Question about John Deere Garden
John Deere T160 won't start after taking out from winter storage. I had stored it with a fully charged battery. It won't turn over and when the ignition is turned it doesn't even have a clicking sound. I cleaned up all the terminals and checked the spark plug. I attempted to jump start it and it turned very slowly but not a full crank. It made a frying sound when this happened. The battery is still fully charged according to my electric charger.
  • 161 Answers
SOURCE: trickle charger for storing electric cushman golf cart
contact manufacturer, and seek there advice
Posted on Nov 27, 2008
  • 702 Answers
SOURCE: 94 F150 5L won't crank
Sounds like your starter has decided not to work anymore.
Posted on Feb 09, 2009
  • 109 Answers
SOURCE: my 2007 john deere eztrak z225 wont crank even
If i understand you right the little square piece is the solenoid, and it should be replaced if it is making a buzzing noise
Posted on Apr 26, 2009
  • 15935 Answers
SOURCE: 2001 Chevy Malibu, 89,000 miles, 3.1 engine, won't start
CLICK HERE for the injector schematic.
CLICK HERE for the Ignition schematic.
Since the PCM uses info gatheres from the crank and cam sensors to calculate ignition - and there are no OBD codes - in all likelihood, the PCM itself is bad.
The Ignition Module, also transmits to the PCM.
It appears after all your testing - that the PCM is at fault.
It does not error report on itself (unfortunately).
The ignition timing is controlled by the Powertrain Control Module (PCM). No adjustment is necessary (distributorless ignition) or possible.
Please see the following....
The ignition timing is controlled by the Powertrain Control Module (PCM). No adjustment is necessary or possible.
The engines covered by this manual are equipped with distributorless ignitions, ignition timing is controlled by the Powertrain Control Module (PCM), as applicable. No adjustments are possible. If ignition timing is not within specification, there is a fault in the engine control system. Diagnose and repair the problem as necessary.
Ignition timing is the measurement, in degrees of crankshaft rotation, of the point at which the spark plugs fire in each of the cylinders. It is measured in degrees before or after Top Dead Center (TDC) of the compression stroke.
Ideally, the air/fuel mixture in the cylinder will be ignited by the spark plug just as the piston passes TDC of the compression stroke. If this happens, the piston will be at the beginning of the power stroke just as the compressed and ignited air/fuel mixture forces the piston down and turns the crankshaft. Because it takes a fraction of a second for the spark plug to ignite the mixture in the cylinder, the spark plug must fire a little before the piston reaches TDC. Otherwise, the mixture will not be completely ignited as the piston passes TDC and the full power of the explosion will not be used by the engine.
The timing measurement is given in degrees of crankshaft rotation before the piston reaches TDC (BTDC). If the setting for the ignition timing is 10 BTDC, each spark plug must fire 10 degrees before each piston reaches TDC. This only holds true, however, when the engine is at idle speed. The combustion process must be complete by 23° ATDC to maintain proper engine performance, fuel mileage, and low emissions.
As the engine speed increases, the pistons go faster. The spark plugs have to ignite the fuel even sooner if it is to be completely ignited when the piston reaches TDC. Spark timing changes are accomplished electronically by the engine and ignition control computers.
If the ignition is set too far advanced (BTDC), the ignition and expansion of the fuel in the cylinder will occur too soon and tend to force the piston down while it is still traveling up. This causes pre ignition or -knocking and pinging-. If the ignition spark is set too far retarded, or after TDC (ATDC), the piston will have already started on its way down when the fuel is ignited. The piston will be forced down for only a portion of its travel, resulting in poor engine performance and lack of power.
Timing marks or scales can be found on the rim of the crankshaft pulley and the timing cover. The marks on the pulley correspond to the position of the piston in the No. 1 cylinder. A stroboscopic (dynamic) timing light is hooked onto the No. 1 cylinder spark plug wire (2.2L engine only, on the 2.4L engines, special adapters are needed) . Every time the spark plug fires, the timing light flashes. By aiming the light at the timing marks while the engine is running, the exact position of the piston within the cylinder can be easily read (the flash of light makes the mark on the pulley appear to be standing still). Proper timing is indicated when the mark and scale are in specified alignment.
WARNING When checking timing with the engine running, take care not to get the timing light wires tangled in the fan blades and/or drive belts.
Thanks for using FixYa!!
Posted on Aug 18, 2009
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Posted on Nov 08, 2009
I have a john deere la 115 trys to turn over but not enough power to start
Check the battery condition make sure its fully charged and the terminals are clean and tight, if ok the starter may need repairs.
Jul 03, 2016 | John Deere Garden
Why won't my 2007 John Deere L130 turn over?
remove spark plug and see it it turn over .set Brake too
May 04, 2015 | John Deere Garden
I have 2000 john deere 420 and it wont turn over
The starting circuit is dependent upon the clutch safety ans PTO being off. Here are some steps to take:
1. Ensure battery is fully charged
2. Turn key on and turn PTO on then back off. Listen for clunk
3. Press clutch in fully and turn key to start position. If still no sound at all, hold key in start position and move clutch foot up and down, listening for solenoid click. If click but no crank, starter or solenoid or battery cable connection is bad. Start by wiggling cables, looking for any looseness. Next check solenoid and cables. If that doesn't fix it, starter or solenoid may be bad. There may be a fuse in the circuit. Check them out also.
if it cranks but doesn't start, you have a fuel or ignition problem. Good luck. Let us know what you find
Jun 22, 2014 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Turf Tractor
I believe the wires run directly from the battery to the switch that makes it run without a fuse. Check to make sure the switch is fully plugged in under the pedal. You will also want to check the charge on the battery, which a store like Batteries Plus should be able to do. Might be a bad battery as well.
Nov 19, 2013 | Peg Perego IGOR0040 John Deere Turf...
Our john deere gator won't run
how do you know that the battery is charged? it could be that the charger isn't working. I would check the charger with a multimeter and verify that its putting out enough volts to charge the battery, it should be putting out between 13.8 and 14.6 volts
Apr 29, 2012 | Peg Perego John Deere Gator HPX
My John Deere x300 won't start. The battery is charged and I can smell gas as the engin turns over. It
I am not familiar with this particular model but from the smell of raw gas I check the air filter and choke first to see that you are not flooding it. You could also take out the spark plug to see whether it is wet with gas.
Aug 07, 2011 | John Deere Garden
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
The charging system on a C425 John Deere riding lawn mower will not charge the battery.
It could be that the battery is not taking a charge. If you have an external battery charger, try taking it out and charging it.
You should also be able to take the battery into your local auto parts store and they can test it for you for free.
If the battery tests good then you probably need to replace the alternator.
Jun 08, 2011 | John Deere Garden
My john deere LA120 will only start with a jump, battery fully charged changed battery.
Your starter may be nearing the end of its service life.
If it is worn down it may require more amperage than your battery can deliver to crank. That is why the extra battery helps. More amps!
You can start your tractor and check the wires to see if they are hot to the touch. That would be proof the starting system is drawing more amps. If it isnt hot then you might have connection problems or corrodes leads.
You can try replacing your battery wires to lower resistance and improve power transfer to the starter. Leads are cheap and available at most car parts stores.
Jul 07, 2010 | John Deere Garden
Battery seam like it is not charging
Some automatic battery chargers will not charge a REALLY low battery. You really need a volt/ohmmeter to check charging rate.
Should be 13.5--14.4 volts while charging, 12.5 volts for fully charged battery.
Apr 05, 2009 | Craftsman Garden
Garden Logo
185 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
