Question about Nintendo DS Lite
My DS lite turned off and will not take a charge and will not turn back on. I plugged it in to the wall and it will not turn back on.
  • 41 Answers
It might be the charging port. I had this problem with my DS and sent it to www.videogame911.com. They fixed it fast, had it back less then a week.
Posted on Mar 28, 2011
Hi my nintendo ds lite wn't turn. do i require to charage my ds,or no?
A Nintendo DS console will indeed need charging. If your light appears as red, yes, you will need to purchase a Nintendo DS charger. All and every kinds of Nintendo DS's require charging. Nintendo DS, Nintendo DS Lite, Nintendo DSi, Nintendo DSi XL, and Nintendo 3DS. You will have to insert the wall outlet side of the plug into the wall, and the other smaller side into the DS, DSi, or 3DS.
If you have any further questions or concerns, feel free to contact me!
Jul 07, 2011 | Microsoft Xbox 360 Console
How to charge and turn a ds lite on
Use the charging cord packaged within the box that your DS came in plugged into the wall socket and the small hole in your DS near the slot for the games. Turn it on by flicking the small button with an arrow on it up (on the right of your DS).
Feb 21, 2011 | Nintendo Bottom Full replacement TFT LCD...
I havent charged my ds for about 3 months and now when i plug it the yellow light comes on for about a sec. and turns off and it wont turn on how do i make it charge
well, here are some ideas as to why it might be like that...
1. Your battery is old, like how cell phone batteries die quicker the longer you use them, your ds may be the same way...
2. You have dropped your ds (have you in those 3 months of it sitting around?) and now the battery is loose or broken.
3. Just try to plug your ds charger into your ds, and see what happens. This should be the method that works, if your ds won't turn on, its because the batteries probably dead, just plug it into a wall outlet and see what happens...
Hope this helps you get started, GOOD LUCK! :-)
Mar 30, 2009 | Nintendo DS Lite Console
Nintendo DS Lite won't turn on unless game is plugged
well you could charge your ds and whil its charging you can turn it on
Mar 16, 2009 | Nintendo DS Lite Console
NINTENDO DS LITE WON'T CHARGE OR POWER ON
Each time you charge your battery, the charge capacity is decreased. After a large amount of charges, the capacity is decreased to an amount only enough to turn on a/the screen(s) for a second. Try getting a new battery.
Mar 02, 2009 | Nintendo DS Console
Nintendo ds lite shut down
I would contact nintendo if you have a warranty. Also try changing the battery or charger on the internet
Dec 03, 2008 | Nintendo DS Lite Console
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
No power
Try looking for the Nintendo DS fuse problem here in fixya.
If your DS is still covered by warranty then contact the nintendo customer service before doing any custom repair.
May 27, 2008 | Nintendo DS Lite Console
Ndsl power problem
As Bob (HowlingMad) said, the Ds and Ds Lite will turn off immediately after being turned on if the connection to the top screen is broken.
Check the connections between the screen and Ds, if they look damaged then try replacing the ribbon cable for the top screen (or you may have to replace the whole screen - i'm not sure if it is built together on the Ds Lite). If the connections appear fine then it may be that due to the movement the connector has come out of it's socket/plug (also like Bob said), this is easily fixable if this is the case and would require you to take the casing off your Ds and plug it back in.
Hope this helps
Mowcius
May 07, 2008 | Nintendo DS Lite Console
Ds lite ac wall charger
When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
Nov 30, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Logo
175 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
