Question about Roper Dryers
Need to replace 3-wire power cord with 4-wire power cord on Roper model REL4432AWO (220V electric unit)
    President:
  • 1,430 Answers
Try this link it should help Replacing a dryer cord
Posted on Mar 28, 2011
How do I wire a Franke Evolution 2-step
There are other points to consider before wiring in the machine. is it a topps model? 2 boilers?
singer boiler with heat exchange unit. are you wanting single phase 13 amp 22amp or 3 phase.?
you can email me direct on franke@lydney.biz
Dec 22, 2014 | Franke Evolution Two Step Espresso Machine
Replacing electrical cord
if you buy a color coded cord and plug then red and black go on thee 2 outer terminals of the power terminal and the white wire goes between these as this is the neutral connection and if it has a green ground wire connect this anywhere to the metal case of the unit, if its a gray cord with no colors then the 2 outer wire on the cord go to the outer terminals on the units power terminal block and the center wire on this cord goes to the center terminal on the unit
Jul 28, 2012 | Roper REX4634KQ Electric Dryer
How to wire 4 wire power connector cord
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Jun 21, 2011 | Roper REX4634KQ Electric Dryer
I am replacing a 3 prong cord with a 4 since we have moved into a newer newer home and the dryer has a white wire attached to the frame instead of a green wire. Is the the ground and can I just place the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 23, 2010 | Roper RES7646KQ Electric Dryer
Swich 4 cord to 3 cord plug in
To switch from a 4 prong to a 3 prong. First remove 4 prong cord, save screws you will need them. Look a 3 prong, it will be flat with 3 wires next to each other with metal fittings on the ends. The 2 outside which are hot wires go to the outside screws on the block, and the center which is neutral goes in the center. The only difference in the cords is the 4 prong has a ground, in new construction this is code. You don't need a ground if house is wired for a 3 prong.
Jun 15, 2010 | Roper REX4634KQ Electric Dryer
Wiring for three prong power supply cord
If you desire to convert an appliance from a 4-prong to a 3-prong, make sure you reconnect the bonding strap and/or ground wire to the Neutral (white) wire at the terminal block.
Connections
New
Picture shown is for a range cord but is exactly the same for a dryer connection.
Feb 03, 2010 | Roper REX4634KQ Electric Dryer
Roper Dryer
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Mar 02, 2009 | Roper Dryers
I need to change the electrical cord from a four wire to a 3 wire and i want to make sure i do it rite. i do not have a manual. its a kenmore 80 series electric dryer 220v model #11062812101
You can find a copy of the installation manual at managemyhome.com.It describes how to connect as 4 or 3 wire.
Enter your model number (I had to delete the last digit), and make sure you enter Kenmore in all capital letters.
Feb 03, 2009 | Kenmore 62872 Electric Dryer
Kenmore stackable unit
Yes, you can use any safety 4-prong as long as it is a dryer cord rated at 220V.
Jan 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dryers Logo
79 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
