HP DesignJet 350c InkJet Printer Logo
Posted on Mar 28, 2011
When the switch is pushed the indicator lights go on for an instant then turn off.
Anonymous
Level 1:
  • Contributor 53 Answers
  • Posted on Aug 30, 2011
Anonymous
Contributor
Level 1:
Answers
53
Questions
8
Helped
22805
Points
69
This is a powre supply problem and could be fatal. They used to be available as a spare but are no longer. The power supply is the same as on the 430/450 and 750 so you may get lucky.
Wire diagram for 2013 honda 500 power steering wont work?
Is the check engine light or other light on? It should be if there's an issue, but check this info out below and hopefully it'll get you going! Usually if the light is on and no power steering is the issue, a simple reset will fix the problem. Instructions are below and I've posted more info below as well.
You can reset the computer by disconnecting the battery cables for a couple hours. Or this procedure below.
Step 1. With the vehicle stopped, put the gearshift lever in "N" (neutral), be sure that the neutral indicator comes on and turn the ignition switch to "off". Step 2. Turn the ignition switch to "on" while pushing the UP and Down shift switches (gearshift switches) simultaneously. The "N" on the gear position indicator starts blinking. Step 3. Within 5 seconds after turning the ignition switch to "ON", push and release the gearshift switches in the order of UP switch, Down switch, and UP switch. (Do not hold onto the switch) The gear position indicator displays "- -" to indicate the system enters the intial setting mode. If more than 5 seconds elapse or the procedures are incorrect, The "N" stops blinking and stays on. Repeat the procedures from step 1 at this time. Step 4. Move the throttle lever to fully closed position, then to fully open position, and then move it to the fully closed position again within 5 seconds after "- -" displays on the gear position indicator. Step 5. When the initial setting procedure is complete, the indication on the gear position indicator changes from "- -" to "N". If the "- -" on the gear position indicator blinks, repeat the procedure from step 1.
1731d803-999f-4c1e-8f09-1c75adb10b35-mllhxmajfunukklrwo4s204y-3-65.jpeg bd95a625-bc2f-4455-82a0-c844e8b6b96e-mllhxmajfunukklrwo4s204y-3-77.jpeg 32f760fe-4486-42f8-a9e8-665f84241bb5-mllhxmajfunukklrwo4s204y-3-90.jpeg 8b9eb16d-9ef9-4aee-a115-bb46e0344cd9-mllhxmajfunukklrwo4s204y-3-104.jpeg
How turn on my fog lights on 99 montana or its turn on by itself
Fog Lamps The fog lamps switch is located in the instrument panel switchbank. Push the fog lamp symbol on the switch to turn on the lamps. The indicator light will glow. Push the ribbed part of the switch to turn them off. The indicator light will go off. Your parking lamps or headlamps must be on for your fog lamps to go on.
http://www.pontiac.com/content/dam/pontiac/northamerica/usa/nscwebsite/en/Home/Owners/Owner_Resources/Manuals/en/us/1999/montana/1999-pontiac-montana-owners-manual.pdf.pdf
Page 2-63 of owners manual
1helpful
When I turn on either left or right indicator both indicators light up
try pushing the hazard light switch again. what you have is the hazard lights in operation ( both sides indicators working) In normal indicator operation power from the flasher unit is directed to which ever side you select but by pressing the hazard light switch the indicator power lights up all lights.
1999 nissan pathfinder brakes lights stays lit when ignition switch is turned off
the brake light switch will work without the key in the ignition if you push on the brake pedal, its just the way its designed. if you were to test the switch with a test light one wire is always powered up and the second wire is only powered when the brake pedal is pushes to activate the switch. if you test both wires without pushing the pedal I think you will find you have power on both wires indicating the brake switch has shorted and is working all the time. replace the brake switch.
1helpful
2answers
1999 jeepcherkee brake lights stick
Check your Brake Light Switch, more than likely it is broken. It is located
UNDER THE DASH
1/2 the way up the BACK SIDE of the BRAKE PEDAL
I have a 2000 Dodge Durango and I keep blowing the fuse for instrument lights and tailights
hello same pronlem with my 98 durango but right turn signal!
what it was is the 4 pin connector for the tow package had the insulationripped off them i guess whe backing out of a steep driveway it sxrapped! so the headlights, turn signals, and brake circuits where grounding out! quick fix!
just cut and capped that mess!
good luck
Left turn indicator intermittent how to fix?
The turn signal indicator switch could be corroding (getting rusted on the inside). You could take it out & break the corrosion/rust & lubricate it with wd40 & put it back in..hopefully it solves the issue. If not, then you might need to get another indicator switch. You start off by taking off the steering wheel neck panels
My running lights will not work at night when i have my headlight switch set to auto on i have a 2008 gmc crew cab
At this website www.reliable-store.com I found all complete guide,much better language, complete detail in 800+ pages, ..and they also have live
chat for instant help feature
I think mines doing it too
the daytime running light module needs to be replaced.
k24674
Grand Canyon Tech
Grand Canyon Tech
