Question about Euro-Flex Monster 1200 Handheld Steam Cleaner
Cannot remove cap that is used to fill monster steamer cleaner
  • Anonymous Mar 12, 2014
    handle broke where it joins alum shaft that extends to steamer
    Sergeant:
  • 192 Answers
Press the Water tank cap and Unscrew it to the empty water tank. (Page 7)
Manual is at the link below.
LINK
Hope I was help.
Posted on Mar 28, 2011
  • 1 more comment
  • Ebony Dixon
    Ebony Dixon Oct 13, 2013
    still cannot get the cap off
  • Ebony Dixon
    can i pop it off?
  • Tom Salvitti
    Tom Salvitti Jul 27, 2014
    Don't feel bad I have a terrible time getting the cap off as well. I'm college educated, get great to excellent on my reviews at work all the time, but I feel like an idiot with this cap. Everything I read people just go "well you press it and turn it"...no kidding? really? Its not coming off.
My ez1 Monster Floor Steamer - green light goes off when I lower the handle and stops steaming
It could be calcium deposits in the tank. Clean it with white vinegar. Good luck!
Nov 10, 2012 | Euroflex Ez1 Monster Floor Steamer -...
I need operating manual for vapor white wing steamer
This is from an Amazon review. I have misplaced my manual and was searching for a pdf file without any luck. I think I have it under control if I only knew where to put my distilled water.Basic operation of the WhiteWing is:
1. Fill the tank with distilled water
2. Attach the hose to the steamer.
3. Attach the extension handles and attachment you want.(Be sure to watch the video and read the instruction booklet. Some of the attachments have specific uses and setup instructions)
4. Lock the finger trigger.
5. Plug it in.
6. Turn it on.
7. Wait 20 min. or until the pressure gauge reads between 3.5-4.5.
8. Get ready to rock - press the steam release button, unlock the finger trigger and start steaming.
For many jobs such as countertops, shower stalls, stovetops, you will need to follow behind the steam, wiping with a cloth to remove the released dirt from the surface. Some jobs may require you to start with a non-toxic cleaner or grease remover such as Orange Clean or Method brand cleaners. Remember, you'll be breathing in vaporized cleaner. So be sure it's something non-toxic and non-irritating. I prefer the Method brand cleaners.
Jun 20, 2012 | Vapor WhiteWing Steamer Canister Vacuum
My steamer gets hot but no steam if very little is coming out what do i do
clean it with lime away where the steam comes out it has had hard water build up that has clogged your openings
Apr 06, 2012 | Euro-Flex Monster 1200 Handheld Steam...
Bissell carpet steamer not working
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rtsdf
Feb 21, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Euro-flex monster baby 1000 watt will not release steam
try running a descale through the unit. probably blocked with mineral deposits. Descaler available at most steamer retailers
Sep 20, 2009 | EuroSteam Vapor Steam Cleaner Vacuum
Steamer filler cap is sealed
You need a little more leverage--either a strap type tool or a pair of adjustable width pliers that span the width of the cap. Try running hot water over the cap first which may loosen it enough to remove by hand.
Sep 09, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
Scuncii Steamer
It is probably clogged with rust or limescale - can happen with steam cleaners. Sadly there's no way around this but to try a limescale remover in distilled water such as Calgon limescale remover. Fill the kettle as normal and give it time to boil up. Then release the steam as you would normally. You may find that the kettle will spurt out deposits of gunk. Sounds like its definately clogged though.
Feb 19, 2009 | Scunci 52067 Handheld Steam Vacuum
Dirt devil easy steamer need directions to use
Thank you for responding to my question. I should have spent some time really looking at my little machine. It wasn't hard to figure out -once I found and read the back of the cleaning solution bottle and tried my luck following the water to cleaner ratio.. Opening, adding the cleaning solution and water and re-closing the reservoir was pretty easy. Everything worked out fine...and my carpet is...spotless. Thank you, Cmarie
Mar 27, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Euro-Flex Monster 1200 Handheld Steam Cleaner Logo
1,262 people viewed this question
Top Euro-Flex Vacuums Experts
Are you an Euro-Flex Vacuum Expert? Answer questions, earn points and help others
