetooth headset. I charged it
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
Oct 27, 2009 | Motorola Mobility H270 Bluetooth Headset
Why wont my headset blink the blue light
Hi there...
It's probably not charged enough.
Make sure you plug in to your USB connector, and charge it before you try turning it on again.
Hope I helped!
Tom
Jun 20, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
My Headset just stopped working on the gn9350 headset. The base is on but it does not seem to be charging and there is no light on the headset or in front on the charging station. Is there some way to...
Hi I was in a live session with you when you left. Apparently you have not paired the headset with the base. All you have to do is follow this procedure
Place the headset in the charging base->Press the base's pairing button->Both the telephone and USB buttons on the base until the headset's link indicator will light for 2 seconds indicating that the pairing is successful. It should probabl charge after this.
Let me know if you need more help.
Sai.
Mar 17, 2009 | GN Netcom GN 9350 Wireless Headset
ASUS HS1000W Wireless Headset Logo
224 people viewed this question
Top ASUS Radio Communications Experts
ray gallant
Paul Chapman
Paul Chapman
Brett Duxbury
Brett Duxbury
Are you an ASUS Radio Communication Expert? Answer questions, earn points and help others
