Question about Sport & Outdoor - Others
I have a 98 Mach Z 800 triple ski doo and need help with how to get the ski doo to stop jamming in between reverse and forward? and how to get it unstuck from reverse/forward
2 Suggested Answers
  • 85 Answers
SOURCE: I have a Ski doo 583 RAVE motor theat backfires
It sounds like you have a reed problem they should be in a "cage" just behind the carbs on the cylinder and if they were missing a piece or if they were cracked it would cause the engine to backfire. If they are in good condition they should close against the cage and stop the back pressure coming through the carbs.
Posted on Jan 21, 2010
Where do i get a tool to adjust belt tension on a 1989 ski-doo mach-1
COPY AND PASTES THIS ADDRESS (http://www.vintagesnow.com/Ski-Doo_files/1989_SM.pdf) INTO YOUR BROWSER'S ADDRESS WINDOW AND DOWNLOAD THE EXCELLENT MANUAL FOR YOUR VINTAGE SKI-DOO. READ IN DETAIL THE DISCUSSION ON BELT TENSION
Dec 29, 2017 | Cars & Trucks
1990 ski doo mach 1
You have dirt in the carburetor jets and or passages, clean the fuel tank and rebuild the carb.
Dec 20, 2016 | Winter Sports
What should the crompression be on my 98 ski doo mach z triple
125-140 is Ideal, Not only do you want a higher compression but you also want them Balanced. The PTO (Clutch Side) normally will indicate a lower compression because it is the cylinder to go FIRST. So if that number is lower, you might be looking at a Top End Rebuild that is fairly easy to do. Anything less than 90, and you won't get a good fire going and normally will not fire below 70. hope this helps..
Oct 29, 2014 | Winter Sports
04 summit adrenaline dies every time i put it in reverse what could cause this to happen
This happens with my 800 HO, I replaced the Plugs and Viola... Problem is now gone
Mar 23, 2013 | Ski-Doo 2004 Summit Adrenaline 600 H.O
My 04 skidoo summit 600 HO dies every time i try to put it in reverse what would cause this to happen
my 800 Summit does this also, it is my sign that I need to change my Plugs. and EVERY TIME, it works...
I have 95 Ski-doo formula z 583 and last weekend i lost my lights and all gauges and reverse beeper. any ideas what could be problem
check the fuses?if not then there must be a burnt wire someplace close to the exhaust manafold ,either that or your selonoid is burnt out.
Mar 07, 2010 | Simon & Schuster Ski-Doo: X-Team Racing...
Ski doo x team racing problems please help me
Try running in compatibility mode. Rightclick the shortcut, select properties>compatibility>check the box that says: run in compatibility mode for: and select an OS.
If that doesnt help I'm afraid you gotta actually run windows 95, 98, me or 2k to get it to work.
I hope this helps,
Yannick
Feb 17, 2009 | Simon & Schuster Ski-Doo: X-Team Racing...
Sport & Outdoor - Others Logo
24 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
