Question about Eureka 4870SZX BOSS SMARTVAC PET LOVER Bagged Upright Vacuum
My vacuum is blowing out instead of sucking in. It's blowing the cover of the hepa filter right off! What is causing this problem and how can it be fixed?
    Genius:
  • 1,400 Answers
Hello
Possible clogged hose.Run a broomstick or long pole through the hose to unclog it.
Then check your prefilter should be down by the front light,should be washable.
Last... be sure the hepa filter is clean an in the right way.
Posted on Mar 28, 2011
Why cant i keep my hepa filter and cover on my new navigator?? help?
Are you sure that you are correctly connecting the filter, and flipping the tabs to "lock" it into the "closed" position.
Jun 13, 2014 | Shark Navigator Bagless Upright Vacuum
Vacuum appears to be blowing dust out rather than sucking up dust
Check Hepa Filter if it has one or other resevoir for excess dust/dirt. Clean receptacle and replace filter.
Sep 23, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
My hoover upright started blowing instead of vacuuming; it blows out of the attachment connection also when I try to use that.
Is this a bagless vacuum? Some Hoovers work in the opposite from conventional designs; the dirt is blown into dirt cup instead of sucked into a paper bag. If you have this type of vacuum, check the HEPA filter (and any prefilter, if applicable) and gently clean it so as not to damage the filter media.
If this does not help, please resubmit your request with a model number.
Good luck from Detroit, MI.
Jul 19, 2011 | Hoover Vacuums
What filters do i need for the eureka the boss bagless vacuum w/widetrack modal 4495
There is a Cassette Micron Filter 60696.If you have a HEPA cartridge filter you need EUREKA's HEPA part 61500.In earlier models there is a micron filter instead of a HEPA filter--for that you need EUREKA's Micron part 60801. But if you have that HEPA filter, the manual says you have to use the HEPA filter to achieve the closed HEPA filtration system again.
Dec 10, 2010 | Eureka 4495A Bagless Upright Vacuum
Vacuum blows out dust/pet hair etc. when in use
try replacing the belt if you havent. it almost sounds like your getting weak aggitation. if thats not bad, check for a clog in the brushroll housing nozzle right on the inside by the tube. Replace the inside hepa filter if you havent within the last 3 months.
Jan 04, 2010 | Hoover U5753-900 WindTunnel Bagless...
Our dirt devil vacuum is blowing out air instead of pulling in air.
my dirt devil is blowing out air instead of sucking up.Tried new bag.any other solution to fix
Aug 29, 2009 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Dirt Devil Upright Bagless Vibe Vacuum no longer sucks
Sounds like there's a clog in the long hose that connects to the dirt canister. Remove the hose completely and check for clogs. There is a blue plastic piece that the hose is attached to. You can remove it by taking out the two screws in the back, and the four screws behind the dirt canister. Once those are removed, the hose comes away from the vacuum with the blue plastic piece attached. That should allow you to check for clogs. If necessary, take the hose outside or a place that is well lit, so you can visually verify the absence of clogs.
Mar 09, 2009 | Dirt Devil M087700SV Bagless Upright...
Dysin vacuum blows air instead of sucking it!
If it is blowing air, then it is still clogged up somewhere, you didn't give your model number, but some of these have removable covers on each side and on the back. Also make sure that all covers are back on securely.
Jan 07, 2008 | Vacuums
Eureka 4870SZX BOSS SMARTVAC PET LOVER Bagged Upright Vacuum Logo
1,524 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
