Question about Saws
Can anyone help please ive just got hold of a black and decker DN339 band saw and want to cut max 50mm soft wood with the grain using the fence to slide against, only the blade is tilting towards the fence as it cuts, cuting a wedge shape in appearance and not cutting straight, I have tried to ajust every thing but to no avail, can any one shed some light or let me know how to set it up, thanks in advance.
  • 2,510 Answers
That is usually an indication that the blade is blunt and one side has lost its edge more than the other. The blade will wander towards the sharper side. You will have to replace the blade. For soft wood you need about 4-6 tpi. and a cutting speed of about 1000 - 1500 ft/min.
Posted on Mar 28, 2011
Length of band saw for 7 1/2 black and decker band saw blade
I get my band saw blades on www.sawblade.com . I cut both wood and metal. I'm using their Carbon and Bi metal blades. Give them a call.
Aug 12, 2014 | Saws
Black decker dn339
Have you tried with black and decker? Try to email them, they might send you a copy. It's an old band saw, it's hard to find a diagram.
Jan 06, 2014 | Saws
Dose not cut in a straight line wonders
First question: What are you cutting? Are you cutting wood? If you're using fence, I need you to make adjustments on it . The nature of the band saw is to drift either left or right being parallel with the band saw fence. Is the blade tension too tight or insufficient? Check your manual for correct tension or you can just see in the tension gauge on your saw. Please this blog on how to check the correct blade tension . What is your feed and speed rate? Make sure the you're not feeding the wood too slow or too fast. Are you using new blade? Your blade is may be dull or low quality. I purchased my blades on www.sawblade.com . Their Haltbar 201 Series works great on general wood cutting.
Last question, have you taken up time to tune up your saw? See this blog for your reference.
Sep 11, 2013 | Craftsman Saws
I can't get this saw to cut straight or square I
Band saws pull to one side on straight cuts, it's a function of the blade torque. My 14" saw pulls to the right. There's nothing you can do to stop this, you have to be aware of it so you account for it on free cuts and know to put your fence on that side so the wood pulls into the fence instead of away from it. Squaring the blade to the table is easier. Do not go by the tilt angle guide. First make absoutely sure all of your blade guides and bearings are properly alligned so they aren't pushing the blade out of line. Use a square to get it close then: using a 4" x 4" block of wood, make a light cut in the wood only deep enough to mark the wood from top to bottom. Turn the block over 180 and try to make a cut in the previous cut mark. If the cuts line up you're there. If you get a V or X you have to make adjustments to the table making sure you tighten the trunion locks tight. I had one of these, it's not a high end saw so don't expect a lot from it.
Aug 23, 2010 | Ryobi 9 in. Benchtop Band Saw
Adjust angle of band saw blade to align with fence
Typically the fence is attached to the table and the table can be angled to create a bevel.
Using a square, align the table so it's square to the blade. Assuming your fence is square to the table vertically, you're good.
With most bandsaws I have worked with, there is a positive stop (typically just a bolt - the head acts as the stop) underneath the table so when you tilt the table, you can return it to flat without having to re-square everything up every time. Once you've got things square, make sure to adjust the positive stop too.
Be aware you may still have to compensate for drift with your fence, though.
If this answer was useful, please vote. Thanks!
May 23, 2010 | Black & Decker 14" Hd Multi Cutter Saw
Cutting straight
this is usually caused by a dull blade or you need to carefully re-adjust the blade guides
Aug 12, 2009 | Ryobi 9 in. Benchtop Band Saw
MAX thickness of wood that this band saw can handle
Generally that's the limit. But to feed a piece that thick, you'd have to have a sharp blade, well adjusted guides and a pretty slow feed rate, depending on the species of wood. I'm guessing the saw will bog down and refuse to cut long before you reach that thickness, unless you have the patience of a saint and don't mind standing there feeding the board through a cm at a time.
Well- tuned it will definitely cut better, but these little portable saws are generally underpowered in my experience..and work best for 3/4" or less thick boards.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 27, 2009 | Black & Decker BDBS100 9-Inch 3.5-Amp Band...
Manual & fence system
I would contact the nearest Rockler woodworking store. they have or can get it for you.
please mark this as a fixya!
Mar 12, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
Straight cutting with rip fence
when i use my table saw, i use clamps on the fence, i dont rely on the one built in.
Feb 26, 2009 | Craftsman 1/4 x 72-5/8" Band Saw Blade, 6...
Saws Logo
159 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
