Question about Cameras
My sony cybershot w220 is displaying E 91:01 and its flash is not working. I tried initialize and set date and time but the problem is not solved.
  • 63 Answers
SOURCE: Sony DSC-W50 Flash Error code-E:91:01
I have a method to stop the E:91:01 error flashing on the screen.it were not solve the flash function but atleast you can use the camera without flash. 1)at setup do a initialize. 2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again ) by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.hope it help.
Posted on Aug 05, 2007
SOURCE: Flash
i think the firmware is corrupted ..... you must install new firmware ....
just visit the nearby showroom or technician he will install the new firmware ..........
for installing firmware it may costs some 300 to 400 bugs ....
how ever there may be other problems too may be the battery is dead just change battery and check....
check whether it is detecting in pc or not..........
Posted on Feb 11, 2008
  • 74 Answers
SOURCE: e:91:01
hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
Posted on Oct 17, 2008
  • 74 Answers
Press Menu button
togle down thrice from camera to setup 1
If it is working then don't forget to set your Clock.
Posted on Oct 31, 2008
SOURCE: Flash not working on Sony CyberShot DSC-P93A digital camera
The flash on my Moultrie gameSpy 4.0 (D40) quit working. I can trigger the camera and see the flash is very week. Batteries are 100%. Can the flash be ordered and replaced?
Posted on Nov 30, 2008
Setting time and date
Press on menu key>settings>initial setup>time and date.
Here's a free User Guide for your phone.
www.consumercellular.com/Content/PDFs/Manuals/Motorola_W220_UG.pdf
Thanks!
Jan 03, 2012 | Motorola Mobility W220 Cellular Phone
Camera will not come on, it says "turn the power
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Jun 19, 2011 | Sony Cybershot Dsc-w290 W230 W220
SONY DSC-W220/B My camera is displaying a message E:91:01 and will not flash. What do I do?
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
If this does not work do this:
THE MASTER RESET
(1) remove the battery pack
(2) press and hold the power button for 30 sec
(3) after put the battery back do not turn it on for 1 min
(4) turn on
May 27, 2011 | Sony Cyber-Shot DSC-W220/B Digital Camera
Sony cybertshot camera dsc-w220, need to change language from Japanese to English
Press HOME to display the home screen. Use cursor-left/right to select Settings (toolbox icon). Use cursor-up/down to select Language ("A" icon) and press * in the center of the cursor pad.
Jan 30, 2011 | Sony Cybershot Dsc-w290 W230 W220
How do you change the time on a Motorola w220, not display the time actually change it without resetting the whole phone?
You don't actually have to reset the whole phone, go to the Menu,click on the "Settings" option,scroll down the options that are there and select "Initial Setup", it is the sixth option on that dropdown list, select it and click on Time and Date option,check whether the "Auto Adjustment" box is checked, if it then remove the tick and then set the time or date as you wish,without setting up the whole phone.!
Nov 23, 2010 | Motorola Mobility W220 Cellular Phone
SONY CYBERSHOT DSC - H3 DIGITAL CAMERA FLASH PROBLEM
Hi Jim,
Have you tried resetting all settings on the camera? On a Sony camera, it is called "initialize". The initialize setting is found by going to the menu, and tabbing down until you find an option called either "reset settings" or "initialize settings" and then confirm it.
Many times that will fix the issue, in case something has either been enabled/disabled on accident, or the software is sticking (which happens from time to time)
Feb 17, 2010 | Sony Cybershot DSC-H3 Digital Camera
No flash and screen flashes "E:91:01"
Hi!
The error E:91 indicates a hardware malfunction in the Camera. In this case, you may try resetting the Camera to the original factory settings.
Follow the steps given below to reset the Camera to the original factory settings:
(a) Press the Menu button to display the menu screen.
(b) After pressing the right arrow on the control button, go to the (setup) setting, then press the right arrow again.
(c) Next, press the left/right/up/down arrow on the control button to select "Setup 1" option.
(d) Then, select the "Initialize" option OK, OK.
(e) Set the clock if date and time screen appear.
(f) Next, turn off the Camera and remove the Battery pack and press and hold the power button for 30 seconds.
(g) Then, reinsert the Battery pack and turn the Camera ON.
Performing all the above steps will reset the Camera to the original factory settings. After resetting the Camera to the original factory settings, please check the operation of the Camera.
If the Camera continues to display the error E:91 then service will be required.
Regards,
Pacific.
Aug 23, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Error message E 91 01
flash error for sony cybershot dscw55 ERROR CODE E:91:01 1st go to SETUP MENU then select the toolbox icon 1 then select "INITIALIZE" press ok, master reset then it goes back to normal
(DOWNLOAD & SAVE PICTURES BEFORE MASTER RESET AND KNOW THAT YOU WILL HAVE TO SET UP TIME&DATE)
1. Turn OFF cam
Jul 06, 2009 | Sony Cyber-shot W110 Digital Camera
Cybershot will not store clock settings
Hi!
The internal battery is bad. It has to be replaced. Contact your local Sony service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
I work in Sony service center.
Tom
Jul 06, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
E:91:01
hi there
Oct 11, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Cameras Logo
62 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
