Question about Toshiba MD26H82 26" TV/DVD Combo
Hi im trying to hook up a vizeo sound bar to a toshiba model#md26h82 tv/dvd combo,what i would like to know is how do i change the audio settings on the tv so they can go to the digital audio out(red and white jacks) and be picked up by the soundbar,i have no owners manual for tv just bill of sale, any info you could give me is greatly appreciated...joe
  • 2 more comments
  • joe377483 Mar 28, 2011
    hi im trying to hook up a vizeo sound bar to a toshiba model#md26h82 tv/dvd combo,what i would like to know is how do i change the audio settings on the tv so they can go to the digital audio out(red and white jacks) and be picked up by the soundbar,i have no owners manual for tv just bill of sale, any info you could give me is greatly appreciated...joe
  • joe377483 Mar 30, 2011
    the Model number of the SoundBarVSB200 here is all info i have on the soundbar.
    VIZIO Sound Bar:VIZIO Sound Bar:
    Flat-panel sound
    Four 3" high-efficiency, hand-built mid/bass transducers
    Two 3/4" high-performance, aluminum-dome neodymium tweeters
    Speaker bar frequency response: 60Hz to 20kHz
    Integrated Class-D amplifier at 15 x2 channel with 0.01% THD
    S/PDIF receiver for digital audio delivery
    102db Dynamic range
    Support for PCM input via TOSLINK input
    High Power Efficiency with Low Power Consumption
    Environmentally conscious
    High Definition Audio Performance
    High-Performance 32-Bit 150MHz DSP Audio Engine
    Impressive Sound Pressure Level measuring 98dB SPL max @ 1M
    Advanced 24-Bit Linear PCM to PWM Engine with integrated thermal, over-current, over voltage, over current protection
    Latest Virtualization & Volume Leveling Technology from SRS Labs
    SRS TruSurround HD virtual surround
    SRS TruVolume eliminates undesirable loud commercials and channel to channel variances
    Two analog and 1 S/PDIF connectors
    Flexible stand supporting both desktop and wall mount configurations
    AC (100V-240V, 50-60Hz) Power Supply Connection to Speaker Bar
    Line output to optional subwoofer, 2Vpp.
    Master Volume Control
    Input Select
    Mute
    SRS TruSurround HD signal processing on/off
    SRS TruVolume On/Off
    Power
    2 Stereo RCA Input
    Input Sensitivity: 2Vrms (max)
    1 S/PDIF Fiber Optic TOSLINK Input
    Supported Sampling Frequencies: 32kHz, 44.1kHz, 48kHz
    Support Linear PCM Bit Depths: 16-bit, 20-bit
    SRS TruSurround HD enables compelling Virtual Surround experience from mono, stereo or 2 channel matrix surround encoded content
    SRS TruBass psychoacoustic bass enhancements enables amazing bass for a single bar
    SRS FOCUS sound height alignment for precise sonic stage placement under panel
    SRS Dialog Clarity delivers enhanced vocal intelligibility
    SRS Definition delivers sparkling detail while bringing lost background information to life
    SRS TruVolume eliminates undesirable increase in volume when commercials come on and channel to channel volume variances.
    VIZIO Sound Bar:
  • Flat-panel sound
  • Four 3" high-efficiency, hand-built mid/bass transducers
  • Two 3/4" high-performance, aluminum-dome neodymium tweeters
  • Speaker bar frequency response: 60Hz to 20kHz
  • Integrated Class-D amplifier at 15 x2 channel with 0.01% THD
  • S/PDIF receiver for digital audio delivery
  • 102db Dynamic range
  • Support for PCM input via TOSLINK input
  • High Power Efficiency with Low Power Consumption
  • Environmentally conscious
  • High Definition Audio Performance
  • High-Performance 32-Bit 150MHz DSP Audio Engine
  • Impressive Sound Pressure Level measuring 98dB SPL max @ 1M
  • Advanced 24-Bit Linear PCM to PWM Engine with integrated thermal, over-current, over voltage, over current protection
  • Latest Virtualization & Volume Leveling Technology from SRS Labs
  • SRS TruSurround HD virtual surround
  • SRS TruVolume eliminates undesirable loud commercials and channel to channel variances
  • Two analog and 1 S/PDIF connectors
  • Flexible stand supporting both desktop and wall mount configurations
  • AC (100V-240V, 50-60Hz) Power Supply Connection to Speaker Bar
  • Line output to optional subwoofer, 2Vpp.
  • Master Volume Control
  • Input Select
  • Mute
  • SRS TruSurround HD signal processing on/off
  • SRS TruVolume On/Off
  • Power
  • 2 Stereo RCA Input
  • Input Sensitivity: 2Vrms (max)
  • 1 S/PDIF Fiber Optic TOSLINK Input
  • Supported Sampling Frequencies: 32kHz, 44.1kHz, 48kHz
  • Support Linear PCM Bit Depths: 16-bit, 20-bit
  • SRS TruSurround HD enables compelling Virtual Surround experience from mono, stereo or 2 channel matrix surround encoded content
  • SRS TruBass psychoacoustic bass enhancements enables amazing bass for a single bar
  • SRS FOCUS sound height alignment for precise sonic stage placement under panel
  • SRS Dialog Clarity delivers enhanced vocal intelligibility
  • SRS Definition delivers sparkling detail while bringing lost background information to life
  • SRS TruVolume eliminates undesirable increase in volume when commercials come on and channel to channel volume variances.
  • joe377483 Mar 31, 2011
    the Model number of the SoundBarVSB200 here is all info i have on the soundbar. VIZIO Sound Bar:VIZIO Sound Bar: Flat-panel sound Four 3" high-efficiency, hand-built mid/bass transducers Two 3/4" high-performance, aluminum-dome neodymium tweeters Speaker bar frequency response: 60Hz to 20kHz Integrated Class-D amplifier at 15 x2 channel with 0.01% THD S/PDIF receiver for digital audio delivery 102db Dynamic range Support for PCM input via TOSLINK input High Power Efficiency with Low Power Consumption Environmentally conscious High Definition Audio Performance High-Performance 32-Bit 150MHz DSP Audio Engine Impressive Sound Pressure Level measuring 98dB SPL max @ 1M Advanced 24-Bit Linear PCM to PWM Engine with integrated thermal, over-current, over voltage, over current protection Latest Virtualization & Volume Leveling Technology from SRS Labs SRS TruSurround HD virtual surround SRS TruVolume eliminates undesirable loud commercials and channel to channel variances Two analog and 1 S/PDIF connectors Flexible stand supporting both desktop and wall mount configurations AC (100V-240V, 50-60Hz) Power Supply Connection to Speaker Bar Line output to optional subwoofer, 2Vpp. Master Volume Control Input Select Mute SRS TruSurround HD signal processing on/off SRS TruVolume On/Off Power 2 Stereo RCA Input Input Sensitivity: 2Vrms (max) 1 S/PDIF Fiber Optic TOSLINK Input Supported Sampling Frequencies: 32kHz, 44.1kHz, 48kHz Support Linear PCM Bit Depths: 16-bit, 20-bit SRS TruSurround HD enables compelling Virtual Surround experience from mono, stereo or 2 channel matrix surround encoded content SRS TruBass psychoacoustic bass enhancements enables amazing bass for a single bar SRS FOCUS sound height alignment for precise sonic stage placement under panel SRS Dialog Clarity delivers enhanced vocal intelligibility SRS Definition delivers sparkling detail while bringing lost background information to life SRS TruVolume eliminates undesirable increase in volume when commercials come on and channel to channel volume variance
      President:
    • 1,140 Answers
    Hello Joe,
    I can help you get this all setup and working, but I should start by telling you that you cannot connect this TV to your soundbar using the red and white RCA jacks. The red and white RCA jacks are analog and none of the RCA audio sockets on the back of this TV are audio outputs. They are all audio inputs. I've ringed these in red in the picture below.
    The only audio outputs on this TV are digital coaxial and digital optical, ringed these in green:
    The only way to connect this TV to your Vizio soundbar is using a digital optical or digital coaxial cable. If you don't have either of these, you will need to purchase one, but you can only use one of these cables if the Vizio SoundBar has digital optical IN or digital coaxial IN. If you can let me know the model number of the SoundBar I can help you to work out the best way to connect it all.
    Digital Optical
    Digital Coaxial
    There are other options as well. If you are using a cable/satellite receiver or digital converter as the source for your TV channels, you can connect this box directly to the SoundBar. Most of these boxes have RCA type audio OUT sockets, so you would be able to use your red & white analog audio cable if you connected this way. It is actually better to connect all of the audio sources, i.e cable/satellite receiver, DVD player, etc directly to the SoundBar, rather than routing the audio via the TV. Connecting via the TV can result in audio delay meaning the sound is out of sync with the picture and you may get echo if you are using the TV speaker as well.
    I am happy to provide as much detail and assistance as you need and I can also draw you a setup diagram, but in order to do so, I will need the following details:
    1. Model number of the SoundBar
    2. Model number of cable/satellite receiver or digital converter (if using one)
    3. Model numbers of any other devices you wish to connect to the SoundBar (if any)
    4. Which audio cables you have spare for making connections.
    Finally, you obviously need a manual for this TV. This is available from FixYa and can be downloaded by clicking on the following link:
    http://static.fixya.com/Manuals/T/Toshiba/_79ED16AEB8FA88D5535AF820E55B52F1.pdf
    If you are unable to open the file, you will need to download and install Adobe Reader:
    http://get.adobe.com/reader/
    Hope this helps. If you need further assistance, please reply to me with the details requested above.
    Regards,
    BElectric
    Posted on Mar 28, 2011
    • 325 Answers
    The tv should auto detect the optical signal for the soundbar. Some tvs will not and you must go into the sound (menu settings) and choose optical as a sound output method. If niether of these work you will need to test the sound bar with the optical output of the tv and possibly lower the tv volume all the way down and turn the sound bar up...My phillips tv doesn't auto detect, and I must turn down my tv volume and up the volume on my sound bar to produce the optical sound.
    Let me know if this helps :)
    • 1 more comment
    • Andrew P.
      Andrew P. Mar 28, 2011
      by red and white do you mean standard definition (analog?). True digital sound is a single output, much like this picture.
      For analog to digital/optical you will need one of these:
      These are the adaptors commonly used for soundbars with tvs that do not support one sound format.
      Please let me know if this helped :)
    • Andrew P.
      Andrew P. Mar 31, 2011
      Please explain to me which output method you are trying to use from the below image:
    • Andrew P.
      Better yet. Here is the manual it covers everything needed for external sound options:
      Please follow this link:
      http://www.mediafire.com/file/fhw3awoiev...
      If this has helped please rate :)
    We are trying to hook up a VIZIO sound bar model#S3820w-Co to our Vizio TV we also have Directv and a dvd player hook to this tv which wire do we hook from sound bar to Tv
    If the TV and sound bar have an optical connector, then get the optical cable to connect the two. If not then use the audio out jacks on the TV and don't forget to change the audio set up to switch the sound to the sound bar.
    Oct 29, 2014 | Televison & Video
    Is there any recourse for a new TV that has little sound?
    I do not understand why the set cannot be returned but I would be interested to know if the low sound is on TV or DVD only or both.
    Some of these sets have a tiny audio circuit that puts out fairly low sound levels---unless a as is sale the set has to be fit to be used, go after the store first for refund or exchange for another brand or Contact Toshiba==set may be up for a exchange if enough folks complain.
    Sep 02, 2012 | Toshiba Televison & Video
    Connecting my VCR/DVD combo to Toshiba television
    It would be helpful to know what cable your trying to connect, component, S-VIDEO, HDMI, etc. Also the make & model of the combo unit & Toshiba TV. However the basic process is usually the same for most hardware. Make sure the connection to combo unit is "video/audio out" not in and make sure the input for the TV says IN not OUT. Then you need to set the TV to the correct input channel. And then make sure the combo unit is using the correct output... usually this is automatic for component cables but not always.
    Nov 16, 2011 | Toshiba Televison & Video
    Im trying to set up my tv, it was given to me as a gift, my uncle was using it it works i can change the channels but when i try to work my dvd player with it, only the audio comes on the screen stays...
    Please few things...
    1- Make sure audio and video wires are hooked correctly in AV input of tv and you selected that AV input in tv with its remote.
    2- Also check your dvd has not been set on progressive mode if you hook dvd player through yellow-red-white wires with tv.
    3- if dvd player is set on progressive mode, then hook it with tv by component video input, red-green-blue for video and red-white for audio.
    Hope this info will solve your problem.
    Thanks.
    Mar 17, 2010 | Toshiba TP55H60 55" Rear Projection...
    I am hooked into cable and not on antenna. I can get sound w/ the DVD player that is hooked up to the tv but no sound on the tv. The tv channels come in clear but no sound.
    May be a simple problem with the SAP (second audio program ) being set to the wrong place, run thru the onscreen audio menu and see if this is the case
    Dec 18, 2009 | Toshiba MV13L2 13 in. TV/VCR Combo
    I have sound but no picture. The screen is black
    can you see any any menus or the volume bar or channel indicator?
    Make sure all your audio and video cables are hooked up correctly to inputs on the TV and to the same set of hookups. For example all of the VCR cables hooked into video 1 and all of the DVD cables in video 2.
    Also check that you haven't hooked up the video to the tv's output. Some sets output audio and/or video for external devices such as recording setups or home theater sound systems.
    Oct 17, 2009 | Zenith TVBR2742Z 27 in. TV/VCR Combo
    Only getting sound but no picture!
    Well, i had a look at the back of that Toshiba TV - make sure that the red, white, and yellow cables are hooked into the Video-1 slot of the Toshiba and that the Toshiba channel is changed to Video 1.
    Then check your nameless DVD player and make sure the red, white, and yello cables are all hooked to OUTPUT slots that are in the same column or row - if I had you DVD manufacturer and model #, I could suggest some additional steps to check. Also, make sure your dvd player is in dvd playback mode.
    -Tha Mp3 Doctor
    Dec 31, 2008 | Toshiba 42HL167 42 in. LCD Television
    Hooking up a d.v.d player to a vcr/tv combo?
    RCA plugs (the yellow, red, and white outlets you speak of) consist of a video plug (yellow) and stereo plugs for audio (red and white). Just match the colors from the DVD RCA colors to the RCA hook-ups on the TV (ex. Yellow the Yellow, White to White).
    You don't need to worry about the red one, it just makes the DVD player play stereo audio. Instead, you'll have mono, which is fine, and most modern players can detect mono and switch it for you so don't worry about changing settings and what not (unless you're missing sound on one side.)
    Sep 13, 2008 | Optical Coating Model 108 VHS VCR
    DVD hook up
    You need 3 pins cable for Components Video hook up and 2 pins for Audio Right-Left conncetion.
    There is another option of Yellow-Red-White combination for Video / Audio hook up.
    Please let me know what type of set up you need.
    Aug 22, 2008 | Insignia LCDTV26 26 in. Television
    Toshiba MD26H82 26" TV/DVD Combo Logo
    213 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
