Fine grey powder collected in rim of washer and all over clothes
  • 2,510 Answers
What you probably have is a build-up of scrud in the machine as a result of an interaction between the fabric softener and the detergent. This flakes off and marks the clothing.
Buy a commercially available cleaner for your machine for this purpose of do one or two cycles using a bottle of white vinegar in the tub without detergent. Clean the machine out doing another cycle using baking soda directly in the drum. Repeat this process if there are still any indications of scrud.
Take care that you use the correct amount of detergent in your machine according to load and water level and do a cleaning run about every 25 wash cycles to clear away any excess detergent that was not caught by the rinse.
Posted on Mar 28, 2011
The Neptune front loaf washer has been collecting
1. Purchase and use washer cleaning powder.
2. When not in use, leave door open.
Sep 01, 2014 | Washing Machines
Water not drane setisfewctori Cloth not dry
There are 2 possible reasons for this .The drain for the washer may be kinked at the back preventing the water being pumped out . The pump is virtually a water circulator and not a pressure pump so any obstruction will keep water in the washer.. Next --the spin cycle may be to slow for the water to be spun out of the clothes. Check the load is not above the recommended weight as this makes the spin cycle slow. IT is better to do 2 washes rather than to cram it all into 1 wash. Check the filter at the pump as they tend to block up with lint and other gunk from the clothes and the water may be unable to get to the pump Powdered detergents are 90% clay( fine as talc powder and used to carry the detergent) and this settles out in the lower parts of a machine so if you use powder I would recommend changing to liquid
Mar 11, 2014 | Bosch Classixx WFL 2066 Front Load Washer
I have a 5.5kg Top Load Fisher & Paykel Washing Machine MW512. The clothes seem to come out with alot of dust particles on them. Is there somewhere in the washing machine where it is collecting this...
Hi - are these particles kinda ash grey black in colour? if they are then the bellows have sprung a leak.. unfortunartely the only way is to replace the inner stainless drum.
Inspect the top of the bowl for any signs of structural damage along the grey plastic housing as it contains very fine sand used to counter balance the inner bowl.. on rare ocassions these leaks and give you the particle effect similar to what you've described..
Aug 12, 2011 | Fisher and Paykel Fisher & Paykel Washer
Hi,I have a Simpson eziset 450. The problem is that when we make it wash our clothes,when it finishes,the clothes came out all spotted!grey spots..like if they've been done by dirty water..what's the...
you have sportac build up in your pipes and barrel you need to run some dish washer cleaning solution through the machine on hot wash this will kill and remove all build up try using a liguid detergent not powder in the future
best of luck
please rank this advice thumbs up it it helped
Jan 18, 2011 | Washing Machines
I get dirty streaks on cloths during the wash cycle.
It's a common problem with modern machines.
Due the modern way of washing on low temperatures some dirt will stick into the machine's.
You can try to wash some old stuff several times on a high temperature and instead of using washingpowder you have to use a handfull of soda.
It will clean the inside. Worked fine overhere.
Good luck,
Gerard
Jan 20, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
The washer smells,had the problem before the repairman took it apart, I cleaned the white plastis rim on the tub,solved the problem soap buildup we need to know how to take it apart to clean it
Dont !! Try doing a hot wash with a good dose of Washing Soda Crystals and no clothes (An empty washer not a visit to a nudist colony). Also go back to Old Fashioned Soap Powder for a while. Cold wash powders and low teperature washes do not dissolve the fats which are washed out of the clothes and they build up causing the smells. Old fashioned powders had some bleach and soda in them which kept the problem at bay
Jun 14, 2009 | Whirlpool Washing Machines
Black marks on clothes after washing
Try running a few caps of CLR in the washer (without clothes, of course!) Then run a few cycles with no additives. I've heard that powdered lemonade works also. Might be safer to try first. Good Luck!
May 23, 2009 | Washing Machines
Bad bosch
The grey sludge may be due to incorrect soap powder (use only front loader) or excessive powder use. Minimise the powder use and insure you do a very hot wash once every 4 weeks to break down powder that may be building up.
Regards Sam
Apr 15, 2009 | Bosch Classixx WFO 2466 Front Load Washer
Our washing keeps getting bleached spots / areas. Clothing has light patches.
it wont be the machinei think.
try doing a hot wash cyle on an empty machine with some descaler powder or soda crystals to clean it out.
Aug 25, 2008 | Hotpoint WMA58 Front Load Washer
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
