Question about GE JX2030DMBB Optional 30" BuiltIn Kit Black Microwave Oven
My Whirlpool MH6140XKB over the range black microwave oven has rusting in between the door panel. What can be done to repair this?
SOURCE: Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Posted on Sep 24, 2007
  • 140 Answers
SOURCE: Rust forming between the glass panels in the door
Actually if you can use a screwdriver you can fix this problem yourself. The glass can be accessed by taking off the screws holding the inside panel to the door on. The screws are visible. Once this panel is off you will see the screws that hold the plate glass in. Keep in mind that the gasket that goes around the glass and inside the door panel are there to keep microwaves from escaping. So in all this be sure to put it back in place right. I have fixed many doors and there really is nothing to mess up. Just put it back together the same way you took it off but in reverse of course. As far as cleaning the glass there is a product call Goof Off that comes in a spray. They sell it at Lowes or Home Depot either one. Use steel wool that you can get there as well and spray a generous amount on the steel wool until it drips slightly and not on the glass directly. Clean all the areas and kinda of use a dry rag to wipe off any excess. After you've taken care of the rust stains and are satisfied take a good glass cleaner like Windex and clean it like regular glass. Keep in mind that the whole door will come off and completely apart to get to both glasses and in between. I would comment additionally that what is in between the glass may be that way due to a leak through the gasket around between the inside and outside glass. However, inspect the gasket well and if you need to you can find a replacement through the dealer or manufacturer of that brand. Keep in mind also that leakage from the microwave door in any way could hurt someone with a heart pacemaker if they get close or someone else that has a battery in it such as people with embedded health units for muscles spasms after back surgeries and the like. Those are the most critical health issues to consider and to be sure that your gaskets are good.
Posted on Jan 22, 2009
  • 140 Answers
SOURCE: Condensation marks on microwave door
For most microwaves the process is pretty straightforward. You can open the door and you will see the screws that hold the outerinside panel on to the glass. After you remove those screws you will see the screws that hold the ouside cover to the door in place. Once you get that far you will see what is holding the glass in place. Keep in mind to replace the gaskets around the glass right and anything you take off to get to the glass itself. If you are getting condensation from range top cooking then the seal around the glass may need to be replaced. You really cannot hurt anything by taking it apart, but it needs to be put back together exactly the way you take it apart. Good luck and hope this helped.
Posted on Jan 26, 2009
SOURCE: my microwave oven has are rust spots;can I paint over them?
Yes, you can paint over the spots and no, it's not dangerous. I'd let the paint thoroughly dry before using the oven -- it could otherwise cause paint to buckle/ripple/etc.
Posted on May 03, 2009
Sailorm0on
  • 61 Answers
SOURCE: Rust inside the microwave oven
This is just okay but if you're quite doubtful you may bring this to any appliance service center for repaint
Posted on May 15, 2009
Samsung over the range microwave oven model# SMK9175ST the microwave part stopped heating
If "everything" works and your microwave just stopped heating, the problem might be with the internal door switches, the high voltage circuitry, or the circuit board or quite probalby your magnetron is dead. If you don't have the technical knowledge to repair microwaves, you should take it to a repair service for diagnostics.
Jul 16, 2015 | Samsung 1.8 Cu. Ft. Over-the-Range...
How can i replace the front door panel that has cracked at handle . it is whirlpool microwave above range style
I advice you to take it to a repair centre. There should not be a micro wave leak after replacement. leak is harmful !
Dec 10, 2014 | Whirlpool Microwave Ovens
How to replace door handle on whirlpool microwave model MH2155XPS-0
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. Several of these sites also have helpful exploded view parts illustrations to assist you with parts identification and how disasemble/reassemble your appliance. A replacement part number for the model you have listed is 8169738.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
If you have any questions, please post back and let me know. I hope this helps you.
Apr 21, 2011 | Whirlpool MH2155XP Microwave Oven
Replace handle on whirpool microwave
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
If you have not purchased a new handle yet, the part number is 4359474 (Black) and 4359473 (White) and costs about $30.
Aug 12, 2010 | Whirlpool MH7135XE Microwave Oven
Can't take down/unsinstall over range whirlpool microwave
You can download the installation instructions for this model here.
Essentially you'll take it in reverse order.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 28, 2010 | Whirlpool MH7140XF Microwave Oven
I have rust like streaks inside my Whirlpool Microwave Door Panel. It is unsigthly. How do I get rid of the rust-like streaks?
Disassembling the door is a major pain and the streaks will likely only be faded not removed completely. Best solution is replace the door. Otherwise taking it apart(and not damaging it) is your only option.
Eric
May 19, 2010 | Whirlpool MH1140XM Microwave Oven
Error message on a whirlpool microwave oven ''F2 H2 Hood Keys scanning''
The F2 H2 error code refers to a faulty hood/light switch. This is a combonation board located just behind the buttons on the left panel. The part number for the switch board is 8206049. Since the screws holding this left panel on are only accessable with the door of the microwave removed, I would recommend this repair to be done by a profressional repair person.
Apr 18, 2010 | Microwave Ovens
The bottom portion of the handle just cracked. It's still attached at the top, but I want to replace it before that weakens too. Is it something I can do myself with limited "fix-it" skills? GE Profile -...
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
Replacement parts can be found at any of the following sites:
appliancepartspros.com
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
Aug 15, 2009 | GE Profile Spacemaker Over-the-Range...
Mh6140xkb door glass has rust and stains
If there are letters and numbers after the model you listed the parts are here. http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=mh3184
Jul 11, 2009 | Whirlpool MH3184XP Microwave Oven
Microwave doesn't heat, plate doesn't turn
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jkfjfk
Jan 26, 2009 | Whirlpool MH3184XP Microwave Oven
GE JX2030DMBB  Optional 30" BuiltIn Kit  Black Microwave Oven Logo
241 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
