Question about Malber WD1000 Front Load Washer/Dryer
Was shaking too much. Someone came in and said it was broken, but we didn't buy a new unit. Figured out that drying rinse was too fast and made it slower. But now no water enters the tub? We opened up the water from under the sink. Is there a valve (or two) at the washer end of the water supply?
    Brigadier General:
  • 6,277 Answers
Shaking first-
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
(If this has not cured the problem it is possible that the internal suspension is malfunctioning).
Now water-
It COULD be that the excessive shaking has damaged either one or both of the water inlet valves OR disturbed plug/cable causing poor contacts with the control PCB- it's difficult to say without an engineer checking. Sorry but I suggest definitely balance the machine because it needs it and then an engineer call ;-0(
Sorry again and good luck,
John C
Posted on Mar 28, 2011
How do you adjust rinse aid dosing
"Jet Dry"... or Rinse Aid dispensers
The only problems I was able to find made no reference to adjustments of any kind... Clogging and broken/damaged covers only )inserted below).
Without your model... or actual malfunction... I can guess no further... Sorry Jeff.
You could look at these options if you wish to continue being obscure... Hope it helps.
http://cdn-d.appliancepartspros.com/0000192287_4.gif
http://www.appliancepartspros.com/bosch-rinse-aid-door-166623-ap2802335.html#autoplay
http://fast.wistia.net/embed/iframe/barj7to9ic?controlsVisibleOnLoad=true&plugin[socialbar-v1][buttons]=email-twitter-googlePlus-facebook&version=v1&videoHeight=237&videoWidth=422&volumeControl=true&autoPlay=true
Jan 22, 2016 | Dishwashers
I spilled water all over my remote. Will it still work once it dries out and how do I dry it out?
It depends in part on the water since tap water can vary a great in deal conductivity.
If you want to risk opening the housing, remove the batteries and use distilled (not bottled mineral) water and rinse the remote with it.
Shake it out and place in a warm area to help speed the drying of it; don't put batteries back in it until you are certain it has dried.
Years ago, a custom disk drive from a word processor had received a bladder full of cat u rine and it was restored as described above and worked fine for years after..
Mar 29, 2015 | Computers & Internet
Fill with water on indicator
Remove the water reservoir clean the inside and dry. Pull the filter screen and rinse. Put 2 cups of water in the container and shake well for a few minutes. Empty and Dry again. Reset as per the manual, fill to the line and with the filer removed, do a dry run without the kcup in place.
Feb 01, 2014 | Keurig B70 Coffee Maker
I bought my husband a new senso touch razor i would like to know how they rate with other shavers also are they hard to clean
Hi cuke693,
I work for Philips Consumer Lifestyle and received a Senso Touch 1180X/40 for free as part of a Home Test. I have never been a fan of electric razors because of incredibly sensitive skin and fast growing facial hair. I do however, use the Senso Touch 1180X/40 in between shaves with a manual razor, and I am very happy with it. It doesn't irritate my skin, the shave is very close, and use/care is easy and ideal. I also like the fact I can use it safely and comfortably in the shower, too.
Depending on the model you have, you can find great resources at www.philips.com/support. Just enter the specific model number to access the product specific page which includes FAQ's, manuals, videos, chat, etc. (http://ow.ly/6j6O2)
As for cleaning, these are the instructions for the 1180X/40 (again, for model specific information, visit the above website):
Regular cleaning is important to maintain an optimal shaving result.
1. Turn the shaver on.
2. Rinse the shaving unit under a hot tap.
3. Pull the top part of the shaving unit from the bottom part.
4. Rinse the bottom and top part under a hot tap for 30 seconds.
5. Reassemble the shaving unit and carefully shake off excess water. Let the shaving unit dry completely.
Sep 01, 2011 | Philips Health & Beauty
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
When we turn the power on iit only stays on a few seconds then turns off with the cst.in light flashing.. what does this mean and what can we do to fix it?? tks
I had the same problem. We watched a DVD, and the unit worked fine. We went out for ice cream, came back, and decided to watch a VHS. Instead of taking the VHS, the CST.IN light flashed and the unit cut off after a few seconds. We didn't have a VHS in the unit at the time. After cutting the unit back on several times without success, I looked online for solutions. One person said to hit 'eject' 5 times in a row, but that didn't work for my unit. Someone else said there was a lever inside near the power button that ejected the VHS, so I checked that out next. I washed and dryed my hands well, and used my finger to jiggle the white lever. Then I saw that the tray that the VHS sits on wasn't all the way forward, so I gently pulled and pushed it. I'm not sure which of the two actions worked, but my light is now a steady green and my unit is working fine now. I am so glad because we've had this unit for almost 10 years now, and I really didn't want to have to buy a new one! Good luck!
Jan 17, 2011 | Emerson EWD2202 DVD Player/VCR
The cst.in function on my dvd/vcr is blinking and because of it, i can't work my dvd/vcr. What can i do to fix the problem?
Jan 16, 2011 | Emerson EWD2202 DVD Player/VCR
Water wont come out
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying something else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 21, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
My Proheat will not **** up water anymore
I have a Proheat 2X and had the same problem. I don't know if this will work with your unit... but I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing. With the dial set to "Tools", I had the same problem.
SO, an alternative to throwing out my unit and buying something else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW on carpet & tool settings. Don't know if this will help you, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 19, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
I recently bought a different type of dishwashing detergent for my Frigidare dishwasher and my dishes look as if they have not been rinsed. They cycled all the way through the drying cycle so the detergent...
the best way to use your dishwasher is the way it was designed.
if your unit has a compartment for jet dry or rinse agent then you should add and fill that compartment with rinse aid. try not to buy soap with any extra like soap with jet dry or shine plus . because when you fdo that sometimes customer think that they dont need rinse agent . big mistake. rinse agent is deposited at a certain time in the cycle. diod you know that is you use lets say jet dry and a soap with shine plus or rinse aid in soap the machine can over suds? as a tech trust me i have seen it.let me know if i was helpful. drop a 4thumbs up post
Feb 28, 2010 | Dishwashers
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
53 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
