Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
How to change the belt on lawn boy 10685 - Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
4 Suggested Answers
SOURCE: The rear wheels will not turn in reverse at all. I
Rear wheel drives like this have pinion gears with rachet pawls that allow them to go backwards freely while locking when the transmission drives them.
You need to take off your rear wheels and carefully remove the pawls. They look like little squareish metal shaft keys with springs under them. You should notice that the keys or pawls are covered in what looks like grease.....which is actually worm metal from the pinion gear and oil mixed together to form this pastey greasey substance. Clean all that stuff off and lightly oil *( light oil...3 in 1 kind of oil) and reassemble.
You should hear the nice clean clicking of the rachet pawls as you roll backwards again!
Good luck and be careful!
Posted on Jul 01, 2010
  • 89 Answers
SOURCE: what locks in the left and right torsion springs
the proper set up on thre bar which hols thr springs is plate lock handle part 107-3946 then the right hand torsion spring 108-0953,make sure the spring hooks over the plate lock, then left hand torsion spring then bar slides through left hand hole and lever release 40-1823-03 attaches to end of bar with a set screw
Posted on Nov 04, 2009
HansPP
  • 2510 Answers
SOURCE: I have a Lawn Boy
Remove the spark plug and try pulling the starter again. You may have a fuel leakage into the cylinder and it has caused a hydraulic lock. Check/change the needle and seat in the carb as this leaking is the usual cause if this type of problem. Good luck and please rate this solution.
Posted on May 22, 2011
I have a Lawn Boy 10685. It sat for about 4 years. It would not start. I replaced the spark plug and added gas. It started right up, but the engine is high revving? what would cause this? How do I fix
Sounds like the return spring on the air vane governor is stretched. Take the shroud off and look for the paddle shaped piece of plastic next to the flywheel. There should be no slack in the attached spring. You can shorten the spring if needed with a pair of needle nose pliers.
Sep 21, 2014 | Garden
Why did my Lawn Boy Platinum self propelsion quit?
I believe there is a V-belt that drives the front wheels,it may have broken,or the gears in the gear box have failed !
Jun 22, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Model 10640 how to adjust self-propel drive cable
If the V-belt is old, you'll need to install a new V-belt first ,then IIRC,the adjustment is by sliding the bale conduit on the side of the handle.
Jun 16, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Drive gear does not engage
Cable adjustment,broken V-belt, bad gear box.
May 30, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
I have a Lawn Boy 10685 with a Tecumseh motor will it run with rear mulch switch off and either wired together or left open?
If you are getting spark, it should run, usually safety switches connect to ground out the coil to give no spark.
Apr 17, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
I have a Lawn Boy 10685. Changed the blade and went to start the mower and the pull cord will not pull. I tried spinning the blade by hand with no luck. I took the starter apart and it spins fine. I check...
May 22, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
Does not walk good.....could the cable stretch or is the belt loose or housing needs adjusting?
Check the drive belt for tension first...most likely the belt has stretched out with use over time.
Jul 06, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
1,156 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
