Question about Uniden UM525 ES Series VHF Radio with Hailer
I have a Uniden 525 fixed mount 2-way VHF radio. It has power and picks up weather with the shakespeare antenna. However radio checks have failed and i don't receive anything either. The antenna's tip is broken, does that severely affects the transmission potential of the unit? If so what antenna should i replace it with?
    Champion:
  • 204 Answers
Yes if the tip is broken, the antenna will receive, but not transmit properly. The make an antenna that has a 32" stainless steel antenna with a small metal "can". Can mount it anywhere.
Posted on Mar 30, 2011
My Solara Dsc radio, which has worked well for several years, suddenly began blowingthe 2 amp fuse on the red power line whenever the transmit button was pushed on the mic. Why?
No worries here.
According to Uniden, the 6 amp fast blow fuse is the correct one.
Not entirely sure why there'd be a 2 amp with your old radio, but I suspect the radio is good.
-Steve
Uniden VHF radio fuse Google Search
Dec 04, 2013 | Uniden Solara DSC VHF Marine Radio
Plug portable whip antenna into radio, power on with car lighter, no reception...how do I tell if radio itself is not working properly
To check your radio you will need a ANTENNA RADIO TESTER Shakespeare make a cheap tester STYLE: ART-3 works good. Good luck.
Jan 22, 2011 | Uniden Solara Vhf Dsc Fixed Mount Radio
My UNIDEN UM525 receive only near and strongly stations
First, check your antenna, could have been struck by lightning or corrosion could be setting in, if it's corrosion you would not be able to see it. Before going into your radio, try the radio with a different antenna. You never mentioned weather the radio are transmitting or not, knowing this the technition would have a better idea where to check for the problem. Good luck.
Jan 17, 2011 | Uniden UM525 ES Series VHF Radio with...
Where do I find or what is the part number/name for the extra antenna for the wham system?
The antenna is not listed as an accessory on the Uniden web site, so your best bet is to contact their Customer Service department. You can email them by following this link:
http://www.mycusthelp.net/uniden/_cs/QuestionAsk.aspx
Bill B.
Nov 07, 2010 | Uniden Oceanus DSC Wham ready Fixed Mount...
Please could you supply me with the service manual for a Uniden Solara DSC. Thanks The radio was tested and is transmitting well, however it doesn't seem to be receiving. Suspect the problem lies...
It has been my experience that Uniden won't part with their owners manual cheaply. As a matter of fact, you can probably pick up a new radio for less than the cost of a manual.
Welcome to the world of disposable electronics.
Sorry I couldn't be of more help to you.
-Steve
Jul 02, 2010 | Uniden Solara Vhf Dsc Fixed Mount Radio
My manual is not in english for my uniden dsc vhf radio
try this link and good luck.........
http://www.retrevo.com/samples/Uniden-manuals.html?cmpid=Manuals_Uniden&s_kwcid=uniden%20manual|4347054231&adsense=2257534859&gclid=CNib_Ii476ACFUpf2godCksrcw
Apr 05, 2010 | Uniden Oceanus DSC Wham ready Fixed Mount...
I have an icom m304marine vhf with a shakespeare
Sound like you have an antenna issue. Try a different antenna with coax. If the problem is still there, than you have a problem with the radio. Icom makes really good marine radios but you could have a defective one.
Jun 30, 2009 | Cobra Mr F75b Marine Vhf Radio Fixed Mount...
Transmits but does not Receive
Check your microphone by swapping with another duplicate. If no differance, you will need a SWR meter (standing wave ratio) to find the culprit. It attaches in line of the coax and determinds power out and reflected power. The reading should be 25 watts foward and max of 1 reflected.
Oct 22, 2008 | Cobra Mr F75b Marine Vhf Radio Fixed Mount...
Uniden vhf
Initially, pls check/clean your antenna, mount, coaxial cable, RF connector, power leads, grounding straps.
Based on your post description, a couple of ideas:
1. Since you receive OK, chances are the antenna/cable is good. You verify though with an SWR meter;
2. Since TX light comes on, looks like the mic, PTT and coiled cord are all OK;
3. All else works but no one can hear you, you have no power output. Use an RF wattmeter with dummy load to verify that you are pushing at least 25 watts. In the absence of a power meter, the SWR would also do or even an indication of a significant current flow to the radio ( use an inline ammeter) would indicate power.
As you will note, some specialized instruments are needed. Perhaps your best bet would be to seek the services of a qualified communications technician. TMore often it is the finals or power pack that fails resulting in no TX. In some cases, it is either the RF diode or the power regulator that causes no TX. It may also be worth your while to do a full check over of your antenna system.
Hope this be of some help. Pls post back how things turns up or should you need additional information.
Good luck and kind regards.
Jan 02, 2008 | Uniden Oceanus DSC Wham ready Fixed Mount...
Uniden UM525 ES Series VHF Radio with Hailer Logo
311 people viewed this question
Top Uniden Boating Experts
Steve
Steve
Mike Marcotte
Mike Marcotte
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Uniden Boating Expert? Answer questions, earn points and help others
