Question about Music
I have an Ibanez Acoustic Electric 5AEQ45F. The top part of the pick up became disconnected. One wire, a white one with a female connection, became disconnected and I cannot find where to reconnect. Please help? :)
  • Songbird03 Mar 29, 2011
    I looked all over the internet for a diagram, to no avail. Thank you for your answer. No wonder I couldn't find where it went lol :)
    After your post and trying to fix my guitar, I realized the pick up that looks like a wire under the fret board was not what I was referring to. There is a white cord off the top of the hardware cover that the pick up plugs into. Where does that cord go?
  • Music Master
  • 5,603 Answers
Realize that there is a white pickup that looks like a wire that ITSELF is the pickup which goes under the bridge. It works like a capacitive mic. One end will be unconnected. This lays in the groove under the bridge.
Posted on Mar 28, 2011
  • Fred Yearian Mar 29, 2011
    I have spent an hour looking for an exact schematic without success... here is a link to a site that has many that one can compare the resources of pickups, pots, etc and maybe get a clue to the connections. DO NOT count on wire colors... they vary:
    http://www.guitarelectronics.com/categor...
My Ibanez acoustic electric has very weak volume and makes a constant white noise hiss when plugged into an amp or sound system. Batteries are new as is the pre-amp and under saddle piezo. Ideas?
It will be either the saddle pickup or the guitar pre amp. If you unplug the pickup and the hiss is gone, there was your fault. Otherwise fit a known good pre amp.
Feb 02, 2017 | Ibanez Music
I need the wiring diagram for an Ibanez AS153 semi hollow body, where can I get one?
the 153 is wired like a Les Paul or SG
2 humbucker, 2 vol, 2 tone
with the addition of a 3 way coil tap for the neck pick-up
wired similar to:
http://www.guitarelectronics.com/product/WIRING_MOD_HB0066/Guitar-Wiring-Mod-HumbuckerOFFParallel.html
Aug 16, 2016 | Ibanez Artstar Series AS153 Semi-Hollow...
Ibanez Pre amp problem
It sounds like the guitar pickup may be faulty. It may be a loose connection on the which could be soldered easily or it may be damaged in some other way.
As this is isolated with your G string, I suspect the individual pickup unit is at fault.
Apr 16, 2014 | Ibanez Music
Jack female connector type
switchcraft
your standard 1/4 in mono female jack.
Mar 18, 2014 | Ibanez RGD Series - RGD321 Electric Guitar...
When i plug in to an amp i have no output
Check you battery and/or connections. You need to know in particular if the pickup wire is intact, and going to the volume/tone preamp. There would also be another wire going from the preamp to the plugin socket. If it uses a battery, check the power connections there. I hope this helps
Mar 12, 2014 | Ibanez EW20-MBE Acoustic-Electric Guitar
I have a Ibanez V Series V70CE. It play well. But sometimes when I connect it to the amplifier, there seems to be loose connection and no sound is heard. When I move the wire little bit sound come...
Many try to use poor quality guitar cables and have the problem. The sleeve of the guitar cable plug turns on the battery in the guitar. Always loop the guitar cable through your belt or the guitar strap to avoid the cable wisting the plug in the guitar causing noise and WEAR that wears the plug sleeve to the point it no longer will activate the guitar.
Sep 18, 2011 | Ibanez V Series V70CE Dreadnought Cutaway...
Hi, My Ibanez AEL 20 has a preamp - tuner 5AEQ45F. Tuner works but there is no signal in output jack. Guitar is quite new, and the preamp hasn't been used before. Can I get a PCB schematic diagram...
Remember that while in tuner mode, the audio output is disabled. Try additional presses of the tuner button to see if the audio comes back on. Also verify the volume and EQ gains are turned up. Verify the battery is new.
May 30, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
Ibanez acoustic/ electric mandolin top caced in on upper side next the fingerboard.
Take it to a luthier (find one with google or in the phone book) to see if it can be economically repaired.
Nov 28, 2010 | Ibanez M522S F-Style Mandolin
Music Logo
472 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
