Question about Roper RAS8445KQ Top Load Washer
Runs the cycle but does not seem to wash or spin
My washer currently is not filling with water, washing, and is leaking from the bottom. so what is wrong with it
Posted on Apr 21, 2011
Washer not spinning
Does it make any grinding noise or other sounds when it is spinning?
Nov 03, 2012 | Zanussi Washing Machines
Machine runs wash cycle but fails to drain and spin. When door unlocks I remove and replace wet washing then switch on rinse and spin cycle. This seems to work but is no long term answer.
Hi, The washer will fail to spin if there is too much water in the machine, check the filter on the machine is not clogged or blocked if it's not then the pump could be suspect, normally you can hear it running on the spin cycle. it could also be the motor brushes are worn.
if its none of the above I would suggest that it maybe the pressure switch or pressure switch tube blocked other than that the last resort is the programmer or motor control panel.
Hope this helps.
Feb 09, 2011 | Hotpoint Aquarius WD63 Front Load...
Knocking in washer
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
good luck.........
Mar 28, 2009 | Maytag Performa PAV3200
SPIN CYCLE PROBLEM
Replace both the wax motor (part of door lock),2nd,at the same time replace the main upper Control board.You will solve this problem.
May 17, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing machine doesn't woir in spin cycle
There are several possibilities...depending on the brand. The most likely is that the timer is bad....but I would check the safety switch on the lid frame first. It should close electrically when the lid closes...If not, it will wash but not spin.
Dec 31, 2007 | Washing Machines
Whirlpool gold washing machine
It is either a timer issue or a motor issue. I know, that you knew. But if you have a motor with like circuitry and size, you can try that or to put it into the spin cycle and see if it is a mechanical obstruction or with a voltmeter see if the timer is working.
Apr 19, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Roper RAS8445KQ Top Load Washer Logo
18 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
