Computer recharger Hi, I have a gateway laptop T-6321 . I want to bring it in Europe.(this is where I will use it) . The problem is with the plugin and the different voltage that we use back home. I have a head that I could attach to the plugin but is this going to affect the laptop because of the lower voltage that we have there ? Should I better buy another recharger ? or a head transformer plugin attached on it ? What would be the best solution ?
    Brigadier General:
  • 6,966 Answers
To my knowledge most current laptop AC adapter are designated/designed to be autovolt. This refers to the capability of the adapter to accept (without any problem) any voltage anywhere and still process it to a useful output that the laptop can use. This could be verified by looking over the sticker/nameplate of the adapter. If it says 1--~240VAC, then it is auto volt. The next area of concern would be the way the AC plugs are designed. US standards differs from European and for the AC adapter/charger to fit the European wall outlets, some sort of mechanical adapter is required. Most US AC plugs are parallel polarized flat prongs whereas Europeans would be small circular prongs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 05, 2008
Volume on gateway nv57h44u
If the volume on the youtube player is up fully and so is the master volume on the laptop then I would suggest you get a small bluetooth speaker. I use a wired external speaker on one of my laptops as the internal speakers are very weak .. Why not bring your laptop to a small computer shop and try different speakers to see what suits you.
Jan 31, 2018 | Gateway NV57H44U 15.6 Laptop i5 2.4GHz 4GB...
Do you have the Windows media?
This guy sell the media:
http://dallas.craigslist.org/dal/sys/4359959590.html
The Gatewy T-6321 drivers is located in here:
http://support.gateway.com/support/drivers/search.asp?param=t-6321
Mar 06, 2014 | Gateway T-6321 PC Notebook
How do I restore my laptop to factory settings?
Press the F11 key at startup. This should bring up the Gateway System Recovery option. That will allow you to restore your computer to it's originally installed state.
May 28, 2012 | Gateway Computers & Internet
Charger light goes out when plug in computer
it could be that the connection jack on the mainboard has been dislodged from the solder joint, common among Gateway comuters and HP units too. is the DC jack loose from the notebook ? if so thats the issue it seems. You will have to bring it to a computer person to resolder. if not and youc an do it yourslef, save money -- but be careful not to damage anything on the mainboard.
Jan 03, 2012 | Gateway NV5207u Notebook
I got a new battery it worked when i got it now it wont charge ac adapter works though after i made sure the battery worked i put the computer away for a present for my daughter i have my own laptop so the...
Welcome to FixYa!
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Jul 17, 2011 | Gateway T-6321 PC Notebook
I have got problem in my laptop, the battery is not charging, it indicates plugin not charging. i need your help
Hi
Your laptop in warranty then go to the seller and replace the battery, otherwise go to the dell vostro and bring the new battery.
Jun 22, 2011 | Dell Vostro 1220 Laptop Computer PC...
Gateway cx210x notebook: screen flicering and becoming pinkish
hi there, it may be that your cable connecting your monitor to the computer is being wiggled loose. You need to leave this to the pros as this can't be explained over the internet. You need to bring it to a computer shop for them to reconnect the computer. Tell them that the monitor cable is being severed from the graphics card.
Jan 31, 2010 | Gateway CX210X Notebook
Battery not charging
How old is the battery? If this laptop is a couple of years old, you may need a replacement, depending on how many recharge cycles have been done.
Dec 30, 2008 | Gateway MT3705 Notebook
Scroll touchpad broken at my gateway T 6321
I guess that some settings with touch pad might have changed.
try accessing the touch pad controls in the control panel.
may be its called synaptics ....
lemme know if it works :)
Aug 06, 2008 | Computers & Internet
How can I disengage the extremely sensitive touch pad on my Gateway notepad T-6321.c I find that almost every time I try to input data or write a message, if I even barely touch the touch pad by accident,...
Hello my name is Jei and I hope this helps you out.
Some touchpads have a button located above them. Usualy a small bar. This turns the pad on and off.
Otherwise you may be able to disable the touchpad in the bios. (Consult manual for specific instructions)
Another way is to place a thick piece of paper or cardboard over the touchpad area and securing it with clear tape or a nice sticker.
Alternative methods include taking the computer apart and disconnecting the touch pad, but this should only be done by someone who understands who a laptop comes apart and has the space and tools to do it properly.
Jei
Jul 21, 2008 | Gateway Computers & Internet
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
